Project: 2620 (Run 32, Clone 19, Gen 17)
Am gettin' the same error that many of the others are getting with the 2620 project, using 6.23(and the same while previously using 6.20) of the Windows systray client, which always shuts down. Due to this, I'm getting no folding done on this machine, so I was wondering how do I turf this WU, and download a new one? Looking in the "Work" folder, it would seem that most of the file names start with "wudata_01", and from the queue info it's obvious that the WU that's the problem is in slot 1, so can I safely assume that I can delete all the files with names starting with "wudata_01"? Would that then initiate the client to download a new WU?
Re: Project: 2620 (Run 32, Clone 19, Gen 17)
Delete the work folder and the queue and you should get a new unit.
Folding whatever I'm sent since March 2006 Beta testing since October 2006. www.FAH-Addict.net Administrator since August 2009.
