Possible bad WU?
This WU ended with the same results each time, except the fifth, where the client paused 24 hours for exceeding the EUE limit.
Client Version 6.23
GPU Core Version 1.19
[02:39:56]
[02:39:56] Project: 5755 (Run 3, Clone 195, Gen 13)
[02:39:56]
[02:39:56] Assembly optimizations on if available.
[02:39:56] Entering M.D.
[02:40:03] Working on Protein
[02:40:07] Client config found, loading data.
[02:40:07] Starting GUI Server
[02:40:07] mdrun_gpu returned
[02:40:07] SHAKE violations on GPU
[02:40:07]
[02:40:07] Folding@home Core Shutdown: UNSTABLE_MACHINE
[02:40:11] CoreStatus = 7A (122)
[02:40:11] Sending work to server
[02:40:11] Project: 5755 (Run 3, Clone 195, Gen 13)
[02:40:11] - Read packet limit of 540015616... Set to 524286976.
[02:40:11] - Error: Could not get length of results file work/wuresults_04.dat
[02:40:11] - Error: Could not read unit 04 file. Removing from queue.
[02:40:11] EUE limit exceeded. Pausing 24 hours.
[02:52:03] - Autosending finished units... [December 26 02:52:03 UTC]
[02:52:03] Trying to send all finished work units
[02:52:03] + No unsent completed units remaining.
[02:52:03] - Autosend completed
[02:52:03] + Working...
[06:56:46] ***** Got a SIGTERM signal (2)
[06:56:46] Killing all core threads
Folding@Home Client Shutdown.
Flathead74
Re: Project: 5755 (Run 3, Clone 195, Gen 13)
There are two reports for 0 points ... that's probably a bad WU
Flathead74
