Windows 7 Folding?
Windows 7 Folding?
With the imminent release of windows 7 (beta) what are the expectations or plans for implementing Folding on this new platform
Being new I am not sure what to expect or when to expect it so can anyone guide me on this?
Re: Windows 7 Folding?
I tested FAH on Seven already :
- uniprocessor client works like a charm
- you need to install any SMP client as if you were using Vista (it has the same UAC)
- I didn't test the GPU client, but I guess it will work like with Vista (the driver models didn't change in the meantime)
Windows 7 - All Windows 7 comments go here.
I'm starting this thread now because we know some of you will try the Windows 7 open beta starting in 2 days, and you'll likely try folding on it. We make _NO_ claims that the client will work on Windows 7 yet, we haven't tried it.
Some things you can expect are that there will be little if any performance difference of the CPU Folding@home cores as we already make the hardware work as hard as it can, and GPU clients will need properly working drivers - which always take a while for a new OS.
All comments are welcome, but constructive comments will help us the most.
Mods please merge any other Win7 threads into this one from any windows forum.
Re: Windows 7 - All Windows 7 comments go here.
Merged the above two posts. Unfortunately, they inserted themselves prior to your posting, as they were posted before yours.
Just an FYI
Just an FYI
Information
The following words in your search query were ignored because they are too common words: windows 7.
-=MB=-
hackman2007
I tried installing SMP in Windows 7.
It failed and would not connect to the machine.
I disabled the firewall in case that was the root cause. Going to try some other things too. Probably related to UAC.
GPU2 client works like a champ.
Run the install.bat in Administrator account (in fact you can follow a Vista guide to install it under Seven).
I followed the Vista guide and this is what I get when I run intsall.bat as the administrator:toTOW wrote:Run the install.bat in Administrator account (in fact you can follow a Vista guide to install it under Seven).
Microsoft Windows [Version 6.1.7000]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Windows\system32>cd "c:\users\username"
c:\Users\username>cd folding
c:\Users\username\folding>install.bat
MPICH2 Process Manager, Argonne National Lab removed.
MPICH2 Process Manager, Argonne National Lab installed, but failed to start:
account (domain\user) [core_duo\username]:
password:
confirm password:
Password encrypted into the Registry.
Unable to connect to 'core_duo:8676',
sock error: generic socket failure, error stack:
MPIDU_Sock_post_connect(1228): unable to connect to core_duo on port 8676, exhausted all endpoints (errno -1)
MPIDU_Sock_post_connect(1275): unable to connect to core_duo on port 8676, No connection could be made because the target machine actively refused it. (errno 10061)
Press any key to continue . . .
c:\Users\username\folding>-
Strange ... it worked fine with me.
But I have already seen this error under Vista (I don't remember how to fix it) ... you should search on the forum for threads about it.
I got it working. The problem (I think) was due to a space in the current directory name. I moved it to C:\folding rather than in my user directory and it seems to be working fine now.
Tested Gpu folding on Windows 7 x64 vs Vista x64.
No problem installing W7 on a differen parision on my PC. Its automaticly sets up dual boot. No problems staring up old Vista or New W7.
RivaTuner and FahMon works fine. No problem innstalling multi GPU following Vitsa guide.
My 2 9800GX2's giving 20900ppd(4 clients) in W7 with 178.08 drivers. This is the same as in Vista on 180.60. No temp change.
Conclusion is that there is a loss of 300ppd pr. client in W7.(The differens between 178.08 and 180.60 is a loss of app. 300ppd, so if a had 180.60 in W7 I would have lost total 1200ppd.) Thats why I used the 178.06 on W7.
EDIT: Forgot one thing, W7 automaticly extends desktop to all 4 monitors
succesfully Folding on Windows 7
Just wanted to let you know that I've maneged to get folding running stable (apparently) on windows 7.
Havent seen any posts about this so I thought I'd give you the heads up.
Installed the current cuda drivers for vista and my 9800gtx is crunching away nicely.
system specs,
E6600 @3,6 cpu
650i Motherboard
2 GB ram
9800 Gtx vidcard
system specs,
E6600 @3,6 cpu
650i Motherboard
2 GB ram
9800 Gtx vidcard
[13:10:03] - Machine ID: 2
[13:10:03]
[13:10:03] Loaded queue successfully.
[13:10:03]
[13:10:03] + Processing work unit
[13:10:03] Core required: FahCore_11.exe
[13:10:03] Core found.
[13:10:03] Working on queue slot 01 [January 11 13:10:03 UTC]
[13:10:03] - Autosending finished units... [January 11 13:10:03 UTC]
[13:10:03] + Working ...
[13:10:03] - Calling '.\FahCore_11.exe -dir work/ -suffix 01 -cpu 90 -checkpoint 15 -verbose -lifeline 168 -version 623'
[13:10:03] Trying to send all finished work units
[13:10:03] + No unsent completed units remaining.
[13:10:03] - Autosend completed
[13:10:04]
[13:10:04] *------------------------------*
[13:10:04] Folding@Home GPU Core
[13:10:04] Version 1.22 (Mon Dec 1 10:38:13 PST 2008)
[13:10:04]
[13:10:04] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[13:10:04] Build host: amoeba
[13:10:04] Board Type: Nvidia
[13:10:04] Core :
[13:10:04] Preparing to commence simulation
[13:10:04] - Looking at optimizations...
[13:10:04] - Created dyn
[13:10:04] - Files status OK
[13:10:04] - Expanded 88330 -> 447228 (decompressed 506.3 percent)
[13:10:04] Called DecompressByteArray: compressed_data_size=88330 data_size=447228, decompressed_data_size=447228 diff=0
[13:10:04] - Digital signature verified
[13:10:04]
[13:10:04] Project: 5515 (Run 2, Clone 0, Gen 241)
[13:10:04]
[13:10:04] Assembly optimizations on if available.
[13:10:04] Entering M.D.
[13:10:11] Working on p5515_lam5w_330K_g91
[13:10:13] Client config found, loading data.
[13:10:13] Starting GUI Server
[13:12:29] Completed 1%
[13:14:44] Completed 2%
[13:16:58] Completed 3%
[13:19:11] Completed 4%
[13:21:30] Completed 5%
[13:23:50] Completed 6%
[13:26:12] Completed 7%
[13:28:30] Completed 8%
[13:30:50] Completed 9%
[13:33:07] Completed 10%
[13:35:25] Completed 11%
[13:37:54] Completed 12%
[13:40:30] Completed 13%
[13:43:11] Completed 14%
[13:45:28] Completed 15%
[13:47:47] Completed 16%
[13:50:01] Completed 17%
[13:52:17] Completed 18%
[13:54:30] Completed 19%
[13:56:43] Completed 20%
[13:58:56] Completed 21%
[14:01:09] Completed 22%
[14:03:34] Completed 23%
[14:06:16] Completed 24%
[14:08:59] Completed 25%
[14:11:39] Completed 26%
[14:15:19] Completed 27%
[14:17:32] Completed 28%
[14:19:45] Completed 29%
[14:21:58] Completed 30%
[14:24:11] Completed 31%
[14:26:23] Completed 32%
[14:28:36] Completed 33%
[14:30:49] Completed 34%
[14:33:02] Completed 35%
[14:35:15] Completed 36%
[14:37:28] Completed 37%
[14:39:40] Completed 38%
[14:41:53] Completed 39%
[14:44:06] Completed 40%
[14:46:19] Completed 41%
[14:48:32] Completed 42%
[14:50:45] Completed 43%
[14:52:57] Completed 44%
[14:55:10] Completed 45%
[14:57:23] Completed 46%
[14:59:36] Completed 47%
[15:01:49] Completed 48%
[15:04:02] Completed 49%
[15:06:14] Completed 50%
[15:08:27] Completed 51%
[15:10:40] Completed 52%
[15:12:53] Completed 53%
[15:15:06] Completed 54%
[15:17:19] Completed 55%
[15:19:45] Completed 56%
[15:22:13] Completed 57%
[15:24:55] Completed 58%
[15:27:11] Completed 59%
[15:29:26] Completed 60%
[15:31:45] Completed 61%
[15:34:05] Completed 62%
[15:36:25] Completed 63%
[15:38:44] Completed 64%
[15:41:04] Completed 65%
[15:43:24] Completed 66%
[15:45:44] Completed 67%
I have it installed with no problems at all. It seems to be about the same time folding projects as Vista is.
After 2 breakdown's in the last 24h I'm back on Vista. It just freezes. And no contact with PC is possible. Have to pull the plug to get started again.
Breakdowns while folding? Which client or clients? On what kind of hardware? The more info you post, the more helpful it would be. Thanks.BrgHW wrote:After 2 breakdown's in the last 24h I'm back on Vista. It just freezes. And no contact with PC is possible. Have to pull the plug to get started again.
DanGe
- Hardware configuration: 2018 Mac Mini / MacOS Catalina
3.2 GHz 6-Core Intel Core i7 - Location: California, United States
Uniprocessor console clients work well as services.
The systray clients (uniprocessor and GPU) do not appear to cleanly shut down as they usually do under Vista if you do not manually shut down the clients before shutting down the computer. No shutdown messages appear in the log of those systray clients, and FahMon gets confused with their statuses. Fortunately I have not lost any work yet.
GPU2 is also working well with the pre-release drivers with no noticeable decline in PPD compared to Vista's drivers that came with the CUDA 2.0 package.
Edit: SMP on MPICH works great too on x64
