Project: 5771 (Run 12, Clone 48, Gen 6)
Flathead74
Post by Flathead74 »
Possible bad WU?
It fails immediately.
[00:55:25] *------------------------------*
[00:55:25] Folding@Home GPU Core - Beta
[00:55:25] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[00:55:25]
[00:55:25] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[00:55:25] Build host: amoeba
[00:55:25] Board Type: Nvidia
[00:55:25] Core      :
[00:55:25] Preparing to commence simulation
[00:55:25] - Looking at optimizations...
[00:55:25] - Created dyn
[00:55:25] - Files status OK
[00:55:25] - Expanded 45411 -> 251112 (decompressed 552.9 percent)
[00:55:25] Called DecompressByteArray: compressed_data_size=45411 data_size=251112, decompressed_data_size=251112 diff=0
[00:55:25]
[00:55:25] Project: 5771 (Run 12, Clone 48, Gen 6)
[00:55:25]
[00:55:25] Assembly optimizations on if available.
[00:55:25] Entering M.D.
[00:55:32] Working on Protein
[00:55:33] Client config found, loading data.
[00:55:33] mdrun_gpu returned
[00:55:33] NANs detected on GPU
[00:55:33]
[00:55:33] Folding@home Core Shutdown: UNSTABLE_MACHINE
[00:55:35] CoreStatus = 7A (122)
[00:55:35] Sending work to server
[00:55:35] Project: 5771 (Run 12, Clone 48, Gen 6)
[00:55:35] - Read packet limit of 540015616... Set to 524286976.
[00:55:35] - Error: Could not get length of results file work/wuresults_09.dat
[00:55:35] - Error: Could not read unit 09 file. Removing from queue.
[00:55:35] Trying to send all finished work units
[00:55:35] + No unsent completed units remaining.
[00:55:35] - Preparing to get new work unit...
[00:55:35] + Attempting to get work packet
Re: Project: 5771 (Run 12, Clone 48, Gen 6)
There are 6 similar reports in the DB ... I've marked the WU.
ChrissyT88
Post by ChrissyT88 »
Just to let you know i picked this one up just now (lucky i checked!). Gave instant NANs and shut down for 24hrs.
[14:22:57] Folding@Home GPU Core - Beta
[14:22:57] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[14:22:57]
[14:22:57] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[14:22:57] Build host: amoeba
[14:22:57] Board Type: Nvidia
[14:22:57] Core      :
[14:22:57] Preparing to commence simulation
[14:22:57] - Looking at optimizations...
[14:22:57] - Created dyn
[14:22:57] - Files status OK
[14:22:57] - Expanded 45411 -> 251112 (decompressed 552.9 percent)
[14:22:57] Called DecompressByteArray: compressed_data_size=45411 data_size=251112, decompressed_data_size=251112 diff=0
[14:22:57] - Digital signature verified
[14:22:57]
[14:22:57] Project: 5771 (Run 12, Clone 48, Gen 6)
[14:22:57]
[14:22:57] Assembly optimizations on if available.
[14:22:57] Entering M.D.
[14:23:04] Working on Protein
[14:23:04] Client config found, loading data.
[14:23:04] mdrun_gpu returned
[14:23:04] NANs detected on GPU
[14:23:04]
[14:23:04] Folding@home Core Shutdown: UNSTABLE_MACHINE
[14:23:07] CoreStatus = 7A (122)
[14:23:07] Sending work to server
[14:23:07] Project: 5771 (Run 12, Clone 48, Gen 6)
[14:23:07] - Error: Could not get length of results file work/wuresults_01.dat
[14:23:07] - Error: Could not read unit 01 file. Removing from queue.
[14:23:07] - Preparing to get new work unit...
[14:23:07] + Attempting to get work packet
[14:23:07] - Connecting to assignment server
[14:23:08] - Successful: assigned to (171.67.108.11).
[14:23:08] + News From Folding@Home: GPU folding beta
[14:23:08] Loaded queue successfully.
[14:23:10] + Closed connections
[14:23:15]
[14:23:15] + Processing work unit
[14:23:15] Core required: FahCore_11.exe
[14:23:15] Core found.
[14:23:15] Working on queue slot 02 [January 18 14:23:15 UTC]
[14:23:15] + Working ...
[14:23:15]
[14:23:15] *------------------------------*
[14:23:15] Folding@Home GPU Core - Beta
[14:23:15] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[14:23:15]
[14:23:15] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[14:23:15] Build host: amoeba
[14:23:15] Board Type: Nvidia
[14:23:15] Core      :
[14:23:15] Preparing to commence simulation
[14:23:15] - Looking at optimizations...
[14:23:15] - Created dyn
[14:23:15] - Files status OK
[14:23:15] - Expanded 45411 -> 251112 (decompressed 552.9 percent)
[14:23:15] Called DecompressByteArray: compressed_data_size=45411 data_size=251112, decompressed_data_size=251112 diff=0
[14:23:15] - Digital signature verified
Card is a GTX280 - stable on every unit so far. Will delete unit.
Jester
Post by Jester »
Had the same Wu on two seperate occasions today,
Last "24hr shutdown" only a couple of hours ago,
Lucky I'm on holidays....... :roll:
Jester
Post by Jester »
And again on another rig, 5 x instant failure and client shutdown for 24 hrs,
This is getting ridiculous..... :x
Flathead74
Here it is again... it shut me down...
[08:05:24] Project: 5771 (Run 12, Clone 48, Gen 6)
[08:05:24]
[08:05:24] Assembly optimizations on if available.
[08:05:24] Entering M.D.
[08:05:30] Working on Protein
[08:05:31] Client config found, loading data.
[08:05:31] Starting GUI Server
[08:05:31] mdrun_gpu returned
[08:05:31] NANs detected on GPU
[08:05:31]
[08:05:31] Folding@home Core Shutdown: UNSTABLE_MACHINE
[08:05:34] CoreStatus = 7A (122)
[08:05:34] Sending work to server
[08:05:34] Project: 5771 (Run 12, Clone 48, Gen 6)
[08:05:34] - Read packet limit of 540015616... Set to 524286976.
[08:05:34] - Error: Could not get length of results file work/wuresults_02.dat
[08:05:34] - Error: Could not read unit 02 file. Removing from queue.
[08:05:34] EUE limit exceeded. Pausing 24 hours.
