Project: 5763 (Run 1, Clone 1, Gen 85)
Drugless
Post by Drugless »
Anyone else having a problem with this WU?
[10:42:11] Project: 5763 (Run 1, Clone 1, Gen 85)
[10:42:11]
[10:42:11] Assembly optimizations on if available.
[10:42:11] Entering M.D.
[10:42:18] Working on Protein
[10:42:20] Client config found, loading data.
[10:42:20] Starting GUI Server
[10:42:20] mdrun_gpu returned
[10:42:20] NANs detected on GPU
[10:42:20]
[10:42:20] Folding@home Core Shutdown: UNSTABLE_MACHINE
[10:42:23] CoreStatus = 7A (122)
[10:42:23] Sending work to server
[10:42:23] Project: 5763 (Run 1, Clone 1, Gen 85)
[10:42:23] - Read packet limit of 540015616... Set to 524286976.
[10:42:23] - Error: Could not get length of results file work/wuresults_09.dat
[10:42:23] - Error: Could not read unit 09 file. Removing from queue.
[10:42:23] EUE limit exceeded. Pausing 24 hours.
Folding Tools:8 X PS3's, 5 x GTX280,1 x 8800GS, 8 x 9800GX2 GPU's
Re: Project: 5763 (Run 1, Clone 1, Gen 85)
There's no data for this WU in the DB yet ...
If they all fail with the same error message, I'm not surprised. :(
Drugless
Post by Drugless »
toTOW wrote:There's no data for this WU in the DB yet ...
Thanks
Don't think I have a hardware problem since same GPU is completing all other WU's and haven't had this problem since the original 5506 issues.
Will wait and see if anyone else reports it.
Drugless
Post by Drugless »
Got it again. Same PC different GPU
[10:14:36] Project: 5763 (Run 1, Clone 1, Gen 85)
[10:14:36]
[10:14:36] Assembly optimizations on if available.
[10:14:36] Entering M.D.
[10:14:43] Working on Protein
[10:14:46] Client config found, loading data.
[10:14:46] Starting GUI Server
[10:14:46] mdrun_gpu returned
[10:14:46] NANs detected on GPU
[10:14:46]
[10:14:46] Folding@home Core Shutdown: UNSTABLE_MACHINE
[10:14:50] CoreStatus = 7A (122)
[10:14:50] Sending work to server
[10:14:50] Project: 5763 (Run 1, Clone 1, Gen 85)
[10:14:50] - Read packet limit of 540015616... Set to 524286976.
[10:14:50] - Error: Could not get length of results file work/wuresults_02.dat
[10:14:50] - Error: Could not read unit 02 file. Removing from queue.
[10:14:50] Trying to send all finished work units
[10:14:50] + No unsent completed units remaining.
Birdman86
Project: 5763 (Run 1, Clone 1, Gen 85) strikes again
Post by Birdman86 »
Now that WU had stopped my GeForce 8800 GT that hasn't had any EUE's for many weeks. I'm still running version 6.20 client.
[00:03:24] Completed 98%
[00:04:39] Completed 99%
[00:05:55] Completed 100%
[00:05:55] Successful run
[00:05:55] DynamicWrapper: Finished Work Unit: sleep=10000
[00:06:05] Reserved 79068 bytes for xtc file; Cosm status=0
[00:06:05] Allocated 79068 bytes for xtc file
[00:06:05] - Reading up to 79068 from "work/wudata_05.xtc": Read 79068
[00:06:05] Read 79068 bytes from xtc file; available packet space=786351396
[00:06:05] xtc file hash check passed.
[00:06:05] Reserved 23472 23472 786351396 bytes for arc file=<work/wudata_05.trr> Cosm status=0
[00:06:05] Allocated 23472 bytes for arc file
[00:06:05] - Reading up to 23472 from "work/wudata_05.trr": Read 23472
[00:06:05] Read 23472 bytes from arc file; available packet space=786327924
[00:06:05] trr file hash check passed.
[00:06:05] Allocated 560 bytes for edr file
[00:06:05] Read bedfile
[00:06:05] edr file hash check passed.
[00:06:05] Allocated 10566 bytes for logfile
[00:06:05] Read logfile
[00:06:05] GuardedRun: success in DynamicWrapper
[00:06:05] GuardedRun: done
[00:06:05] Run: GuardedRun completed.
[00:06:07] - Writing 114178 bytes of core data to disk...
[00:06:07] Done: 113666 -> 107717 (compressed to 94.7 percent)
[00:06:07]   ... Done.
[00:06:07] - Shutting down core
[00:06:07]
[00:06:07] Folding@home Core Shutdown: FINISHED_UNIT
[00:06:11] CoreStatus = 64 (100)
[00:06:11] Sending work to server
[00:06:11] Project: 5762 (Run 6, Clone 17, Gen 108)
[00:06:11] - Read packet limit of 540015616... Set to 524286976.
[00:06:11] + Attempting to send results [January 13 00:06:11 UTC]
[00:06:14] + Results successfully sent
[00:06:14] Thank you for your contribution to Folding@Home.
[00:06:14] + Number of Units Completed: 886
[00:06:18] - Preparing to get new work unit...
[00:06:18] + Attempting to get work packet
[00:06:18] - Connecting to assignment server
[00:06:20] - Successful: assigned to (171.64.65.106).
[00:06:20] + News From Folding@Home: GPU folding beta
[00:06:20] Loaded queue successfully.
[00:06:22] + Closed connections
[00:06:22]
[00:06:22] + Processing work unit
[00:06:22] Core required: FahCore_11.exe
[00:06:22] Core found.
[00:06:22] Working on queue slot 06 [January 13 00:06:22 UTC]
[00:06:22] + Working ...
[00:06:23]
[00:06:23] *------------------------------*
[00:06:23] Folding@Home GPU Core - Beta
[00:06:23] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[00:06:23]
[00:06:23] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[00:06:23] Build host: amoeba
[00:06:23] Board Type: Nvidia
[00:06:23] Core      :
[00:06:23] Preparing to commence simulation
[00:06:23] - Looking at optimizations...
[00:06:23] - Created dyn
[00:06:23] - Files status OK
[00:06:23] - Expanded 68696 -> 357580 (decompressed 520.5 percent)
[00:06:23] Called DecompressByteArray: compressed_data_size=68696 data_size=357580, decompressed_data_size=357580 diff=0
[00:06:23] - Digital signature verified
[00:06:23]
[00:06:23] Project: 5763 (Run 1, Clone 1, Gen 85)
[00:06:23]
[00:06:23] Assembly optimizations on if available.
[00:06:23] Entering M.D.
[00:06:30] Working on Protein
[00:06:31] Client config found, loading data.
[00:06:31] mdrun_gpu returned
[00:06:31] NANs detected on GPU
[00:06:31]
[00:06:31] Folding@home Core Shutdown: UNSTABLE_MACHINE
[00:06:35] CoreStatus = 7A (122)
[00:06:35] Sending work to server
[00:06:35] Project: 5763 (Run 1, Clone 1, Gen 85)
[00:06:35] - Read packet limit of 540015616... Set to 524286976.
[00:06:35] - Error: Could not get length of results file work/wuresults_06.dat
[00:06:35] - Error: Could not read unit 06 file. Removing from queue.
[00:06:35] - Preparing to get new work unit...
[00:06:35] + Attempting to get work packet
[00:06:35] - Connecting to assignment server
[00:06:36] - Successful: assigned to (171.64.65.106).
[00:06:36] + News From Folding@Home: GPU folding beta
[00:06:36] Loaded queue successfully.
[00:06:39] + Closed connections
[00:06:44]
[00:06:44] + Processing work unit
[00:06:44] Core required: FahCore_11.exe
[00:06:44] Core found.
[00:06:44] Working on queue slot 07 [January 13 00:06:44 UTC]
[00:06:44] + Working ...
[00:06:44]
[00:06:44] *------------------------------*
[00:06:44] Folding@Home GPU Core - Beta
[00:06:44] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[00:06:44]
[00:06:44] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[00:06:44] Build host: amoeba
[00:06:44] Board Type: Nvidia
[00:06:44] Core      :
[00:06:44] Preparing to commence simulation
[00:06:44] - Looking at optimizations...
[00:06:44] - Created dyn
[00:06:44] - Files status OK
[00:06:44] - Expanded 68696 -> 357580 (decompressed 520.5 percent)
[00:06:44] Called DecompressByteArray: compressed_data_size=68696 data_size=357580, decompressed_data_size=357580 diff=0
[00:06:44] - Digital signature verified
[00:06:44]
[00:06:44] Project: 5763 (Run 1, Clone 1, Gen 85)
[00:06:44]
[00:06:44] Assembly optimizations on if available.
[00:06:44] Entering M.D.
[00:06:51] Working on Protein
[00:06:52] Client config found, loading data.
[00:06:52] mdrun_gpu returned
[00:06:52] NANs detected on GPU
[00:06:52]
[00:06:52] Folding@home Core Shutdown: UNSTABLE_MACHINE
[00:06:56] CoreStatus = 7A (122)
[00:06:56] Sending work to server
[00:06:56] Project: 5763 (Run 1, Clone 1, Gen 85)
[00:06:56] - Read packet limit of 540015616... Set to 524286976.
[00:06:56] - Error: Could not get length of results file work/wuresults_07.dat
[00:06:56] - Error: Could not read unit 07 file. Removing from queue.
[00:06:56] - Preparing to get new work unit...
[00:06:56] + Attempting to get work packet
[00:06:56] - Connecting to assignment server
[00:06:57] - Successful: assigned to (171.64.65.106).
[00:06:57] + News From Folding@Home: GPU folding beta
[00:06:57] Loaded queue successfully.
[00:07:00] + Closed connections
[00:07:05]
[00:07:05] + Processing work unit
[00:07:05] Core required: FahCore_11.exe
[00:07:05] Core found.
[00:07:05] Working on queue slot 08 [January 13 00:07:05 UTC]
[00:07:05] + Working ...
[00:07:05]
[00:07:05] *------------------------------*
[00:07:05] Folding@Home GPU Core - Beta
[00:07:05] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[00:07:05]
[00:07:05] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[00:07:05] Build host: amoeba
[00:07:05] Board Type: Nvidia
[00:07:05] Core      :
[00:07:05] Preparing to commence simulation
[00:07:05] - Looking at optimizations...
[00:07:05] - Created dyn
[00:07:05] - Files status OK
[00:07:05] - Expanded 68696 -> 357580 (decompressed 520.5 percent)
[00:07:05] Called DecompressByteArray: compressed_data_size=68696 data_size=357580, decompressed_data_size=357580 diff=0
[00:07:05] - Digital signature verified
[00:07:05]
[00:07:05] Project: 5763 (Run 1, Clone 1, Gen 85)
[00:07:05]
[00:07:05] Assembly optimizations on if available.
[00:07:05] Entering M.D.
[00:07:13] Working on Protein
[00:07:14] Client config found, loading data.
[00:07:14] mdrun_gpu returned
[00:07:14] NANs detected on GPU
[00:07:14]
[00:07:14] Folding@home Core Shutdown: UNSTABLE_MACHINE
[00:07:18] CoreStatus = 7A (122)
[00:07:18] Sending work to server
[00:07:18] Project: 5763 (Run 1, Clone 1, Gen 85)
[00:07:18] - Read packet limit of 540015616... Set to 524286976.
[00:07:18] - Error: Could not get length of results file work/wuresults_08.dat
[00:07:18] - Error: Could not read unit 08 file. Removing from queue.
[00:07:18] - Preparing to get new work unit...
[00:07:18] + Attempting to get work packet
[00:07:18] - Connecting to assignment server
[00:07:19] - Successful: assigned to (171.64.65.106).
[00:07:19] + News From Folding@Home: GPU folding beta
[00:07:19] Loaded queue successfully.
[00:07:21] + Closed connections
[00:07:26]
[00:07:26] + Processing work unit
[00:07:26] Core required: FahCore_11.exe
[00:07:26] Core found.
[00:07:26] Working on queue slot 09 [January 13 00:07:26 UTC]
[00:07:26] + Working ...
[00:07:27]
[00:07:27] *------------------------------*
[00:07:27] Folding@Home GPU Core - Beta
[00:07:27] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[00:07:27]
[00:07:27] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[00:07:27] Build host: amoeba
[00:07:27] Board Type: Nvidia
[00:07:27] Core      :
[00:07:27] Preparing to commence simulation
[00:07:27] - Looking at optimizations...
[00:07:27] - Created dyn
[00:07:27] - Files status OK
[00:07:27] - Expanded 68696 -> 357580 (decompressed 520.5 percent)
[00:07:27] Called DecompressByteArray: compressed_data_size=68696 data_size=357580, decompressed_data_size=357580 diff=0
[00:07:27] - Digital signature verified
[00:07:27]
[00:07:27] Project: 5763 (Run 1, Clone 1, Gen 85)
[00:07:27]
[00:07:27] Assembly optimizations on if available.
[00:07:27] Entering M.D.
[00:07:34] Working on Protein
[00:07:35] Client config found, loading data.
[00:07:35] Starting GUI Server
[00:07:35] mdrun_gpu returned
[00:07:35] NANs detected on GPU
[00:07:35]
[00:07:35] Folding@home Core Shutdown: UNSTABLE_MACHINE
[00:07:39] CoreStatus = 7A (122)
[00:07:39] Sending work to server
[00:07:39] Project: 5763 (Run 1, Clone 1, Gen 85)
[00:07:39] - Read packet limit of 540015616... Set to 524286976.
[00:07:39] - Error: Could not get length of results file work/wuresults_09.dat
[00:07:39] - Error: Could not read unit 09 file. Removing from queue.
[00:07:39] - Preparing to get new work unit...
[00:07:39] + Attempting to get work packet
[00:07:39] - Connecting to assignment server
[00:07:40] - Successful: assigned to (171.64.65.106).
[00:07:40] + News From Folding@Home: GPU folding beta
[00:07:40] Loaded queue successfully.
[00:07:44] + Closed connections
[00:07:49]
[00:07:49] + Processing work unit
[00:07:49] Core required: FahCore_11.exe
[00:07:49] Core found.
[00:07:49] Working on queue slot 00 [January 13 00:07:49 UTC]
[00:07:49] + Working ...
[00:07:49]
[00:07:49] *------------------------------*
[00:07:49] Folding@Home GPU Core - Beta
[00:07:49] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[00:07:49]
[00:07:49] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[00:07:49] Build host: amoeba
[00:07:49] Board Type: Nvidia
[00:07:49] Core      :
[00:07:49] Preparing to commence simulation
[00:07:49] - Looking at optimizations...
[00:07:49] - Created dyn
[00:07:49] - Files status OK
[00:07:49] - Expanded 68696 -> 357580 (decompressed 520.5 percent)
[00:07:49] Called DecompressByteArray: compressed_data_size=68696 data_size=357580, decompressed_data_size=357580 diff=0
[00:07:49] - Digital signature verified
[00:07:49]
[00:07:49] Project: 5763 (Run 1, Clone 1, Gen 85)
[00:07:49]
[00:07:49] Assembly optimizations on if available.
[00:07:49] Entering M.D.
[00:07:56] Working on Protein
[00:07:58] Client config found, loading data.
[00:07:58] mdrun_gpu returned
[00:07:58] NANs detected on GPU
[00:07:58]
[00:07:58] Folding@home Core Shutdown: UNSTABLE_MACHINE
[00:08:01] CoreStatus = 7A (122)
[00:08:01] Sending work to server
[00:08:01] Project: 5763 (Run 1, Clone 1, Gen 85)
[00:08:01] - Read packet limit of 540015616... Set to 524286976.
[00:08:01] - Error: Could not get length of results file work/wuresults_00.dat
[00:08:01] - Error: Could not read unit 00 file. Removing from queue.
[00:08:01] EUE limit exceeded. Pausing 24 hours.
Now I've got another WU and folding it without problems, but I lost one hour before I noticed the problem.
Should I update to version 6.23 to avoid those errors or is this a bad WU?
Why did I got the same WU so many times that my client stopped?
Wouldn't it be easy to prevent these unnecessary client stops simply by giving the same WU only three times in a row.
I guess the time has come to mark this WU as a bad one (there are 3 similar report in the DB too).
Drugless
Post by Drugless »
Got it again so not taken off yet.
[03:18:03] Project: 5763 (Run 1, Clone 1, Gen 85)
[03:18:03]
[03:18:03] Assembly optimizations on if available.
[03:18:03] Entering M.D.
[03:18:09] Working on Protein
[03:18:11] Client config found, loading data.
[03:18:11] Starting GUI Server
[03:18:12] mdrun_gpu returned
[03:18:12] NANs detected on GPU
[03:18:12]
[03:18:12] Folding@home Core Shutdown: UNSTABLE_MACHINE
[03:18:15] CoreStatus = 7A (122)
[03:18:15] Sending work to server
[03:18:15] Project: 5763 (Run 1, Clone 1, Gen 85)
[03:18:15] - Read packet limit of 540015616... Set to 524286976.
[03:18:15] - Error: Could not get length of results file work/wuresults_07.dat
[03:18:15] - Error: Could not read unit 07 file. Removing from queue.
[03:18:15] EUE limit exceeded. Pausing 24 hours.
