Problem with a result file/qfix
John Naylor
Hardware configuration: Q9450 OC @ 3.2GHz (Win7 Home Premium) - SMP2
i5-3750k @ 3.8GHz (Win7 Pro) - SMP2
Post by John Naylor »
I just spotted that I have what I suspect is an unreturned results file that was not showing up in my queue, so I ran qfix to add it back to the queue so I could send it. However qfix reports the PRCG as 0, 0, 0, 0 so it cannot reattach it (the PRCG it quotes as in the queue is the correct PRCG). The log has long since been overwritten as the unit was finished on December 16th, so can someone please check if that unit was returned and if not, how can I get it back into my queue?
Microsoft Windows [Version 6.0.6001]
Copyright (c) 2006 Microsoft Corporation.  All rights reserved.
C:\Users\John>cd C:\Users\John\FAH\1
C:\Users\John\FAH\1>qfix
entry 3, status 0, address 171.65.103.68:8080
entry 4, status 0, address 171.65.103.162:8080
entry 5, status 0, address 171.65.103.68:8080
entry 6, status 0, address 171.65.103.160:8080
entry 7, status 0, address 171.65.103.160:8080
entry 8, status 0, address 171.67.108.12:8080
entry 9, status 0, address 171.65.103.160:8080
entry 0, status 0, address 171.65.103.160:8080
  Found results <work\wuresults_00.dat>: proj 0, run 0, clone 0, gen 0
   -- queue entry: proj 2443, run 0, clone 11, gen 1
   -- doesn't match queue entry
entry 1, status 0, address 171.65.103.68:8080
entry 2, status 1, address 171.65.103.160:8080
File is OK
Folding whatever I'm sent since March 2006 :) Beta testing since October 2006. www.FAH-Addict.net Administrator since August 2009.
Re: Problem with a result file/qfix
When qfix says that the wuresults is for PRCG=0 0 0 0 it means that the data in that file is corrupt and there is/was no way to use it.
That particular WU has been completed by three people. You happen to be one of them.
Hi John_Naylor (team 35947),
Your WU (P2443 R0 C11 G1) was added to the stats database on 2008-12-16 14:38:49 for 2435 points of credit.
John Naylor
ah thanks a lot. Happy New Year!
