Project: 2673 (Run 5, Clone 12, Gen 51) SLOWWWW
parkut
Post by parkut »
WU has been deleted, would never have made deadline
model name : Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
cpu MHz : 2394.000
cache size : 4096 KB
Memory: 975.89 MB physical, 1.94 GB virtual
Core: FahCore_a2.exe
Current Work Unit
Name: p2673_IBX in water
Tag: P2673R5C12G51
Download time: January 14 00:38:16
Due time: January 20 00:38:16
Progress: 5% [__________]
[00:38:17] Project: 2673 (Run 5, Clone 12, Gen 51)
[00:38:17]
[00:38:17] Assembly optimizations on if available.
[00:38:17] Entering M.D.
[00:38:27] (Run 5, Clone 12, Gen 51)
[00:38:27]
[00:38:27] Entering M.D.
[03:32:51] - Autosending finished units... [January 14 03:32:51 UTC]
[03:32:51] Trying to send all finished work units
[03:32:51] + No unsent completed units remaining.
[03:32:51] - Autosend completed
[07:36:02] 1%)
[09:32:51] - Autosending finished units... [January 14 09:32:51 UTC]
[09:32:51] Trying to send all finished work units
[09:32:51] + No unsent completed units remaining.
[09:32:51] - Autosend completed
[14:33:52] Completed 330009 out of 16499999 steps  (2%)
[15:32:51] - Autosending finished units... [January 14 15:32:51 UTC]
[15:32:51] Trying to send all finished work units
[15:32:51] + No unsent completed units remaining.
[15:32:51] - Autosend completed
[21:31:42] Completed 495009 out of 16499999 steps  (3%)
[21:32:51] - Autosending finished units... [January 14 21:32:51 UTC]
[21:32:51] Trying to send all finished work units
[21:32:51] + No unsent completed units remaining.
[21:32:51] - Autosend completed
[03:32:51] - Autosending finished units... [January 15 03:32:51 UTC]
[04:29:05] Completed 660009 out of 16499999 steps  (4%)
[09:32:52] - Autosending finished units... [January 15 09:32:52 UTC]
[09:32:52] Trying to send all finished work units
[09:32:52] + No unsent completed units remaining.
[09:32:52] - Autosend completed
[11:26:23] Completed 825009 out of 16499999 steps  (5%)
MtM
Hardware configuration: Q6600 - 8gb - p5q deluxe - gtx275 - hd4350 ( not folding ) win7 x64 - smp:4 - gpu slot
T5450 - 4gb - ?? - 8600M GT 512 ( DDR2 ) - win7 x64 - smp:2 - gpu slot
Re: Project: 2673 (Run 5, Clone 12, Gen 51) SLOWWWW
Post by MtM »
That was a bad wu, look at the number of steps. Should inform Kason ( or I think I saw a report yesterday also maybe it was the same project not sure ).
kasson
Pande Group Member
Post by kasson »
Yes, it's a bad WU. I stopped it server-side. Thanks for the report.
