171.65.103.160 in Reject Mode
Cajun_Don
Post by Cajun_Don »
Folding@Home server status
Report initiated on Sun Dec 28 01:20:20 PST 2008.
171.65.103.160 classic VSPMF93 ppetrone full Reject 1.45 0 6 8800 2521 15 4.04 37194 37194 411248 - 35 - - 3 0 8 8 1 171.64.122.76
Have a great day.
Xilikon
Re: 171.65.103.160 in Reject Mode
Post by Xilikon »
Add me in the crowd unable to upload units to that server. The backup server (171.67.108.17) is also unable to receive uploads.
VijayPande
Pande Group Member
Post by VijayPande »
I see the issue and have resolved it.
Prof. Vijay Pande, PhD
Chair, Biophysics
Stanford University
The server is up, but for some reason, it drops connection before my WU get through (with 100 ko/sec upload speed, it should last about 6 mins 36) ... the server is not particularly overloaded (80-100 netload).
[10:34:30] + Attempting to send results [March 2 10:34:30 UTC]
[10:34:30] - Reading file work/wuresults_08.dat from core
[10:34:30]   (Read 40733593 bytes from disk)
[10:34:30] Connecting to http://171.65.103.160:8080/
[10:39:29] - Couldn't send HTTP request to server
[10:39:29] + Could not connect to Work Server (results)
[10:39:29]     (171.65.103.160:8080)
[10:39:29] + Retrying using alternative port
[10:39:29] Connecting to http://171.65.103.160:80/
[10:40:35] - Couldn't send HTTP request to server
[10:40:35] + Could not connect to Work Server (results)
[10:40:35]     (171.65.103.160:80)
[10:40:35] - Error: Could not transmit unit 08 (completed March 2) to work server.
[10:40:35] - 1 failed uploads of this unit.
[10:40:35]   Keeping unit 08 in queue.
[10:40:35] Trying to send all finished work units
[10:40:35] Project: 2443 (Run 8, Clone 16, Gen 4)
[10:40:35] - Read packet limit of 540015616... Set to 524286976.
[10:40:35] + Attempting to send results [March 2 10:40:35 UTC]
[10:40:35] - Reading file work/wuresults_08.dat from core
[10:40:35]   (Read 40733593 bytes from disk)
[10:40:35] Connecting to http://171.65.103.160:8080/
[10:45:35] - Couldn't send HTTP request to server
[10:45:35] + Could not connect to Work Server (results)
[10:45:35]     (171.65.103.160:8080)
[10:45:35] + Retrying using alternative port
[10:45:35] Connecting to http://171.65.103.160:80/
[10:47:56] - Couldn't send HTTP request to server
[10:47:56] + Could not connect to Work Server (results)
[10:47:56]     (171.65.103.160:80)
[10:47:56] - Error: Could not transmit unit 08 (completed March 2) to work server.
[10:47:56] - 2 failed uploads of this unit.
[10:47:56] - Read packet limit of 540015616... Set to 524286976.
[10:47:56] + Attempting to send results [March 2 10:47:56 UTC]
[10:47:56] - Reading file work/wuresults_08.dat from core
[10:47:56]   (Read 40733593 bytes from disk)
[10:47:56] Connecting to http://171.67.108.17:8080/
[10:47:57] - Couldn't send HTTP request to server
[10:47:57] + Could not connect to Work Server (results)
[10:47:57]     (171.67.108.17:8080)
[10:47:57] + Retrying using alternative port
[10:47:57] Connecting to http://171.67.108.17:80/
[10:47:58] - Couldn't send HTTP request to server
[10:47:58]   (Got status 503)
[10:47:58] + Could not connect to Work Server (results)
[10:47:58]     (171.67.108.17:80)
[10:47:58]   Could not transmit unit 08 to Collection server; keeping in queue.
[10:47:58] + Sent 0 of 1 completed units to the server
[10:47:58] - Preparing to get new work unit...
[10:47:58] + Attempting to get work packet
[10:47:58] - Will indicate memory of 1023 MB
[10:47:58] - Detect CPU. Vendor: AuthenticAMD, Family: 6, Model: 8, Stepping: 1
[10:47:58] - Connecting to assignment server
[10:47:58] Connecting to http://assign.stanford.edu:8080/
[10:47:59] Posted data.
[10:47:59] Initial: 41AB; - Successful: assigned to (171.65.103.160).
[10:47:59] + News From Folding@Home: Welcome to Folding@Home
[10:48:00] Loaded queue successfully.
[10:48:00] Connecting to http://171.65.103.160:8080/
[10:48:06] Posted data.
[10:48:06] Initial: 0000; - Receiving payload (expected size: 2218768)
[10:48:14] - Downloaded at ~270 kB/s
[10:48:14] - Averaged speed for that direction ~162 kB/s
[10:48:14] + Received work.
[10:48:15] Trying to send all finished work units
[10:48:15] Project: 2443 (Run 8, Clone 16, Gen 4)
[10:48:15] - Read packet limit of 540015616... Set to 524286976.
[10:48:15] + Attempting to send results [March 2 10:48:15 UTC]
[10:48:15] - Reading file work/wuresults_08.dat from core
[10:48:15]   (Read 40733593 bytes from disk)
[10:48:15] Connecting to http://171.65.103.160:8080/
[10:53:21] - Couldn't send HTTP request to server
[10:53:21] + Could not connect to Work Server (results)
[10:53:21]     (171.65.103.160:8080)
[10:53:21] + Retrying using alternative port
[10:53:22] Connecting to http://171.65.103.160:80/
[10:53:23] - Couldn't send HTTP request to server
[10:53:23] + Could not connect to Work Server (results)
[10:53:23]     (171.65.103.160:80)
[10:53:23] - Error: Could not transmit unit 08 (completed March 2) to work server.
[10:53:23] - 3 failed uploads of this unit.
[10:53:23] - Read packet limit of 540015616... Set to 524286976.
[10:53:23] + Attempting to send results [March 2 10:53:23 UTC]
[10:53:23] - Reading file work/wuresults_08.dat from core
[10:53:23]   (Read 40733593 bytes from disk)
[10:53:23] Connecting to http://171.67.108.17:8080/
[10:53:24] - Couldn't send HTTP request to server
[10:53:24]   (Got status 503)
[10:53:24] + Could not connect to Work Server (results)
[10:53:24]     (171.67.108.17:8080)
[10:53:24] + Retrying using alternative port
[10:53:24] Connecting to http://171.67.108.17:80/
[10:53:24]     (171.67.108.17:80)
[10:53:24]   Could not transmit unit 08 to Collection server; keeping in queue.
[10:53:24] + Sent 0 of 1 completed units to the server
[10:53:24] + Closed connections
I restarted the client to try to send with direct RJ45 connection to the network (instead of wifi), and it's even worse (it drops connection earlier in the transfert) :
[11:22:01] Attempting to return result(s) to server...
[11:22:01] Trying to send all finished work units
[11:22:01] Project: 2443 (Run 8, Clone 16, Gen 4)
[11:22:01] - Read packet limit of 540015616... Set to 524286976.
[11:22:01] + Attempting to send results [March 2 11:22:01 UTC]
[11:22:01] - Reading file work/wuresults_08.dat from core
[11:22:02]   (Read 40733593 bytes from disk)
[11:22:02] Connecting to http://171.65.103.160:8080/
[11:24:50] - Couldn't send HTTP request to server
[11:24:50] + Could not connect to Work Server (results)
[11:24:50]     (171.65.103.160:8080)
[11:24:50] + Retrying using alternative port
[11:24:50] Connecting to http://171.65.103.160:80/
[11:24:58] - Couldn't send HTTP request to server
[11:24:58] + Could not connect to Work Server (results)
[11:24:58]     (171.65.103.160:80)
[11:24:58] - Error: Could not transmit unit 08 (completed March 2) to work server.
[11:24:58] - 4 failed uploads of this unit.
[11:24:58] - Read packet limit of 540015616... Set to 524286976.
[11:24:58] + Attempting to send results [March 2 11:24:58 UTC]
[11:24:58] - Reading file work/wuresults_08.dat from core
[11:24:59]   (Read 40733593 bytes from disk)
[11:24:59] Connecting to http://171.67.108.17:8080/
[11:24:59] - Couldn't send HTTP request to server
[11:24:59]   (Got status 503)
[11:24:59] + Could not connect to Work Server (results)
[11:25:00]     (171.67.108.17:8080)
[11:25:00] + Retrying using alternative port
[11:25:00] Connecting to http://171.67.108.17:80/
[11:25:00] - Couldn't send HTTP request to server
[11:25:00]   (Got status 503)
[11:25:00] + Could not connect to Work Server (results)
[11:25:00]     (171.67.108.17:80)
[11:25:00]   Could not transmit unit 08 to Collection server; keeping in queue.
[11:25:00] + Sent 0 of 1 completed units to the server
[11:25:00] - Failed to send all units to server
I had the same troubles with previous WU with this server too, and it finally was sent with one of the automatic send processes a day or two later.
Here is a screen of my network monitoring tool :
And the associated log :
[17:35:18] - Autosending finished units... [March 2 17:35:18 UTC]
[17:35:18] Trying to send all finished work units
[17:35:18] Project: 2443 (Run 8, Clone 16, Gen 4)
[17:35:18] - Read packet limit of 540015616... Set to 524286976.
[17:35:18] + Attempting to send results [March 2 17:35:18 UTC]
[17:35:18] - Reading file work/wuresults_08.dat from core
[17:35:18]   (Read 40733593 bytes from disk)
[17:35:18] Connecting to http://171.65.103.160:8080/
[17:39:55] - Couldn't send HTTP request to server
[17:39:55] + Could not connect to Work Server (results)
[17:39:55]     (171.65.103.160:8080)
Then it tries again on alternative port, with the same bahavior :
[17:39:55] + Retrying using alternative port
[17:39:55] Connecting to http://171.65.103.160:80/
[17:42:02] - Couldn't send HTTP request to server
[17:42:02] + Could not connect to Work Server (results)
[17:42:02]     (171.65.103.160:80)
[17:42:02] - Error: Could not transmit unit 08 (completed March 2) to work server.
[17:42:02] - 6 failed uploads of this unit.
[17:42:02] - Read packet limit of 540015616... Set to 524286976.
[17:42:02] + Attempting to send results [March 2 17:42:02 UTC]
[17:42:02] - Reading file work/wuresults_08.dat from core
[17:42:03]   (Read 40733593 bytes from disk)
[17:42:03] Connecting to http://171.67.108.17:8080/
[17:42:03] - Couldn't send HTTP request to server
[17:42:03]   (Got status 503)
[17:42:03] + Could not connect to Work Server (results)
[17:42:03]     (171.67.108.17:8080)
[17:42:03] + Retrying using alternative port
[17:42:03] Connecting to http://171.67.108.17:80/
[17:42:04] - Couldn't send HTTP request to server
[17:42:04]   (Got status 503)
[17:42:04] + Could not connect to Work Server (results)
[17:42:04]     (171.67.108.17:80)
[17:42:04]   Could not transmit unit 08 to Collection server; keeping in queue.
[17:42:04] + Sent 0 of 1 completed units to the server
[17:42:04] - Autosend completed
edit : the WU was finally sent at 23:42:04 UTC ... :)
