Project: 3064 (Run 2, Clone 138, Gen 34)
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
EUE. Fortunately, did two units in between, so I'm not totally despairing. ;-)
[04:42:47] + Closed connections
[04:42:47]
[04:42:47] + Processing work unit
[04:42:47] Work type a1 not eligible for variable processors
[04:42:47] Core required: FahCore_a1.exe
[04:42:47] Core found.
[04:42:47] Using generic mpiexec calls
[04:42:47] Working on queue slot 06 [January 3 04:42:47 UTC]
[04:42:47] + Working ...
[04:42:47] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 06 -checkpoint 15 -verbose -lifeline 856 -version 623'
[04:42:48]
[04:42:48] *------------------------------*
[04:42:48] Folding@Home Gromacs SMP Core
[04:42:48] Version 1.74 (March 10, 2007)
[04:42:48]
[04:42:48] Preparing to commence simulation
[04:42:48] - Looking at optimizations...
[04:42:48] - Created dyn
[04:42:48] - Files status OK
[04:42:48] - Expanded 609854 -> 3263429 (decompressed 535.1 percent)
[04:42:48] - Starting from initial work packet
[04:42:48]
[04:42:48] Project: 3064 (Run 2, Clone 138, Gen 34)
[04:42:48]
[04:42:48] Assembly optimizations on if available.
[04:42:48] Entering M.D.
[04:43:05] al work pa- Starting from initial work packet
[04:43:05]
[04:43:05] Project: 30Entering M.D.
[04:43:05] ne 138, Gen 34)
[04:43:05]
[04:43:05] Entering M.D.
[04:43:11] Rejecting checkpoint
[04:43:12] a SSE boost OK.
[04:43:12] ambda5_2003Extra SSE boost OK.
[04:43:12]
[04:43:12] Extra SSE boost OK.
[04:43:12] Writing local files
[04:43:12] Completed 0 out of 5000000 steps  (0 percent)
[04:53:52] Writing local files
[04:53:52] Completed 50000 out of 5000000 steps  (1 percent)
            {snip}
[08:49:34] Writing local files
[08:49:34] Completed 1150000 out of 5000000 steps  (23 percent)
[08:57:50] Gromacs cannot continue further.
[08:57:50] Going to send back what have done.
[08:57:50] logfile size: 37978
[08:57:50] - Writing 38514 bytes of core data to disk...
[08:57:50]   ... Done.
[08:57:50] - Failed to delete work/wudata_06.sas
[08:57:50] - Failed to delete work/wudata_06.goe
[08:57:50] - Failed to delete work/wudata_06.pdo
[08:57:50] Warning:  check for stray files
[08:59:50]
[08:59:50] Folding@home Core Shutdown: EARLY_UNIT_END
[08:59:50]
[08:59:54] CoreStatus = 7B (123)
[08:59:54] Sending work to server
[08:59:54] Project: 3064 (Run 2, Clone 138, Gen 34)
[08:59:54] + Attempting to send results [January 3 08:59:54 UTC]
[08:59:54] - Reading file work/wuresults_06.dat from core
[08:59:54]   (Read 38514 bytes from disk)
[08:59:54] Connecting to http://171.64.65.63:8080/
[08:59:54] Posted data.
[08:59:54] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[08:59:54] - Uploaded at ~77 kB/s
[08:59:54] - Averaged speed for that direction ~99 kB/s
[08:59:54] + Results successfully sent
[08:59:54] Thank you for your contribution to Folding@Home.
Re: Project: 3064 (Run 2, Clone 138, Gen 34)
There are no other reports for this WU yet ...
anko1
Post by anko1 »
Thanks for checking on my units, toTOW.
