Project 5113 (R85, C94, G6)
tonic
Post by tonic »
Are these WUs abnormally slow? I'm currently at 32% and fahmon is reporting 3d remaining STILL. This is on an e6850 c2d @ 3.0Ghz. I normally get about ~500PPD with a CPU client on one core, but with this unit it has dropped down to around ~100PPD. The only difference I see is that it's running the a0 core.
Re: Project 5113 (R85, C94, G6)
Are you sure that SSE optimizations are on ? (look in the FAHlog.txt, you should see "Extra SSE boost OK" message)
Post your FAHlog.txt here if you don't know where to find the information.
tonic
Post by tonic »
It seems that they aren't according to the log. Do I need to use a special flag?
-forceasm should help ...
