The subject wu was completed successfully and uploaded to server 171.67.108.13 at 4:27 UTC this morning, but no credit has been received. I am running the Linux client 6.02. Could someone please check the status of this work unit? Here is the log file for this WU.
[19:35:51] - Preparing to get new work unit...
[19:35:51] + Attempting to get work packet
[19:35:51] - Connecting to assignment server
[19:35:51] - Successful: assigned to (171.67.108.13).
[19:35:51] + News From Folding@Home: Welcome to Folding@Home
[19:35:52] Loaded queue successfully.
[19:35:54] + Closed connections
[19:35:54]
[19:35:54] + Processing work unit
[19:35:54] Core required: FahCore_78.exe
[19:35:54] Core found.
[19:35:54] Working on Unit 02 [December 15 19:35:54]
[19:35:54] + Working ...
[19:35:54]
[19:35:54] *------------------------------*
[19:35:54] Folding@Home Gromacs Core
[19:35:54] Version 1.90 (March 8, 2006)
[19:35:54]
[19:35:54] Preparing to commence simulation
[19:35:54] - Looking at optimizations...
[19:35:54] - Created dyn
[19:35:54] - Files status OK
[19:35:55] - Expanded 202187 -> 1167721 (decompressed 577.5 percent)
[19:35:55] - Starting from initial work packet
[19:35:55]
[19:35:55] Project: 4440 (Run 365, Clone 0, Gen 0)
[19:35:55]
[19:35:55] Assembly optimizations on if available.
[19:35:55] Entering M.D.
[19:36:01] Protein: p4440_Seq42_Amber03
[19:36:01]
[19:36:01] Writing local files
[19:36:16] Extra SSE boost OK.
[19:36:16] Writing local files
[19:36:16] Completed 0 out of 1500000 steps (0%)
[19:55:44] Writing local files
[19:55:44] Completed 15000 out of 1500000 steps (1%)
[20:15:18] Writing local files
[04:26:25] Completed 1500000 out of 1500000 steps (100%)
[04:26:25] Writing final coordinates.
[04:26:25] Past main M.D. loop
[04:27:25]
[04:27:25] Finished Work Unit:
[04:27:25] - Reading up to 188856 from "work/wudata_02.arc": Read 188856
[04:27:25] - Reading up to 17868 from "work/wudata_02.xtc": Read 17868
[04:27:25] goefile size: 0
[04:27:25] logfile size: 17619
[04:27:25] Leaving Run
[04:27:25] - Writing 231347 bytes of core data to disk...
[04:27:25] Done: 230835 -> 207817 (compressed to 90.0 percent)
[04:27:25] ... Done.
[04:27:25] - Shutting down core
[04:27:25]
[04:27:25] Folding@home Core Shutdown: FINISHED_UNIT
[04:27:25] CoreStatus = 64 (100)
[04:27:25] Sending work to server
[04:27:25] - Read packet limit of 540015616... Set to 524286976.
[04:27:25] + Attempting to send results
[04:27:33] + Results successfully sent
[04:27:33] Thank you for your contribution to Folding@Home.
[04:27:33] + Number of Units Completed: 437
Project: 4440 (Run 365, Clone 0, Gen 0) - no credit
Re: Project: 4440 (Run 365, Clone 0, Gen 0) - no credit
There might be an issue with these projects or this server : viewtopic.php?f=18&t=7493
I'm getting the same result with your WU
