I am running the Linux client version 6.02 with the smp parameter. The unitinfo.txt file for the subject work unit is 85,899,512 bytes long. The first 180 bytes from unitinfo.txt are:
Current Work Unit
Tag: P2673R4C19G41
Download time: December 5 19:55:26
Due time: December 11 19:55:26
Progress: 858993529% [||||||||||||||||||||||
The last 40 bytes from unitinfo.txt are:
The last 4 lines from the terminal that the client is running in are:
Writing checkpoint, step 20850140 at Sat Dec 6 07:00:15 2008
[13:14:19] Completed 355008 out of 499998 steps (71%)
Writing checkpoint, step 20855320 at Sat Dec 6 07:15:14 2008
Is there a problem with this work unit?
Project: 2673 (Run 4, Clone 19, Gen 41)
sortofageek
Re: Project: 2673 (Run 4, Clone 19, Gen 41)
There is no problem with this WU that I can see. Four donors have returned it successfully for full credit.
We've implemented some fixes for this that are in a new A2 core. The core is currently in testing.
