Project: 4610 (Run 35, Clone 1, Gen 70)
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
Just catching up on my logs. Immediate EUE:
[08:03:36] + Closed connections
[08:03:36]
[08:03:36] + Processing work unit
[08:03:36] Core required: FahCore_82.exe
[08:03:36] Core found.
[08:03:36] Working on Unit 02 [December 20 08:03:36]
[08:03:36] + Working ...
[08:03:36] - Calling 'FahCore_82.exe -dir work/ -suffix 02 -checkpoint 15 -verbose -lifeline 3988 -version 504'
[08:03:36]
[08:03:36] *------------------------------*
[08:03:36] Folding@Home PMD Core
[08:03:36] Version 1.03 (September 7, 2005)
[08:03:36]
[08:03:36] Preparing to commence simulation
[08:03:36] - Looking at optimizations...
[08:03:36] - Created dyn
[08:03:36] - Files status OK
[08:03:36] - Expanded 11881 -> 77614 (decompressed 653.2 percent)
[08:03:36]
[08:03:36] Project: 4610 (Run 35, Clone 1, Gen 70)
[08:03:36]
[08:03:36] Assembly optimizations on if available.
[08:03:36] Entering M.D.
[08:03:43] Going to send back what have done.
[08:03:43] logfile size: 5649
[08:03:43] - Writing 6169 bytes of core data to disk...
[08:03:43]   ... Done.
[08:03:43]
[08:03:43] Folding@home Core Shutdown: EARLY_UNIT_END
[08:03:46] CoreStatus = 72 (114)
[08:03:46] Sending work to server
[08:03:46] + Attempting to send results
[08:03:46] - Reading file work/wuresults_02.dat from core
[08:03:46]   (Read 6169 bytes from disk)
[08:03:46] Connecting to http://169.230.26.30:8080/
[08:03:47] Posted data.
[08:03:47] Initial: 0000; - Uploaded at ~7 kB/s
[08:03:47] - Averaged speed for that direction ~56 kB/s
[08:03:47] + Results successfully sent
[08:03:47] Thank you for your contribution to Folding@Home.
Re: Project: 4610 (Run 35, Clone 1, Gen 70)
There are 10 similar reports, I've marked it as a bad WU.
