Project: 4103 has NutcrackerVirus [False Positive]
forked_at_fark
Post by forked_at_fark »
Hi,
I never thought I would see something like this.
Here's the log.
[19:26:58] Project: 4103 (Run 31, Clone 14, Gen 30)
[19:26:58]
[19:26:58] Assembly optimizations on if available.
[19:26:58] Entering M.D.
[19:27:04] Protein: p4103_wwmut_folded_Amber03_Native
[19:27:04]
[19:27:04] Writing local files
[19:27:04] Extra SSE boost OK.
[19:27:04] Completed 0 out of 1500000 steps (0%)
[19:42:51] Writing local files
[19:42:51] Completed 15000 out of 1500000 steps (1%)
[19:58:42] Writing local files
[19:58:42] Completed 30000 out of 1500000 steps (2%)
[20:14:28] Writing local files
[20:14:28] Completed 45000 out of 1500000 steps (3%)
[20:30:15] Writing local files
[20:30:15] Completed 60000 out of 1500000 steps (4%)
[20:46:00] Writing local files
[20:46:00] Completed 75000 out of 1500000 steps (5%)
[21:01:54] Writing local files
[21:01:54] Completed 90000 out of 1500000 steps (6%)
[21:34:04] Writing local files
[21:34:04] Completed 105000 out of 1500000 steps (7%)
Ivoshiee
Re: Project: 4103 (Run 31, Clone 14, Gen 30) has NutcrackerVirus
Post by Ivoshiee »
I've seen "it" before, just a false positive.
forked_at_fark
Oh, nevermind.
I guess I should have done a forum search first.
I didn't know that there was a common problem of false positives with Avast.
I moved it to the chest.
I hope that doesn't mess up this work unit.
So, I should just tell it to ignore it next time?
I can be assured that there will never be any real viruses?
Put your FAH folder in your AV software trusted zone.
Ivoshiee
Post by Ivoshiee »
forked_at_fark wrote:Oh, nevermind.
It is messed up and you are likely lost that WU already. Do not worry, you'll get another one.
FAH WU files are data files and will not be executed. If indeed some code does attach to any of these files then it will not get a chance to run.
Also, at some level the WU data corruption caused by "virus attachment" will dump the WU itself.
forked_at_fark
Thanks for the answers, everyone.
Will try to fix my Avast.
