171.67.108.25 - Not Receiving Credit For WU's
AuberonKai
Post by AuberonKai »
I am unsure of how many WU's I've posted in the last 5 days, but according to the stats page, I last submitted on 12/18/2008. This is untrue.
Below is my status log from the client. I upgraded today to 6.23; I was on 6.20r3.
My GPU hasn't changed, and nothing (in the log) indicates failure to connect.
I'm running the 6.23 client on a geForce 8800GTS 640MB (single card) with the 7.15.11.8060 drivers dated 11/13/2008 from NVIDIA.
Slot 01 *Active
Project: 5754 (Run 0, Clone 125, Gen 36), Core: 11
Work server: 171.67.108.11:8080
Collection server: 171.67.108.25
Download date: December 21 20:01:21
Deadline date: December 24 20:01:21
PF: 0.913252 based on last 4 slot(s)
[05:45:33] Printing Queue Information
Current Queue:
Slot 02  Empty/Deleted
Project: 5757 (Run 6, Clone 187, Gen 3), Core: 11
Work server: 171.64.65.106:8080
Download date: December 19 15:53:31
Finished date: December 19 19:22:54
Slot 03  Empty/Deleted
Project: 5763 (Run 8, Clone 172, Gen 12), Core: 11
Download date: December 19 19:23:03
Finished date: December 19 22:52:20
Slot 04  Empty/Deleted
Project: 5761 (Run 8, Clone 2, Gen 51), Core: 11
Download date: December 19 22:52:30
Finished date: December 20 02:22:33
Slot 05  Empty/Deleted
Project: 5760 (Run 12, Clone 215, Gen 15), Core: 11
Download date: December 20 02:22:43
Finished date: December 20 08:01:30
Slot 06  Empty/Deleted
Project: 5016 (Run 8, Clone 331, Gen 161), Core: 11
Work server: 171.64.65.20:8080
Download date: December 20 08:01:40
Finished date: December 20 12:36:32
Slot 07  Empty/Deleted
Project: 5758 (Run 4, Clone 209, Gen 19), Core: 11
Download date: December 20 12:37:01
Finished date: December 20 16:11:21
Slot 08  Empty/Deleted
Project: 5757 (Run 6, Clone 12, Gen 60), Core: 11
Download date: December 20 16:11:32
Finished date: December 21 09:47:56
Failed uploads: 3
Slot 09  Empty/Deleted
Project: 5015 (Run 8, Clone 622, Gen 92), Core: 11
Download date: December 21 09:48:04
Finished date: December 21 14:26:45
Slot 00  Empty/Deleted
Project: 5015 (Run 9, Clone 784, Gen 261), Core: 11
Download date: December 21 14:27:14
Finished date: December 21 20:00:51
rem
Re: 171.67.108.25 - Not Receiving Credit For WU's
Post by rem »
hi_
i ve the same issue .
completed units are sent , but no points credits ...
and this for 3 days .
There one failure for this one (chriscox) and one success (WFO).
This WU has been completed by someone called nDivia.
No other WU has been returned yet ...
AuberonKai
Ok, that tells me nothing, really. I'd like to know why I'm not getting credit for the WU's my GPU client thinks it's turning in. I've given you the log.
MtM
Hardware configuration: Q6600 - 8gb - p5q deluxe - gtx275 - hd4350 ( not folding ) win7 x64 - smp:4 - gpu slot
T5450 - 4gb - ?? - 8600M GT 512 ( DDR2 ) - win7 x64 - smp:2 - gpu slot
Post by MtM »
And I want to bet you he's trying to figure it out. If the collection servers don't have a record of them, it's either the collection server having an issue ( which will also explain why you're not credited for them offcourse ) or something alike which is a bigger problem then you not getting credit.
If no record of turned in units is made, the assignment servers will keep reissuing the same wu's to other people, thus creating an endless loop of wu's being repeated without need.
There is another simular thread btw, so I'm strongly thinking it's an collection server issue.
edit: viewtopic.php?f=19&t=7563
AuberonKai
Clearly there must be some disconnect between the assignment and collection servers. The assignment server(s) must not be recording that it assigned a particular WU to me when I pick it up, and then assigns it to someone else. The collection server may be behaving properly in this case, if it as assuming that I am not the correct user with that WU.
I'm not sure how the database works, but perhaps that's an idea to look into? Is there somewhere in the database that says when WUs are assigned and to whom?
AuberonKai
I just looked at the stats for my team (Kolo'ula [150518]) on kakaostats.com. It turns out that my brother (the other member of my team - who runs his F@H client on his PS3 24/7) hasn't made any updates in the last 4 days either, according to the stats. I find this curious. Perhaps we're collecting our assigned WU's from the same server, and returning them to the same server? I have no idea...
Edit: Just looked at the logs again, and apparently one of my WU's (Slot #8) had 3 failed upload attempts. I also just finished a WU. Let's see if I get credit for this one on the new version of the software.
[05:21:14] Folding@home Core Shutdown: FINISHED_UNIT
[05:21:18] CoreStatus = 64 (100)
[05:21:18] Sending work to server
[05:21:18] Project: 5764 (Run 14, Clone 98, Gen 64)
[05:21:18] - Read packet limit of 540015616... Set to 524286976.
[05:21:18] + Attempting to send results [December 23 05:21:18 UTC]
[05:21:25] + Results successfully sent
[05:21:25] Thank you for your contribution to Folding@Home.
[05:21:25] + Number of Units Completed: 121
[05:21:29] + Closed connections
[05:21:29] + Paused after finishing unit
[05:59:48] Printing Queue Information
Current Queue:
Failed uploads: 3
Slot 01  Empty/Deleted
Finished date: December 22 10:38:42
Project: 5013 (Run 2, Clone 210, Gen 183), Core: 11
Download date: December 22 10:38:51
Finished date: December 22 15:17:07
Project: 5763 (Run 0, Clone 92, Gen 60), Core: 11
Download date: December 22 15:17:46
Finished date: December 22 18:50:14
Project: 5759 (Run 7, Clone 9, Gen 51), Core: 11
Download date: December 22 18:50:27
Finished date: December 22 22:23:25
Project: 5764 (Run 3, Clone 18, Gen 70), Core: 11
Download date: December 22 22:23:37
Finished date: December 23 01:58:38
Slot 06 *Empty/Deleted
Project: 5764 (Run 14, Clone 98, Gen 64), Core: 11
Download date: December 23 01:58:49
Finished date: December 23 05:21:18
PF: 0.929989 based on last 4 slot(s)
I don't know if there is a connection or not, but there is another report for missing credits here : viewtopic.php?f=19&t=7563 :(
MtM
Post by MtM »
MtM wrote:There is another simular thread btw, so I'm strongly thinking it's an collection server issue.
I think it would be a big downer if this is true. But then again, that collection server I also had with some wu's yesterday and I think I'm credited for those so it doesn't look to be the case that all wu's submitted there aren't credited.
toTow could you check if these are enterd into the db?
Queue.dat version:8.02
Performance fraction: 0,9630506
Performance fraction units: 4
Download rate: 69,653 Kb/S
Download rate units: 4
Upload rate: 31,14 Kb/S
Upload rate units: 4
Current index: 4
Index=0
Project: 5761 (Run 6 Clone 36 Generation 50)
Cpu memory: -31522816 Gpu memory: 258
Flops:1064675837	Benchmark: 0
Username: Marvin_The_Martian (11314)
Time data - begin:	dinsdag 23 december 2008 0:07:49
Time data - end:	dinsdag 23 december 2008 2:39:43
Issued: 	dinsdag 23 december 2008 0:07:48
Due: 	donderdag 25 december 2008 0:07:49
Expires: 	vrijdag 26 december 2008 0:07:49
Failed uploads: 0
Index=1
Flops:1064693329	Benchmark: 0
Time data - begin:	dinsdag 23 december 2008 2:39:46
Time data - end:	dinsdag 23 december 2008 5:08:14
Due: 	donderdag 25 december 2008 2:39:46
Expires: 	vrijdag 26 december 2008 2:39:46
Failed uploads: 0
Index=2
Project: 5758 (Run 14 Clone 59 Generation 70)
Flops:1064709989	Benchmark: 0
Time data - begin:	dinsdag 23 december 2008 5:08:27
Time data - end:	dinsdag 23 december 2008 7:37:21
Issued: 	dinsdag 23 december 2008 5:08:28
Due: 	donderdag 25 december 2008 5:08:27
Expires: 	vrijdag 26 december 2008 5:08:27
Failed uploads: 0
Index=3
Project: 5759 (Run 4 Clone 117 Generation 22)
Flops:1064722980	Benchmark: 0
Time data - begin:	dinsdag 23 december 2008 7:37:32
Time data - end:	dinsdag 23 december 2008 10:06:31
Issued: 	dinsdag 23 december 2008 7:37:33
Due: 	donderdag 25 december 2008 7:37:32
Expires: 	vrijdag 26 december 2008 7:37:32
Failed uploads: 0
Index=4
Project: 5757 (Run 3 Clone 3 Generation 89)
Flops:1064733308	Benchmark: 0
Time data - begin:	dinsdag 23 december 2008 10:06:55
Time date - end:	 ETA - dinsdag 23 december 2008 12:38:41
Issued: 	dinsdag 23 december 2008 10:06:56
Due: 	donderdag 25 december 2008 10:06:55
Expires: 	vrijdag 26 december 2008 10:06:55
Failed uploads: 0
Index=5
Project: 5014 (Run 7 Clone 445 Generation 14)
Flops:1064573897	Benchmark: 0
Time data - begin:	maandag 22 december 2008 10:33:06
Time data - end:	maandag 22 december 2008 13:09:44
Issued: 	maandag 22 december 2008 10:33:09
Due: 	woensdag 24 december 2008 10:33:06
Expires: 	donderdag 25 december 2008 10:33:06
Failed uploads: 0
Index=6
Project: 5764 (Run 13 Clone 107 Generation 58)
Flops:1064608100	Benchmark: 0
Time data - begin:	maandag 22 december 2008 16:19:27
Time data - end:	maandag 22 december 2008 18:54:02
Issued: 	maandag 22 december 2008 16:19:26
Due: 	woensdag 24 december 2008 16:19:27
Expires: 	donderdag 25 december 2008 16:19:27
Failed uploads: 0
Index=7
Project: 5759 (Run 4 Clone 8 Generation 54)
Flops:1064637055	Benchmark: 0
Time data - begin:	maandag 22 december 2008 18:54:19
Time data - end:	maandag 22 december 2008 18:54:32
Issued: 	maandag 22 december 2008 18:54:18
Due: 	woensdag 24 december 2008 18:54:19
Expires: 	donderdag 25 december 2008 18:54:19
Failed uploads: 0
Index=8
Time data - begin:	maandag 22 december 2008 18:54:34
Time data - end:	maandag 22 december 2008 21:28:54
Due: 	woensdag 24 december 2008 18:54:34
Expires: 	donderdag 25 december 2008 18:54:34
Failed uploads: 0
Index=9
Project: 5763 (Run 12 Clone 60 Generation 61)
Flops:1064660413	Benchmark: 0
Time data - begin:	maandag 22 december 2008 21:29:04
Time data - end:	dinsdag 23 december 2008 0:07:36
Issued: 	maandag 22 december 2008 21:29:04
Due: 	woensdag 24 december 2008 21:29:04
Expires: 	donderdag 25 december 2008 21:29:04
Failed uploads: 0
Hi Marvin_The_Martian (team 11314),
Your WU (P5761 R6 C36 G50) was added to the stats database on 2008-12-22 20:49:46 for 384 points of credit.
Your WU (P5758 R14 C59 G70) was added to the stats database on 2008-12-22 22:46:05 for 384 points of credit.
Your WU (P5759 R4 C117 G22) was added to the stats database on 2008-12-23 02:48:48 for 384 points of credit.
There's no data for this WU in the DB yet.
Your WU (P5014 R7 C445 G14) was added to the stats database on 2008-12-22 04:38:45 for 480 points of credit.
Your WU (P5764 R13 C107 G58) was added to the stats database on 2008-12-22 11:09:09 for 384 points of credit.
Your WU (P5759 R4 C8 G54) was added to the stats database on 2008-12-22 12:47:37 for 384 points of credit.
Your WU (P5763 R12 C60 G61) was added to the stats database on 2008-12-22 16:46:18 for 384 points of credit.
You have two duplicate entries in your queue, but most of your WUs have been credited :)
MtM
Post by MtM »
Yeah I had some crashes of wu's on client startup with corrupted size of results so it couldn't be uploaded, which I think corrupted the queue. Client reported that the entry would be cleared but it only sets the status to 0. I think I can edit the wusize field and try to upload them again, but I'm not sure how that works as iirc queuefix also changes some other bits then just the wusize so the collection server knows the queue has been alterd with a 3rd party program?
Anyway back on topic from OP; looks like the collection server and work server do talk and credit is given. But afaik they did do some work on the servers so maybe some got missed idk, can't tell and can't help you there :(
AuberonKai
I haven't received credit for well over 50 WU's now. Not a single WU has been credited since the update on 12/18/2008 @20:00. Given my previous history, that adds up to around 56 WUs that I haven't received credit for. Folding is going on hold until I get some answer or fix for this...
Could you check your Username and Teamnumber, just to be sure that your client didn't lost its configuration ?
VijayPande
Pande Group Member
Post by VijayPande »
We looked at this CS configuration and WU credits are going through just fine, from everything we can see. We can look into it deeper, but so far, everything looks fine (WU's coming through, points being credited, etc).
Prof. Vijay Pande, PhD
Chair, Biophysics
Stanford University
rem
Post by rem »
hi
i had the same issue with points credits ,
i changed my username , and now it ' s fine ... but restart a new client with the same username was useless :(
