Project: 2665 (Run 0, Clone 568, Gen 74)
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
EUE. Simulation instability. This is using Windows SMP console, v. 6023 Beta R1.
[06:15:13] + Closed connections
[06:15:13]
[06:15:13] + Processing work unit
[06:15:13] Work type a1 not eligible for variable processors
[06:15:13] Core required: FahCore_a1.exe
[06:15:13] Core found.
[06:15:13] Using generic mpiexec calls
[06:15:13] Working on queue slot 07 [December 27 06:15:13 UTC]
[06:15:13] + Working ...
[06:15:13] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 07 -checkpoint 15 -verbose -lifeline 856 -version 623'
[06:15:13]
[06:15:13] *------------------------------*
[06:15:13] Folding@Home Gromacs SMP Core
[06:15:13] Version 1.74 (March 10, 2007)
[06:15:13]
[06:15:13] Preparing to commence simulation
[06:15:13] - Ensuring status. Please wait.
[06:15:18] - Starting from initial work packet
[06:15:18]
[06:15:18] Project: 2665 (Run 0, Clone 568, Gen 74)
[06:15:18]
[06:15:19] Assembly optimizations on if available.
[06:15:19] Entering M.D.
[06:15:40] al work packet
[06:15:40]
[06:15:40] Project: 2665 (Run 0, Clone 568, Gen 74)
[06:15:40]
[06:15:41] Entering M.D.
[06:15:41] ne 568, Gen 74)
[06:15:41]
[06:15:42] Entering M.D.
[06:15:48] Rejecting checkpoint
[06:15:50] Protein: HGG in water
[06:15:50] Writing local files
[06:15:58] Extra SSE boost OK.
[06:15:58] Writing local files
[06:15:58] Completed 0 out of 250000 steps  (0 percent)
[06:30:59] Timered checkpoint triggered.
[06:31:17] Writing local files
[06:31:17] Completed 2500 out of 250000 steps  (1 percent)
     {snip}
[07:32:37] Writing local files
[07:32:38] Completed 12500 out of 250000 steps  (5 percent)
[07:36:09] Warning:  long 1-4 interactions
[07:36:09] ing:  check for stray files
[07:36:09] er[20])
[07:36:09]
[07:36:09] Simulation instability has been encountered. The run has entered a
[07:36:09]   state from which no further progress can be made.
[07:36:09] This may be the correct result of the simulation, however if you
[07:36:09]   often see other project units terminating early like this
[07:36:09]   too, you may wish to check the stability of your computer (issues
[07:36:09]   such as high temperature, overclocking, etc.).
[07:36:09] Going to send back what have done.
[07:36:09] logfile size: 18841
[07:36:09] - Writing 19391 bytes of core data to disk...
[07:36:09]   ... Done.
[07:38:09]
[07:38:09] Folding@home Core Shutdown: EARLY_UNIT_END
[07:38:09]
[07:38:13] CoreStatus = 7B (123)
[07:38:13] Sending work to server
[07:38:13] Project: 2665 (Run 0, Clone 568, Gen 74)
[07:38:13] + Attempting to send results [December 27 07:38:13 UTC]
[07:38:13] - Reading file work/wuresults_07.dat from core
[07:38:13]   (Read 19391 bytes from disk)
[07:38:13] Connecting to http://171.64.65.64:8080/
[07:38:14] Posted data.
[07:38:14] Initial: 0000; - Uploaded at ~19 kB/s
[07:38:14] - Averaged speed for that direction ~43 kB/s
[07:38:14] + Results successfully sent
[07:38:14] Thank you for your contribution to Folding@Home.
Re: Project: 2665 (Run 0, Clone 568, Gen 74)
There are five similar reports, and 3 at the same progress ... this is probably a simulation instability caused by the WU.
anko1
Post by anko1 »
Thanks for checking on my units, toTOW. Happy New Year!
