Project: 2669 (Run 1, Clone 67, Gen 37)
_r2w_ben
Post by _r2w_ben »
This is the ouput from the screen. The log file just indicates a failed workunit.
The machine is running Ubuntu 7.10 on an E4300 with 2GB of RAM.
[19:20:25] Working on Unit 09 [December 15 19:20:25]
[19:20:25] + Working ...
[19:20:25] - Calling './mpiexec -np 4 -host 127.0.0.1 ./FahCore_a2.exe -dir work/ -suffix 09 -np 4 -checkpoint 30 -verbose -lifeline 8076 -version 602'
[19:20:25]
[19:20:25] *------------------------------*
[19:20:25] Folding@Home Gromacs SMP Core
[19:20:25] Version 2.01 (Wed Aug 13 13:11:25 PDT 2008)
[19:20:25]
[19:20:25] Preparing to commence simulation
[19:20:25] - Ensuring status. Please wait.
[19:20:26] Called DecompressByteArray: compressed_data_size=4839006 data_size=23983821, decompressed_data_size=23983821 diff=0
[19:20:27] - Digital signature verified
[19:20:27]
[19:20:27] Project: 2669 (Run 1, Clone 67, Gen 37)
[19:20:27]
[19:20:27] Assembly optimizations on if available.
[19:20:27] Entering M.D.
[19:20:36] (Run 1, Clone 67, Gen 37)
[19:20:36]
[19:20:37] Entering M.D.
NNODES=4, MYRANK=0, HOSTNAME=FAHr
NNODES=4, MYRANK=2, HOSTNAME=FAHr
NNODES=4, MYRANK=1, HOSTNAME=FAHr
NNODES=4, MYRANK=3, HOSTNAME=FAHr
NODEID=0 argc=19
                         :-)  G  R  O  M  A  C  S  (-:
                   Groningen Machine for Chemical Simulation
                 :-)  VERSION 3.3.99_development_200800503  (-:
      Written by David van der Spoel, Erik Lindahl, Berk Hess, and others.
       Copyright (c) 1991-2000, University of Groningen, The Netherlands.
             Copyright (c) 2001-2008, The GROMACS development team,
            check out http://www.gromacs.org for more information.
                                :-)  mdrun  (-:
Reading file work/wudata_09.tpr, VERSION 3.3.99_development_20070618 (single precision)
NODEID=1 argc=19
NODEID=2 argc=19
NODEID=3 argc=19
Note: tpx file_version 48, software version 56
Making 1D domain decomposition 1 x 1 x 4
starting mdrun '22884 system'
250000 steps,    500.0 ps.
Step 9250233, time 18500.5 (ps)  LINCS WARNING
relative constraint deviation after LINCS:
rms 0.009371, max 0.424786 (between atoms 4764 and 4766)
bonds that rotated more than 90 degrees:
 atom 1 atom 2  angle  previous, current, constraint length
Step 9250234, time 18500.5 (ps)  LINCS WARNING
rms 0.000932, max 0.052010 (between atoms 4764 and 4766)
Step 9250235, time 18500.5 (ps)  LINCS WARNING
rms 0.005944, max 0.275590 (between atoms 4767 and 4768)
   4767   4768   90.0    0.1010   0.1288      0.1010
Step 9250236, time 18500.5 (ps)  LINCS WARNING
rms 0.007665, max 0.451738 (between atoms 4764 and 4766)
   4764   4766   90.0    0.1330   0.1582      0.1090
Step 9250237, time 18500.5 (ps)  LINCS WARNING
rms 0.009280, max 0.508994 (between atoms 4764 and 4766)
Step 9250238, time 18500.5 (ps)  LINCS WARNING
rms 0.007285, max 0.432515 (between atoms 4764 and 4766)
   4764   4766   90.0    0.1645   0.1561      0.1090
Step 9250239, time 18500.5 (ps)  LINCS WARNING
rms 96.256473, max 4497.078125 (between atoms 4761 and 4763)
   4764   4765  123.2    0.1093  13.2382      0.1090
   4767   4768   90.0    0.1010   0.1476      0.1010
Step 9250240:
The charge group starting at atom 4763 moved than the distance allowed by the domain decomposition (1.200000) in direction Z
distance out of cell -342.153839
Old coordinates:    6.289    4.341    7.823
New coordinates:  165.649 -320.887 -336.664
Old cell boundaries in direction Z:    5.528    8.538
New cell boundaries in direction Z:    5.490    8.531
Program mdrun, VERSION 3.3.99_development_200800503
Source code file: domdec.c, line: 2644
Fatal error:
A charge group move too far between two domain decomposition steps
Thanx for Using GROMACS - Have a Nice Day
Error on node 1, will try to stop all the nodes
Halting parallel program mdrun on CPU 1 out of 4
gcq#0: Thanx for Using GROMACS - Have a Nice Day
[cli_1]: aborting job:
application called MPI_Abort(MPI_COMM_WORLD, -1) - process 1
[cli_0]: aborting job:
Fatal error in MPI_Sendrecv: Error message texts are not available
[22:23:36] - Autosending finished units...
Re: Project: 2669 (Run 1, Clone 67, Gen 37)
There's no report for this WU yet.
You might consider upgrading to 6.23 client which is better dealing with such issues.
