Project: 5760 (Run 5, Clone 21, Gen 108) - UM at various %
[12:07:36] Project: 5760 (Run 5, Clone 21, Gen 108)
[12:07:36]
[12:07:36] Assembly optimizations on if available.
[12:07:36] Entering M.D.
[12:07:43] Working on Protein
[12:07:45] Client config found, loading data.
[12:07:45] Starting GUI Server
[12:08:44] Completed 1%
[13:06:13] Completed 59%
[13:06:13] mdrun_gpu returned
[13:06:13] NANs detected on GPU
[13:06:13]
[13:06:13] Folding@home Core Shutdown: UNSTABLE_MACHINE
[13:06:16] CoreStatus = 7A (122)
[13:06:16] Sending work to server
[13:06:16] Project: 5760 (Run 5, Clone 21, Gen 108)
[13:06:16] - Read packet limit of 540015616... Set to 524286976.
[13:06:16] - Error: Could not get length of results file work/wuresults_00.dat
[13:06:16] - Error: Could not read unit 00 file. Removing from queue.
[13:06:16] Trying to send all finished work units
[13:06:16] + No unsent completed units remaining.
[13:06:16] - Preparing to get new work unit...
[13:06:16] + Attempting to get work packet
[13:06:16] - Will indicate memory of 1022 MB
[13:06:16] - Connecting to assignment server
[13:06:16] Connecting to http://assign-GPU.stanford.edu:8080/
[13:06:18] Posted data.
[13:06:18] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[13:06:18] + News From Folding@Home: GPU folding beta
[13:06:18] Loaded queue successfully.
[13:06:18] Connecting to http://171.64.65.106:8080/
[13:06:20] Posted data.
[13:06:20] Initial: 0000; - Receiving payload (expected size: 69072)
[13:06:22] - Downloaded at ~33 kB/s
[13:06:22] - Averaged speed for that direction ~49 kB/s
[13:06:22] + Received work.
[13:06:22] Trying to send all finished work units
[13:06:22] + No unsent completed units remaining.
[13:06:22] + Closed connections
[13:06:27]
[13:06:27] + Processing work unit
[13:06:27] Core required: FahCore_11.exe
[13:06:27] Core found.
[13:06:27] Working on queue slot 01 [January 9 13:06:27 UTC]
[13:06:27] + Working ...
[13:06:27] - Calling '.\FahCore_11.exe -dir work/ -suffix 01 -priority 96 -checkpoint 15 -verbose -lifeline 680 -version 623'
[13:06:27]
[13:06:27] *------------------------------*
[13:06:27] Folding@Home GPU Core - Beta
[13:06:27] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[13:06:27]
[13:06:27] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[13:06:27] Build host: amoeba
[13:06:27] Board Type: Nvidia
[13:06:27] Core      :
[13:06:27] Preparing to commence simulation
[13:06:27] - Looking at optimizations...
[13:06:27] - Created dyn
[13:06:27] - Files status OK
[13:06:27] - Expanded 68560 -> 357580 (decompressed 521.5 percent)
[13:06:27] Called DecompressByteArray: compressed_data_size=68560 data_size=357580, decompressed_data_size=357580 diff=0
[13:06:27] - Digital signature verified
[13:06:27]
[13:06:27] Project: 5760 (Run 5, Clone 21, Gen 108)
[13:06:27]
[13:06:27] Assembly optimizations on if available.
[13:06:27] Entering M.D.
[13:06:34] Working on Protein
[13:06:36] Client config found, loading data.
[13:06:36] Starting GUI Server
[13:07:35] Completed 1%
[13:08:35] Completed 2%
[13:09:21] Completed 3%
[13:09:21] mdrun_gpu returned
[13:09:21] NANs detected on GPU
[13:09:21]
[13:09:21] Folding@home Core Shutdown: UNSTABLE_MACHINE
[13:09:24] CoreStatus = 7A (122)
[13:09:24] Sending work to server
[13:09:24] Project: 5760 (Run 5, Clone 21, Gen 108)
[13:09:24] - Read packet limit of 540015616... Set to 524286976.
[13:09:24] - Error: Could not get length of results file work/wuresults_01.dat
[13:09:24] - Error: Could not read unit 01 file. Removing from queue.
[13:09:24] Trying to send all finished work units
[13:09:24] + No unsent completed units remaining.
[13:09:24] - Preparing to get new work unit...
[13:09:24] + Attempting to get work packet
[13:09:24] - Will indicate memory of 1022 MB
[13:09:24] - Connecting to assignment server
[13:09:24] Connecting to http://assign-GPU.stanford.edu:8080/
[13:09:24] Posted data.
[13:09:24] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[13:09:24] + News From Folding@Home: GPU folding beta
[13:09:25] Loaded queue successfully.
[13:09:25] Connecting to http://171.64.65.106:8080/
[13:09:25] Posted data.
[13:09:25] Initial: 0000; - Receiving payload (expected size: 69072)
[13:09:27] - Downloaded at ~33 kB/s
[13:09:27] - Averaged speed for that direction ~46 kB/s
[13:09:27] + Received work.
[13:09:27] Trying to send all finished work units
[13:09:27] + No unsent completed units remaining.
[13:09:27] + Closed connections
[13:09:32]
[13:09:32] + Processing work unit
[13:09:32] Core required: FahCore_11.exe
[13:09:32] Core found.
[13:09:32] Working on queue slot 02 [January 9 13:09:32 UTC]
[13:09:32] + Working ...
[13:09:32] - Calling '.\FahCore_11.exe -dir work/ -suffix 02 -priority 96 -checkpoint 15 -verbose -lifeline 680 -version 623'
[13:09:32]
[13:09:32] *------------------------------*
[13:09:32] Folding@Home GPU Core - Beta
[13:09:32] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[13:09:32]
[13:09:32] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[13:09:32] Build host: amoeba
[13:09:32] Board Type: Nvidia
[13:09:32] Core      :
[13:09:32] Preparing to commence simulation
[13:09:32] - Looking at optimizations...
[13:09:32] - Created dyn
[13:09:32] - Files status OK
[13:09:32] - Expanded 68560 -> 357580 (decompressed 521.5 percent)
[13:09:32] Called DecompressByteArray: compressed_data_size=68560 data_size=357580, decompressed_data_size=357580 diff=0
[13:09:32] - Digital signature verified
[13:09:32]
[13:09:32] Project: 5760 (Run 5, Clone 21, Gen 108)
[13:09:32]
[13:09:32] Assembly optimizations on if available.
[13:09:32] Entering M.D.
[13:09:38] Working on Protein
[13:09:40] Client config found, loading data.
[13:09:40] Starting GUI Server
[13:10:40] Completed 1%
[14:14:09] Completed 65%
[14:14:09] mdrun_gpu returned
[14:14:09] NANs detected on GPU
[14:14:09]
[14:14:09] Folding@home Core Shutdown: UNSTABLE_MACHINE
[14:14:12] CoreStatus = 7A (122)
[14:14:12] Sending work to server
[14:14:12] Project: 5760 (Run 5, Clone 21, Gen 108)
[14:14:12] - Read packet limit of 540015616... Set to 524286976.
[14:14:12] - Error: Could not get length of results file work/wuresults_02.dat
[14:14:12] - Error: Could not read unit 02 file. Removing from queue.
[14:14:12] Trying to send all finished work units
[14:14:12] + No unsent completed units remaining.
[14:14:12] - Preparing to get new work unit...
[14:14:12] + Attempting to get work packet
[14:14:12] - Will indicate memory of 1022 MB
[14:14:12] - Connecting to assignment server
[14:14:12] Connecting to http://assign-GPU.stanford.edu:8080/
[14:14:13] Posted data.
[14:14:13] Initial: 40AB; - Successful: assigned to (171.64.65.106).
[14:14:13] + News From Folding@Home: GPU folding beta
[14:14:13] Loaded queue successfully.
[14:14:13] Connecting to http://171.64.65.106:8080/
[14:14:14] Posted data.
[14:14:14] Initial: 0000; - Receiving payload (expected size: 69072)
[14:14:16] - Downloaded at ~33 kB/s
[14:14:16] - Averaged speed for that direction ~43 kB/s
[14:14:16] + Received work.
[14:14:16] Trying to send all finished work units
[14:14:16] + No unsent completed units remaining.
[14:14:16] + Closed connections
[14:14:21]
[14:14:21] + Processing work unit
[14:14:21] Core required: FahCore_11.exe
[14:14:21] Core found.
[14:14:21] Working on queue slot 03 [January 9 14:14:21 UTC]
[14:14:21] + Working ...
[14:14:21] - Calling '.\FahCore_11.exe -dir work/ -suffix 03 -priority 96 -checkpoint 15 -verbose -lifeline 680 -version 623'
[14:14:21]
[14:14:21] *------------------------------*
[14:14:21] Folding@Home GPU Core - Beta
[14:14:21] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[14:14:21]
[14:14:21] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[14:14:21] Build host: amoeba
[14:14:21] Board Type: Nvidia
[14:14:21] Core      :
[14:14:21] Preparing to commence simulation
[14:14:21] - Looking at optimizations...
[14:14:21] - Created dyn
[14:14:21] - Files status OK
[14:14:21] - Expanded 68560 -> 357580 (decompressed 521.5 percent)
[14:14:21] Called DecompressByteArray: compressed_data_size=68560 data_size=357580, decompressed_data_size=357580 diff=0
[14:14:21] - Digital signature verified
[14:14:21]
[14:14:21] Project: 5760 (Run 5, Clone 21, Gen 108)
[14:14:21]
[14:14:21] Assembly optimizations on if available.
[14:14:21] Entering M.D.
[14:14:28] Working on Protein
[14:14:30] Client config found, loading data.
[14:14:30] Starting GUI Server
[14:15:29] Completed 1%
[14:45:03] Completed 31%
[14:45:03] mdrun_gpu returned
[14:45:03] NANs detected on GPU
[14:45:03]
[14:45:03] Folding@home Core Shutdown: UNSTABLE_MACHINE
[14:45:05] CoreStatus = 7A (122)
[14:45:05] Sending work to server
[14:45:05] Project: 5760 (Run 5, Clone 21, Gen 108)
[14:45:05] - Read packet limit of 540015616... Set to 524286976.
[14:45:05] - Error: Could not get length of results file work/wuresults_03.dat
[14:45:05] - Error: Could not read unit 03 file. Removing from queue.
This WU doesn't fold well ... there's no data in the DB, and it fails at various % ... I hope it's just the WU and not my GPU ...
Re: Project: 5760 (Run 5, Clone 21, Gen 108) - UM at various %
This one has been completed successfully by another donor ...
