Project: 4625 (Run 38, Clone 12, Gen 53) - EUE @ 0%
brityank
Post by brityank »
Had an EUE earlier this afternoon:
CP is Intel 6420 @ 2.13GHz 2GB RAM WinXP/SP2 - Core Temp 43-46ºC.
WU4599 (R19/C21/G27) Completed successfully ahead of this one.
[18:05:51] + No unsent completed units remaining.
[18:05:51] - Preparing to get new work unit...
[18:05:51] + Attempting to get work packet
[18:05:51] - Will indicate memory of 1536 MB
[18:05:51] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 15, Stepping: 6
[18:05:51] - Connecting to assignment server
[18:05:51] Connecting to http://assign.stanford.edu:8080/
[18:05:51] Posted data.
[18:05:51] Initial: E6A9; - Successful: assigned to (169.230.26.30).
[18:05:51] + News From Folding@Home: Welcome to Folding@Home
[18:05:51] Loaded queue successfully.
[18:05:51] Connecting to http://169.230.26.30:8080/
[18:05:52] Posted data.
[18:05:52] Initial: 0000; - Receiving payload (expected size: 12772)
[18:05:52] Conversation time very short, giving reduced weight in bandwidth avg
[18:05:52] - Downloaded at ~24 kB/s
[18:05:52] - Averaged speed for that direction ~47 kB/s
[18:05:52] + Received work.
[18:05:52] Trying to send all finished work units
[18:05:52] + No unsent completed units remaining.
[18:05:52] + Closed connections
[18:05:52]
[18:05:52] + Processing work unit
[18:05:52] Core required: FahCore_82.exe
[18:05:52] Core found.
[18:05:52] Working on queue slot 03 [December 14 18:05:52 UTC]
[18:05:52] + Working ...
[18:05:52] - Calling '.\FahCore_82.exe -dir work/ -suffix 03 -checkpoint 15 -verbose -lifeline 2904 -version 620'
[18:05:52]
[18:05:52] *------------------------------*
[18:05:52] Folding@Home PMD Core
[18:05:52] Version 1.03 (September 7, 2005)
[18:05:52]
[18:05:52] Preparing to commence simulation
[18:05:52] - Looking at optimizations...
[18:05:52] - Created dyn
[18:05:52] - Files status OK
[18:05:52] - Expanded 12260 -> 79887 (decompressed 651.6 percent)
[18:05:52]
[18:05:52] Project: 4625 (Run 38, Clone 12, Gen 53)
[18:05:52]
[18:05:52] Assembly optimizations on if available.
[18:05:52] Entering M.D.
[18:05:58] Going to send back what have done.
[18:05:58] logfile size: 5649
[18:05:58] - Writing 6169 bytes of core data to disk...
[18:05:58]   ... Done.
[18:05:58]
[18:05:58] Folding@home Core Shutdown: EARLY_UNIT_END
[18:06:02] CoreStatus = 72 (114)
[18:06:02] Sending work to server
[18:06:02] Project: 4625 (Run 38, Clone 12, Gen 53)
[18:06:02] + Attempting to send results [December 14 18:06:02 UTC]
[18:06:02] - Reading file work/wuresults_03.dat from core
[18:06:02]   (Read 6169 bytes from disk)
[18:06:02] Connecting to http://169.230.26.30:8080/
[18:06:03] Posted data.
[18:06:03] Initial: 0000; - Uploaded at ~7 kB/s
[18:06:03] - Averaged speed for that direction ~33 kB/s
[18:06:03] + Results successfully sent
[18:06:03] Thank you for your contribution to Folding@Home.
[18:06:07] Trying to send all finished work units
[18:06:07] + No unsent completed units remaining.
[18:06:07] - Preparing to get new work unit...
[18:06:07] + Attempting to get work packet
[18:06:07] - Will indicate memory of 1536 MB
[18:06:07] - Connecting to assignment server
[18:06:07] Connecting to http://assign.stanford.edu:8080/
[18:06:07] Posted data.
[18:06:07] Initial: E6A9; - Successful: assigned to (169.230.26.30).
[18:06:07] + News From Folding@Home: Welcome to Folding@Home
[18:06:08] Loaded queue successfully.
[18:06:08] Connecting to http://169.230.26.30:8080/
[18:06:08] Posted data.
[18:06:08] Initial: 0000; - Receiving payload (expected size: 20449)
[18:06:09] - Downloaded at ~19 kB/s
[18:06:09] - Averaged speed for that direction ~42 kB/s
[18:06:09] + Received work.
[18:06:09] Trying to send all finished work units
[18:06:09] + No unsent completed units remaining.
[18:06:09] + Closed connections
[18:06:14]
[18:06:14] + Processing work unit
[18:06:14] Core required: FahCore_82.exe
[18:06:14] Core found.
[18:06:14] Working on queue slot 04 [December 14 18:06:14 UTC]
[18:06:14] + Working ...
[18:06:14] - Calling '.\FahCore_82.exe -dir work/ -suffix 04 -checkpoint 15 -verbose -lifeline 2904 -version 620'
[18:06:14]
[18:06:14] *------------------------------*
[18:06:14] Folding@Home PMD Core
[18:06:14] Version 1.03 (September 7, 2005)
[18:06:14]
[18:06:14] Preparing to commence simulation
[18:06:14] - Looking at optimizations...
[18:06:14] - Created dyn
[18:06:14] - Files status OK
[18:06:14] - Expanded 19937 -> 126351 (decompressed 633.7 percent)
[18:06:14]
[18:06:14] Project: 4626 (Run 15, Clone 19, Gen 38)
[18:06:14]
[18:06:14] Assembly optimizations on if available.
[18:06:14] Entering M.D.
[18:06:20] Protein: p4626_T0499-16_minout
[18:06:20]
[18:06:20] Completed 0 out of 2500000 steps  (0%)
[18:16:13] Writing local files
Submitted for reference and tracking.
... ... Free Republic Folders - A Tribute to Ronald Reagan ... ...
Re: Project: 4625 (Run 38, Clone 12, Gen 53) - EUE @ 0%
There are 6 similar reports ... I've marked it as a bad WU.
brityank
Post by brityank »
Thanks, toTOW - I looked back but didn't see anything listing this RCG in this project number.
How far back do your records include, and is there anyplace we can check other than scanning down the pages here?
My records includes all returned WUs but it's a moderator only tool. It queries the stats DB, and return all reports it has for a given WU.
brityank
Post by brityank »
OK, thanks toTOW - appreciate your help. I had another one earlier; on way to check it out now. Cheers! :)
