[05:03:37] - Preparing to get new work unit...
[05:03:37] + Attempting to get work packet
[05:03:37] - Will indicate memory of 2046 MB
[05:03:37] - Detect CPU. Vendor: AuthenticAMD, Family: 15, Model: 11, Stepping: 2
[05:03:37] - Connecting to assignment server
[05:03:37] Connecting to http://assign-GPU.stanford.edu:8080/
[05:03:38] Posted data.
[05:03:38] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[05:03:38] + News From Folding@Home: GPU folding beta
[05:03:38] Loaded queue successfully.
[05:03:38] Connecting to http://171.67.108.11:8080/
[05:03:39] Posted data.
[05:03:39] Initial: 0000; - Receiving payload (expected size: 99205)
[05:03:41] - Downloaded at ~48 kB/s
[05:03:41] - Averaged speed for that direction ~45 kB/s
[05:03:41] + Received work.
[05:03:41] Trying to send all finished work units
[05:03:41] + No unsent completed units remaining.
[05:03:41] + Closed connections
[05:03:41]
[05:03:41] + Processing work unit
[05:03:41] Core required: FahCore_11.exe
[05:03:41] Core found.
[05:03:41] Working on queue slot 03 [December 12 05:03:41 UTC]
[05:03:41] + Working ...
[05:03:41] - Calling '.\FahCore_11.exe -dir work/ -suffix 03 -nocpulock -checkpoint 15 -verbose -lifeline 4884 -version 620'
[05:03:41]
[05:03:41] *------------------------------*
[05:03:41] Folding@Home GPU Core - Beta
[05:03:41] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[05:03:41]
[05:03:41] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[05:03:41] Build host: amoeba
[05:03:41] Board Type: Nvidia
[05:03:41] Core :
[05:03:41] Preparing to commence simulation
[05:03:41] - Looking at optimizations...
[05:03:41] - Created dyn
[05:03:41] - Files status OK
[05:03:41] - Expanded 98693 -> 492276 (decompressed 498.7 percent)
[05:03:41] Called DecompressByteArray: compressed_data_size=98693 data_size=492276, decompressed_data_size=492276 diff=0
[05:03:41] - Digital signature verified
[05:03:41]
[05:03:41] Project: 5749 (Run 3, Clone 47, Gen 12)
[05:03:41]
[05:03:41] Assembly optimizations on if available.
[05:03:41] Entering M.D.
[05:03:47] Working on Protein
[05:03:48] mdrun_gpu returned
[05:03:48] Going to send back what have done -- stepsTotalG=0
[05:03:48] Work fraction=0.0000 steps=0.
[05:03:52] logfile size=0 infoLength=0 edr=0 trr=25
[05:03:52] - Writing 637 bytes of core data to disk...
[05:03:52] Done: 125 -> 124 (compressed to 99.2 percent)
[05:03:52] ... Done.
[05:03:53]
[05:03:53] Folding@home Core Shutdown: UNSTABLE_MACHINE
[05:03:55] CoreStatus = 7A (122)
[05:03:55] Sending work to server
[05:03:55] Project: 5749 (Run 3, Clone 47, Gen 12)
[05:03:55] - Read packet limit of 540015616... Set to 524286976.
[05:03:55] + Attempting to send results [December 12 05:03:55 UTC]
[05:03:55] - Reading file work/wuresults_03.dat from core
[05:03:55] (Read 636 bytes from disk)
[05:03:55] Connecting to http://171.67.108.11:8080/
[05:03:56] Posted data.
[05:03:56] Initial: 0000; - Uploaded at ~1 kB/s
[05:03:56] - Averaged speed for that direction ~3 kB/s
[05:03:56] + Results successfully sent
[05:03:56] Thank you for your contribution to Folding@Home.
[05:04:00] Trying to send all finished work units
[05:04:00] + No unsent completed units remaining.
[05:04:00] - Preparing to get new work unit...
[05:04:00] + Attempting to get work packet
[05:04:00] - Will indicate memory of 2046 MB
[05:04:00] - Connecting to assignment server
[05:04:00] Connecting to http://assign-GPU.stanford.edu:8080/
[05:04:01] Posted data.
[05:04:01] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[05:04:01] + News From Folding@Home: GPU folding beta
[05:04:01] Loaded queue successfully.
[05:04:01] Connecting to http://171.67.108.11:8080/
[05:04:01] Initial: 0000; - Receiving payload (expected size: 99296)
[05:04:03] - Downloaded at ~48 kB/s
[05:04:03] - Averaged speed for that direction ~45 kB/s
[05:04:03] + Received work.
[05:04:03] Trying to send all finished work units
[05:04:03] + No unsent completed units remaining.
[05:04:03] + Closed connections
[05:04:08]
[05:04:08] + Processing work unit
[05:04:08] Core required: FahCore_11.exe
[05:04:08] Core found.
[05:04:08] Working on queue slot 04 [December 12 05:04:08 UTC]
[05:04:08] + Working ...
[05:04:08] - Calling '.\FahCore_11.exe -dir work/ -suffix 04 -nocpulock -checkpoint 15 -verbose -lifeline 4884 -version 620'
[05:04:08]
[05:04:08] *------------------------------*
[05:04:08] Folding@Home GPU Core - Beta
[05:04:08] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[05:04:08]
[05:04:08] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[05:04:08] Build host: amoeba
[05:04:08] Board Type: Nvidia
[05:04:08] Core :
[05:04:08] Preparing to commence simulation
[05:04:08] - Looking at optimizations...
[05:04:08] - Created dyn
[05:04:08] - Files status OK
[05:04:08] - Expanded 98784 -> 492276 (decompressed 498.3 percent)
[05:04:08] Called DecompressByteArray: compressed_data_size=98784 data_size=492276, decompressed_data_size=492276 diff=0
[05:04:08] - Digital signature verified
[05:04:08]
[05:04:08] Project: 5749 (Run 9, Clone 149, Gen 12)
[05:04:08]
[05:04:09] Assembly optimizations on if available.
[05:04:09] Entering M.D.
[05:04:16] Working on Protein
[05:04:16] mdrun_gpu returned
[05:04:16] Going to send back what have done -- stepsTotalG=0
[05:04:16] Work fraction=0.0000 steps=0.
[05:04:20] logfile size=0 infoLength=0 edr=0 trr=25
[05:04:20] - Writing 637 bytes of core data to disk...
[05:04:20] Done: 125 -> 124 (compressed to 99.2 percent)
[05:04:20] ... Done.
[05:04:27]
[05:04:27] Folding@home Core Shutdown: UNSTABLE_MACHINE
[05:04:31] CoreStatus = 7A (122)
[05:04:31] Sending work to server
[05:04:31] Project: 5749 (Run 9, Clone 149, Gen 12)
[05:04:31] - Read packet limit of 540015616... Set to 524286976.
[05:04:31] + Attempting to send results [December 12 05:04:31 UTC]
[05:04:31] - Reading file work/wuresults_04.dat from core
[05:04:31] (Read 636 bytes from disk)
[05:04:31] Connecting to http://171.67.108.11:8080/
[05:04:31] Posted data.
[05:04:31] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[05:04:31] - Uploaded at ~3 kB/s
[05:04:31] - Averaged speed for that direction ~3 kB/s
[05:04:31] + Results successfully sent
[05:04:31] Thank you for your contribution to Folding@Home.
[05:04:35] Trying to send all finished work units
[05:04:35] + No unsent completed units remaining.
[05:04:35] - Preparing to get new work unit...
[05:04:35] + Attempting to get work packet
[05:04:35] - Will indicate memory of 2046 MB
[05:04:35] - Connecting to assignment server
[05:04:35] Connecting to http://assign-GPU.stanford.edu:8080/
[05:04:36] Posted data.
[05:04:36] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[05:04:36] + News From Folding@Home: GPU folding beta
[05:04:36] Loaded queue successfully.
[05:04:36] Connecting to http://171.67.108.11:8080/
[05:04:37] Posted data.
[05:04:37] Initial: 0000; - Receiving payload (expected size: 99283)
[05:04:38] - Downloaded at ~96 kB/s
[05:04:38] - Averaged speed for that direction ~56 kB/s
[05:04:38] + Received work.
[05:04:38] Trying to send all finished work units
[05:04:38] + No unsent completed units remaining.
[05:04:38] + Closed connections
[05:04:44]
[05:04:44] + Processing work unit
[05:04:44] Core required: FahCore_11.exe
[05:04:44] Core found.
[05:04:44] Working on queue slot 05 [December 12 05:04:44 UTC]
[05:04:44] + Working ...
[05:04:44] - Calling '.\FahCore_11.exe -dir work/ -suffix 05 -nocpulock -checkpoint 15 -verbose -lifeline 4884 -version 620'
[05:04:44]
[05:04:44] *------------------------------*
[05:04:44] Folding@Home GPU Core - Beta
[05:04:44] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[05:04:44]
[05:04:44] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[05:04:44] Build host: amoeba
[05:04:44] Board Type: Nvidia
[05:04:44] Core :
[05:04:44] Preparing to commence simulation
[05:04:44] - Looking at optimizations...
[05:04:44] - Created dyn
[05:04:44] - Files status OK
[05:04:44] - Expanded 98771 -> 492276 (decompressed 498.4 percent)
[05:04:44] Called DecompressByteArray: compressed_data_size=98771 data_size=492276, decompressed_data_size=492276 diff=0
[05:04:44] - Digital signature verified
[05:04:44]
[05:04:44] Project: 5749 (Run 14, Clone 133, Gen 11)
[05:04:44]
[05:04:44] Assembly optimizations on if available.
[05:04:44] Entering M.D.
[05:04:50] Working on Protein
[05:04:51] mdrun_gpu returned
[05:04:51] Going to send back what have done -- stepsTotalG=0
[05:04:51] Work fraction=0.0000 steps=0.
[05:04:55] logfile size=0 infoLength=0 edr=0 trr=25
[05:04:55] - Writing 637 bytes of core data to disk...
[05:04:55] Done: 125 -> 124 (compressed to 99.2 percent)
[05:04:55] ... Done.
[05:04:55]
[05:04:55] Folding@home Core Shutdown: UNSTABLE_MACHINE
[05:04:58] CoreStatus = 7A (122)
[05:04:58] Sending work to server
[05:04:58] Project: 5749 (Run 14, Clone 133, Gen 11)
[05:04:58] - Read packet limit of 540015616... Set to 524286976.
[05:04:58] + Attempting to send results [December 12 05:04:58 UTC]
[05:04:58] - Reading file work/wuresults_05.dat from core
[05:04:58] (Read 636 bytes from disk)
[05:04:58] Connecting to http://171.67.108.11:8080/
[05:04:59] Posted data.
[05:04:59] Initial: 0000; - Uploaded at ~1 kB/s
[05:04:59] - Averaged speed for that direction ~3 kB/s
[05:04:59] + Results successfully sent
[05:04:59] Thank you for your contribution to Folding@Home.
[05:05:03] Trying to send all finished work units
[05:05:03] + No unsent completed units remaining.
[05:05:03] - Preparing to get new work unit...
[05:05:03] + Attempting to get work packet
[05:05:03] - Will indicate memory of 2046 MB
[05:05:03] - Connecting to assignment server
[05:05:03] Connecting to http://assign-GPU.stanford.edu:8080/
[05:05:04] Posted data.
[05:05:04] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[05:05:04] + News From Folding@Home: GPU folding beta
[05:05:04] Loaded queue successfully.
[05:05:04] Connecting to http://171.67.108.11:8080/
[05:05:04] Initial: 0000; - Receiving payload (expected size: 99234)
[05:05:06] - Downloaded at ~48 kB/s
[05:05:06] - Averaged speed for that direction ~54 kB/s
[05:05:06] + Received work.
[05:05:06] Trying to send all finished work units
[05:05:06] + No unsent completed units remaining.
[05:05:06] + Closed connections
[05:05:11]
[05:05:11] + Processing work unit
[05:05:11] Core required: FahCore_11.exe
[05:05:11] Core found.
[05:05:11] Working on queue slot 06 [December 12 05:05:11 UTC]
[05:05:11] + Working ...
[05:05:11] - Calling '.\FahCore_11.exe -dir work/ -suffix 06 -nocpulock -checkpoint 15 -verbose -lifeline 4884 -version 620'
[05:05:11]
[05:05:11] *------------------------------*
[05:05:11] Folding@Home GPU Core - Beta
[05:05:11] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[05:05:11]
[05:05:11] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[05:05:11] Build host: amoeba
[05:05:11] Board Type: Nvidia
[05:05:11] Core :
[05:05:11] Preparing to commence simulation
[05:05:11] - Looking at optimizations...
[05:05:11] - Created dyn
[05:05:11] - Files status OK
[05:05:11] - Expanded 98722 -> 492276 (decompressed 498.6 percent)
[05:05:11] Called DecompressByteArray: compressed_data_size=98722 data_size=492276, decompressed_data_size=492276 diff=0
[05:05:11] - Digital signature verified
[05:05:11]
[05:05:11] Project: 5749 (Run 7, Clone 139, Gen 10)
[05:05:11]
[05:05:11] Assembly optimizations on if available.
[05:05:11] Entering M.D.
[05:05:18] Working on Protein
[05:05:19] mdrun_gpu returned
[05:05:19] Going to send back what have done -- stepsTotalG=0
[05:05:19] Work fraction=0.0000 steps=0.
[05:05:23] logfile size=0 infoLength=0 edr=0 trr=25
[05:05:23] - Writing 637 bytes of core data to disk...
[05:05:23] Done: 125 -> 124 (compressed to 99.2 percent)
[05:05:23] ... Done.
[05:05:29]
[05:05:29] Folding@home Core Shutdown: UNSTABLE_MACHINE
[05:05:31] CoreStatus = 7A (122)
[05:05:31] Sending work to server
[05:05:31] Project: 5749 (Run 7, Clone 139, Gen 10)
[05:05:31] - Read packet limit of 540015616... Set to 524286976.
[05:05:31] + Attempting to send results [December 12 05:05:31 UTC]
[05:05:31] - Reading file work/wuresults_06.dat from core
[05:05:31] (Read 636 bytes from disk)
[05:05:31] Connecting to http://171.67.108.11:8080/
[05:05:32] Posted data.
[05:05:32] Initial: 0000; - Uploaded at ~1 kB/s
[05:05:32] - Averaged speed for that direction ~2 kB/s
[05:05:32] + Results successfully sent
[05:05:32] Thank you for your contribution to Folding@Home.
[05:05:36] Trying to send all finished work units
[05:05:36] + No unsent completed units remaining.
[05:05:36] - Preparing to get new work unit...
[05:05:36] + Attempting to get work packet
[05:05:36] - Will indicate memory of 2046 MB
[05:05:36] - Connecting to assignment server
[05:05:36] Connecting to http://assign-GPU.stanford.edu:8080/
[05:05:37] Posted data.
[05:05:37] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[05:05:37] + News From Folding@Home: GPU folding beta
[05:05:37] Loaded queue successfully.
[05:05:37] Connecting to http://171.67.108.11:8080/
[05:05:38] Posted data.
[05:05:38] Initial: 0000; - Receiving payload (expected size: 99283)
[05:05:39] - Downloaded at ~96 kB/s
[05:05:39] - Averaged speed for that direction ~63 kB/s
[05:05:39] + Received work.
[05:05:39] Trying to send all finished work units
[05:05:39] + No unsent completed units remaining.
[05:05:39] + Closed connections
[05:05:44]
[05:05:44] + Processing work unit
[05:05:44] Core required: FahCore_11.exe
[05:05:44] Core found.
[05:05:44] Working on queue slot 07 [December 12 05:05:44 UTC]
[05:05:44] + Working ...
[05:05:44] - Calling '.\FahCore_11.exe -dir work/ -suffix 07 -nocpulock -checkpoint 15 -verbose -lifeline 4884 -version 620'
[05:05:44]
[05:05:44] *------------------------------*
[05:05:44] Folding@Home GPU Core - Beta
[05:05:44] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[05:05:44]
[05:05:44] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[05:05:44] Build host: amoeba
[05:05:44] Board Type: Nvidia
[05:05:44] Core :
[05:05:44] Preparing to commence simulation
[05:05:44] - Looking at optimizations...
[05:05:44] - Created dyn
[05:05:44] - Files status OK
[05:05:44] - Expanded 98771 -> 492276 (decompressed 498.4 percent)
[05:05:44] Called DecompressByteArray: compressed_data_size=98771 data_size=492276, decompressed_data_size=492276 diff=0
[05:05:44] - Digital signature verified
[05:05:44]
[05:05:44] Project: 5749 (Run 3, Clone 133, Gen 9)
[05:05:44]
[05:05:44] Assembly optimizations on if available.
[05:05:44] Entering M.D.
[05:05:52] Working on Protein
[05:05:52] mdrun_gpu returned
[05:05:52] Going to send back what have done -- stepsTotalG=0
[05:05:52] Work fraction=0.0000 steps=0.
[05:05:56] logfile size=0 infoLength=0 edr=0 trr=25
[05:05:56] - Writing 637 bytes of core data to disk...
[05:05:56] Done: 125 -> 124 (compressed to 99.2 percent)
[05:05:56] ... Done.
[05:05:59]
[05:05:59] Folding@home Core Shutdown: UNSTABLE_MACHINE
[05:06:03] CoreStatus = 7A (122)
[05:06:03] Sending work to server
[05:06:03] Project: 5749 (Run 3, Clone 133, Gen 9)
[05:06:03] - Read packet limit of 540015616... Set to 524286976.
[05:06:03] + Attempting to send results [December 12 05:06:03 UTC]
[05:06:03] - Reading file work/wuresults_07.dat from core
[05:06:03] (Read 636 bytes from disk)
[05:06:03] Connecting to http://171.67.108.11:8080/
[05:06:03] Posted data.
[05:06:03] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[05:06:03] - Uploaded at ~3 kB/s
[05:06:03] - Averaged speed for that direction ~2 kB/s
[05:06:03] + Results successfully sent
[05:06:03] Thank you for your contribution to Folding@Home.
[05:06:07] EUE limit exceeded. Pausing 24 hours.I note also the assignment of the same unit twice, after the first failure. This seems like a weakness in the allocation strategy.
NVidia GeForce 8400, stock clocks, under Windows Vista Home Premium. No sign of overheating.
David
