Project: 2665 (Run 3, Clone 592, Gen 74)
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
EUE at 91%.
[18:25:03] + Closed connections
[18:25:03]
[18:25:03] + Processing work unit
[18:25:03] Work type a1 not eligible for variable processors
[18:25:03] Core required: FahCore_a1.exe
[18:25:03] Core found.
[18:25:03] Using generic mpiexec calls
[18:25:03] Working on queue slot 06 [December 6 18:25:03 UTC]
[18:25:03] + Working ...
[18:25:03] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 06 -checkpoint 15 -verbose -lifeline 2832 -version 623'
[18:25:03]
[18:25:03] *------------------------------*
[18:25:03] Folding@Home Gromacs SMP Core
[18:25:03] Version 1.74 (March 10, 2007)
[18:25:03]
[18:25:03] Preparing to commence simulation
[18:25:03] - Ensuring status. Please wait.
[18:25:08] - Starting from initial work packet
[18:25:08]
[18:25:08] Project: 2665 (Run 3, Clone 592, Gen 74)
[18:25:08]
[18:25:09] Assembly optimizations on if available.
[18:25:09] Entering M.D.
[18:25:30]  percent)
[18:25:30] - Starting from initial work packet
[18:25:30]
[18:25:30] Project: 2665 (Run 3, Clone 592, Gen 74)
[18:25:30]
[18:25:31] Entering M.D.
[18:25:38] Rejecting checkpoint
[18:25:39] Protein: HGG in water
[18:25:39] Writing local files
[18:25:47] Extra SSE boost OK.
[18:25:47] Writing local files
[18:25:48] Completed 0 out of 250000 steps  (0 percent)
[18:40:47] Timered checkpoint triggered.
[18:42:08] Writing local files
[18:42:08] Completed 2500 out of 250000 steps  (1 percent)
     {snip}
[19:11:47] Writing local files
[19:11:48] Completed 227500 out of 250000 steps  (91 percent)
[19:23:56] Warning:  long 1-4 interactions
[19:23:56] Quit 101 - NaN detected: (ener[20])
[19:23:56]
[19:23:56] Simulation instability has been encountered. The run has entered a
[19:23:56]   state from which no further progress can be made.
[19:23:56] This may be the correct result of the simulation, however if you
[19:23:56]   often see other project units terminating early like this
[19:23:56]   too, you may wish to check the stability of your computer (issues
[19:23:56]   such as high temperature, overclocking, etc.).
[19:23:56] Going to send back what have done.
[19:23:56] logfile size: 179342
[19:23:56] - Writing 179892 bytes of core data to disk...
[19:23:56]   ... Done.
[19:23:57] - Failed to delete work/wudata_06.arc
[19:23:57] Warning:  check for stray files
[19:25:57]
[19:25:57] Folding@home Core Shutdown: EARLY_UNIT_END
[19:25:57]
[19:25:59] CoreStatus = 7B (123)
[19:25:59] Sending work to server
[19:25:59] Project: 2665 (Run 3, Clone 592, Gen 74)
[19:25:59] + Attempting to send results [December 7 19:25:59 UTC]
[19:25:59] - Reading file work/wuresults_06.dat from core
[19:25:59]   (Read 179892 bytes from disk)
[19:25:59] Connecting to http://171.64.65.64:8080/
[19:26:06] Posted data.
[19:26:06] Initial: 0000; - Uploaded at ~25 kB/s
[19:26:06] - Averaged speed for that direction ~46 kB/s
[19:26:06] + Results successfully sent
[19:26:06] Thank you for your contribution to Folding@Home.
Re: Project: 2665 (Run 3, Clone 592, Gen 74)
There's no other report for this WU yet ...
anko1
Post by anko1 »
Thanks for checking, toTOW.
Someone else reported an immediate failure on this WU.
anko1
Post by anko1 »
That makes me feel better. ;
