Team Editing Problem(already searched)
I just starting running Folding@Home on my PS3. I figure since I can't enter a passkey that I should make my own team to help verify the WU's I pump out are mine. I noticed a typo in one of the urls I put in. Where do I find the page to login and change things on my team. Thanks.
Re: Team Editing Problem(already searched)
Thanks, I changed it but I have to wait til the servers done its update to see if it took effect. I'll post if it worked.
Also were those links on the folding site cuz I spent about an hour looking for them and only found the new team one.
Thanks.
Thanks.
Also is what I am doing good enough since I can't use a passkey in the PS3 client??
A passkey is not required, so yes, what you're doing is good enough.
I expect that some future version of the PS3 client will accept a passkey, but I don't really know where that is on the list of planned changes.
one more quick question if someone joins my team and for some reason i want to remove them how do i do this?
You can't.
