Project: 4748 (Run 1, Clone 14, Gen 7)
Ivoshiee
Post by Ivoshiee »
Something strange is here in the FAHlog.txt:
--- Opening Log file [December 7 14:09:19 UTC]
                       Folding@Home Client Version 6.20r2beta
                          http://folding.stanford.edu
Launch directory: C:\folding
Service: C:\folding\Folding@home-Win32-GPU.exe
Arguments: -svcstart -d C:\folding -verbosity 9 -forceasm
Launched as a service.
Entered C:\folding to do work.
Warning:
 By using the -forceasm flag, you are overriding
 safeguards in the program. If you did not intend to
 do this, please restart the program without -forceasm.
 If work units are not completing fully (and particularly
 if your machine is overclocked), then please discontinue
 use of the flag.
[14:09:19] - Ask before connecting: No
[14:09:19] - User name: ivo@vendomar.ee (Team 0)
[14:09:19] - User ID: 1105FF2327CE221
[14:09:19] - Machine ID: 1
[14:09:19]
[14:09:19] Loaded queue successfully.
[14:09:19] - Preparing to get new work unit...
[14:09:19] + Attempting to get work packet
[14:09:19] - Autosending finished units... [14:09:19]
[14:09:19] - Will indicate memory of 3327 MB[14:09:19] Trying to send all finished work units
[14:09:19] + No unsent completed units remaining.
[14:09:19] - Autosend completed
[14:09:19] - Detect CPU. Vendor: AuthenticAMD, Family: 15, Model: 2, Stepping: 2
[14:09:19] - Connecting to assignment server
[14:09:19] Connecting to http://assign-GPU.stanford.edu:8080/
[14:09:21] Posted data.
[14:09:21] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[14:09:21] + News From Folding@Home: GPU folding beta
[14:09:21] Loaded queue successfully.
[14:09:21] Connecting to http://171.64.65.102:8080/
[14:09:22] Posted data.
[14:09:22] Initial: 0000; - Receiving payload (expected size: 99070)
[14:09:24] - Downloaded at ~48 kB/s
[14:09:24] - Averaged speed for that direction ~56 kB/s
[14:09:24] + Received work.
[14:09:24] + Closed connections
[14:09:24]
[14:09:24] + Processing work unit
[14:09:24] Core required: FahCore_12.exe
[14:09:24] Core found.
[14:09:24] Working on queue slot 06 [December 7 14:09:24 UTC]
[14:09:24] + Working ...
[14:09:24] - Calling '.\FahCore_12.exe -dir work/ -suffix 06 -checkpoint 15 -service -forceasm -verbose -lifeline 3852 -version 620'
[14:09:24]
[14:09:24] *------------------------------*
[14:09:24] Folding@Home GPU Core - Beta
[14:09:24] Version 1.20 (Wed Nov 19 14:15:53 PST 2008)
[14:09:24]
[14:09:24] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[14:09:24] Build host: amoeba
[14:09:24] Board Type: AMD
[14:09:24] Core      :
[14:09:24] Preparing to commence simulation
[14:09:24] - Assembly optimizations manually forced on.
[14:09:24] - Not checking prior termination.
[14:09:24] - Expanded 98558 -> 492188 (decompressed 499.3 percent)
[14:09:24] Called DecompressByteArray: compressed_data_size=98558 data_size=492188, decompressed_data_size=492188 diff=0
[14:09:24] - Digital signature verified
[14:09:24]
[14:09:24] Project: 5716 (Run 1, Clone 0, Gen 36)
[14:09:24]
[14:09:24] Assembly optimizations on if available.
[14:09:24] Entering M.D.
[14:09:30] Working on Protein
[14:09:31] Client config found, loading data.
[14:09:31] Starting GUI Server
[14:13:21] Completed 1%
[14:16:50] Completed 2%
[14:20:14] Completed 3%
[14:23:40] Completed 4%
[14:27:06] Completed 5%
[14:30:30] Completed 6%
[14:33:56] Completed 7%
[14:37:21] Completed 8%
[14:40:46] Completed 9%
[14:44:12] Completed 10%
[14:47:36] Completed 11%
[14:51:02] Completed 12%
[14:54:28] Completed 13%
[14:57:52] Completed 14%
[15:01:18] Completed 15%
[15:04:44] Completed 16%
[15:08:08] Completed 17%
[15:11:34] Completed 18%
[15:14:59] Completed 19%
[15:18:24] Completed 20%
[15:21:57] Completed 21%
[15:25:38] Completed 22%
[15:29:16] Completed 23%
[15:32:50] Completed 24%
[15:36:15] Completed 25%
[15:39:40] Completed 26%
[15:43:04] Completed 27%
[15:46:27] Completed 28%
[15:49:51] Completed 29%
[15:53:14] Completed 30%
[15:56:39] Completed 31%
[16:00:03] Completed 32%
[16:03:26] Completed 33%
[16:06:50] Completed 34%
[16:10:14] Completed 35%
[16:13:38] Completed 36%
[16:17:08] Completed 37%
[16:20:40] Completed 38%
[16:24:09] Completed 39%
[16:27:47] Completed 40%
[16:31:19] Completed 41%
[16:34:42] Completed 42%
[16:38:07] Completed 43%
[16:41:29] Completed 44%
[16:44:53] Completed 45%
[16:48:17] Completed 46%
[16:51:40] Completed 47%
[16:55:04] Completed 48%
[16:58:28] Completed 49%
[17:01:51] Completed 50%
[17:05:15] Completed 51%
[17:08:38] Completed 52%
[17:12:02] Completed 53%
[17:15:26] Completed 54%
[17:18:48] Completed 55%
[17:22:12] Completed 56%
[17:25:36] Completed 57%
[17:28:59] Completed 58%
[17:32:23] Completed 59%
[17:35:46] Completed 60%
[17:39:10] Completed 61%
[17:42:34] Completed 62%
[17:45:57] Completed 63%
[17:49:21] Completed 64%
[17:52:44] Completed 65%
[17:56:07] Completed 66%
[17:59:31] Completed 67%
[18:02:55] Completed 68%
[18:06:18] Completed 69%
[18:09:42] Completed 70%
[18:13:05] Completed 71%
[18:16:29] Completed 72%
[18:19:53] Completed 73%
[18:23:16] Completed 74%
[18:26:39] Completed 75%
[18:30:03] Completed 76%
[18:33:26] Completed 77%
[18:36:50] Completed 78%
[18:40:14] Completed 79%
[18:43:37] Completed 80%
[18:47:01] Completed 81%
[18:50:24] Completed 82%
[18:53:48] Completed 83%
[18:57:12] Completed 84%
[19:00:35] Completed 85%
[19:03:59] Completed 86%
[19:07:23] Completed 87%
[19:10:45] Completed 88%
[19:14:09] Completed 89%
[19:17:32] Completed 90%
[19:20:56] Completed 91%
[19:24:20] Completed 92%
[19:27:43] Completed 93%
[19:31:07] Completed 94%
[19:34:31] Completed 95%
[19:37:54] Completed 96%
[19:41:18] Completed 97%
[19:44:42] Completed 98%
[19:48:04] Completed 99%
[19:51:28] Completed 100%
[19:51:29] Successful run
[19:51:29] DynamicWrapper: Finished Work Unit: sleep=10000
[19:51:39] Reserved 219064 bytes for xtc file; Cosm status=0
[19:51:39] Allocated 219064 bytes for xtc file
[19:51:39] - Reading up to 219064 from "work/wudata_06.xtc": Read 219064
[19:51:39] Read 219064 bytes from xtc file; available packet space=786211400
[19:51:39] xtc file hash check passed.
[19:51:39] Reserved 33528 33528 786211400 bytes for arc file=<work/wudata_06.trr> Cosm status=0
[19:51:39] Allocated 33528 bytes for arc file
[19:51:39] - Reading up to 33528 from "work/wudata_06.trr": Read 33528
[19:51:39] Read 33528 bytes from arc file; available packet space=786177872
[19:51:39] trr file hash check passed.
[19:51:39] Allocated 560 bytes for edr file
[19:51:39] Read bedfile
[19:51:39] edr file hash check passed.
[19:51:39] Allocated 54785 bytes for logfile
[19:51:39] Read logfile
[19:51:39] GuardedRun: success in DynamicWrapper
[19:51:39] GuardedRun: done
[19:51:39] Run: GuardedRun completed.
[19:51:39] - Writing 308449 bytes of core data to disk...
[19:51:39] Done: 307937 -> 264976 (compressed to 86.0 percent)
[19:51:39]   ... Done.
[19:51:39] - Shutting down core
[19:51:39]
[19:51:39] Folding@home Core Shutdown: FINISHED_UNIT
[19:51:42] CoreStatus = 64 (100)
[19:51:42] Unit 6 finished with 92 percent of time to deadline remaining.
[19:51:42] Updated performance fraction: 0.898782
[19:51:42] Sending work to server
[19:51:42] Project: 5716 (Run 1, Clone 0, Gen 36)
[19:51:42] + Attempting to send results [December 7 19:51:42 UTC]
[19:51:42] - Reading file work/wuresults_06.dat from core
[19:51:42]   (Read 265488 bytes from disk)
[19:51:42] Connecting to http://171.64.65.102:8080/
[19:51:47] Posted data.
[19:51:48] Initial: 0000; - Uploaded at ~43 kB/s
[19:51:48] - Averaged speed for that direction ~45 kB/s
[19:51:48] + Results successfully sent
[19:51:48] Thank you for your contribution to Folding@Home.
[19:51:48] + Number of Units Completed: 327
[19:51:52] Trying to send all finished work units
[19:51:52] + No unsent completed units remaining.
[19:51:52] - Preparing to get new work unit...
[19:51:52] + Attempting to get work packet
[19:51:52] - Will indicate memory of 3327 MB
[19:51:52] - Connecting to assignment server
[19:51:52] Connecting to http://assign-GPU.stanford.edu:8080/
[19:51:53] Posted data.
[19:51:53] Initial: 40AB; - Successful: assigned to (171.64.65.103).
[19:51:53] + News From Folding@Home: GPU folding beta
[19:51:54] Loaded queue successfully.
[19:51:54] Connecting to http://171.64.65.103:8080/
[19:51:55] Posted data.
[19:51:55] Initial: 0000; - Receiving payload (expected size: 41850)
[19:51:57] - Downloaded at ~20 kB/s
[19:51:57] - Averaged speed for that direction ~49 kB/s
[19:51:57] + Received work.
[19:51:57] Trying to send all finished work units
[19:51:57] + No unsent completed units remaining.
[19:51:57] + Closed connections
[19:51:57]
[19:51:57] + Processing work unit
[19:51:57] Core required: FahCore_12.exe
[19:51:57] Core found.
[19:51:57] Working on queue slot 07 [December 7 19:51:57 UTC]
[19:51:57] + Working ...
[19:51:57] - Calling '.\FahCore_12.exe -dir work/ -suffix 07 -checkpoint 15 -service -forceasm -verbose -lifeline 3852 -version 620'
[19:51:57]
[19:51:57] *------------------------------*
[19:51:57] Folding@Home GPU Core - Beta
[19:51:57] Version 1.20 (Wed Nov 19 14:15:53 PST 2008)
[19:51:57]
[19:51:57] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[19:51:57] Build host: amoeba
[19:51:57] Board Type: AMD
[19:51:57] Core      :
[19:51:57] Preparing to commence simulation
[19:51:57] - Assembly optimizations manually forced on.
[19:51:57] - Not checking prior termination.
[19:51:57] - Expanded 41338 -> 231745 (decompressed 560.6 percent)
[19:51:57] Called DecompressByteArray: compressed_data_size=41338 data_size=231745, decompressed_data_size=231745 diff=0
[19:51:57] - Digital signature verified
[19:51:57]
[19:51:57] Project: 4748 (Run 1, Clone 14, Gen 7)
[19:51:57]
[19:51:57] Assembly optimizations on if available.
[19:51:57] Entering M.D.
[19:52:03] Will resume from checkpoint file
[19:52:04] Working on 544 p4709_fip35_ww_domain
[19:52:04] Client config found, loading data.
[19:52:04] Starting GUI Server
[19:52:13] Resuming from checkpoint
[19:52:13] Verified work/wudata_07.log
[19:52:13] Verified work/wudata_07.edr
[19:52:13] Verified work/wudata_07.xtc
[19:52:13] Completed 91%
[19:52:13] mdrun_gpu returned
[19:52:13] Calculated & specified T inconsisitent
[19:52:13]
[19:52:13] Folding@home Core Shutdown: UNSTABLE_MACHINE
[19:52:17] CoreStatus = 7A (122)
[19:52:17] Sending work to server
[19:52:17] Project: 4748 (Run 1, Clone 14, Gen 7)
[19:52:17] - Error: Could not get length of results file work/wuresults_07.dat
[19:52:17] - Error: Could not read unit 07 file. Removing from queue.
[19:52:17] Trying to send all finished work units
[19:52:17] + No unsent completed units remaining.
[19:52:17] - Preparing to get new work unit...
[19:52:17] + Attempting to get work packet
[19:52:17] - Will indicate memory of 3327 MB
[19:52:17] - Connecting to assignment server
[19:52:17] Connecting to http://assign-GPU.stanford.edu:8080/
[19:52:21] Posted data.
[19:52:21] Initial: 40AB; - Successful: assigned to (171.64.65.103).
[19:52:21] + News From Folding@Home: GPU folding beta
[19:52:22] Loaded queue successfully.
[19:52:22] Connecting to http://171.64.65.103:8080/
[19:52:22] Posted data.
[19:52:22] Initial: 0000; - Receiving payload (expected size: 81353)
[19:52:24] - Downloaded at ~39 kB/s
[19:52:24] - Averaged speed for that direction ~47 kB/s
[19:52:24] + Received work.
[19:52:24] Trying to send all finished work units
[19:52:24] + No unsent completed units remaining.
[19:52:24] + Closed connections
[19:52:29]
[19:52:29] + Processing work unit
[19:52:29] Core required: FahCore_12.exe
[19:52:29] Core found.
[19:52:29] Working on queue slot 08 [December 7 19:52:29 UTC]
[19:52:29] + Working ...
[19:52:29] - Calling '.\FahCore_12.exe -dir work/ -suffix 08 -checkpoint 15 -service -forceasm -verbose -lifeline 3852 -version 620'
[19:52:29]
[19:52:29] *------------------------------*
[19:52:29] Folding@Home GPU Core - Beta
[19:52:29] Version 1.20 (Wed Nov 19 14:15:53 PST 2008)
[19:52:29]
[19:52:29] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[19:52:29] Build host: amoeba
[19:52:29] Board Type: AMD
[19:52:29] Core      :
[19:52:29] Preparing to commence simulation
[19:52:29] - Assembly optimizations manually forced on.
[19:52:29] - Not checking prior termination.
[19:52:29] - Expanded 80841 -> 408077 (decompressed 504.7 percent)
[19:52:29] Called DecompressByteArray: compressed_data_size=80841 data_size=408077, decompressed_data_size=408077 diff=0
[19:52:29] - Digital signature verified
[19:52:29]
[19:52:29] Project: 5650 (Run 0, Clone 63, Gen 34)
[19:52:29]
[19:52:29] Assembly optimizations on if available.
[19:52:29] Entering M.D.
[19:52:36] Working on CMF
[19:52:36] Client config found, loading data.
[19:52:36] Starting GUI Server
[19:54:51] Completed 1%
[19:56:57] Completed 2%
A little snippet from that:
[19:51:57]
[19:51:57]
[19:51:57]
[19:51:57] Core      :
[19:51:57]
[19:51:57]
[19:52:13]
A WU starting from 91% completion (and failing on that spot). What is it?
Update:
Another similar one: http://foldingforum.org/viewtopic.php?f ... 802#p72802
System: HD4830, Windows XP-Pro 32-bit, CAL 8.10.
Re: Project: 4748 (Run 1, Clone 14, Gen 7)
I can't find it again, but there is a thread reporting this somewhere else in the forum ...
Development has figured out what the problem is and a fix will be forthcoming.
