Project: 3798 (Run 58, Clone 4, Gen 50)
GoryanskyAleksey
What is this? I've got it several times on different cores. It has 0 points. It is very strange.
P.S. They all are from 171.64.122.139
Last edited by GoryanskyAleksey on Sat Dec 06, 2008 3:23 pm, edited 1 time in total.
Re: Project: 0 (Run 58, Clone 4, Gen 50)
Please post you FAHlog.txt to help us understand better what is going on.
GoryanskyAleksey
Oh! I've got an access to the one of the nodes: time by time the same shit
--- Opening Log file [December 5 13:44:07 UTC]
Folding@Home Client Version 6.20
http://folding.stanford.edu
Launch directory: C:\PROGRA~1\FoldingSMP\Core1
Service: C:\PROGRA~1\FoldingSMP\Core1\fah1
Arguments: -svcstart -verbosity 9 -forceasm -d C:\PROGRA~1\FoldingSMP\Core1 -verbosity 9 -forceasm
Launched as a service.
Entered C:\PROGRA~1\FoldingSMP\Core1 to do work.
Warning:
By using the -forceasm flag, you are overriding
safeguards in the program. If you did not intend to
do this, please restart the program without -forceasm.
If work units are not completing fully (and particularly
if your machine is overclocked), then please discontinue
use of the flag.
[13:44:07] - Ask before connecting: No
[13:44:07] - User name: GoryanskyAleksey (Team 47191)
[13:44:07] - User ID: 577B310954C87A1A
[13:44:07] - Machine ID: 1
[13:44:07]
[13:44:08] Loaded queue successfully.
[13:44:08]
[13:44:08] + Processing work unit
[13:44:08] Core required: FahCore_78.exe
[13:44:08] Core found.
[13:44:08] - Autosending finished units... [December 5 13:44:08 UTC]
[13:44:08] Trying to send all finished work units
[13:44:08] + No unsent completed units remaining.
[13:44:08] - Autosend completed
[13:44:08] Working on queue slot 01 [December 5 13:44:08 UTC]
[13:44:08] + Working ...
[13:44:08] - Calling '.\FahCore_78.exe -dir work/ -suffix 01 -checkpoint 30 -service -forceasm -verbose -lifeline 5864 -version 620'
[13:44:08]
[13:44:08] *------------------------------*
[13:44:08] Folding@Home Gromacs Core
[13:44:08] Version 1.90 (March 8, 2006)
[13:44:08]
[13:44:08] Preparing to commence simulation
[13:44:08] - Assembly optimizations manually forced on.
[13:44:08] - Not checking prior termination.
[13:44:08] - Expanded 238351 -> 1167708 (decompressed 489.9 percent)
[13:44:08] - Starting from initial work packet
[13:44:08]
[13:44:08] Project: 3798 (Run 53, Clone 2, Gen 50)
[13:44:08]
[13:44:08] Assembly optimizations on if available.
[13:44:08] Entering M.D.
[13:44:14] Protein: p3798
[13:44:14]
[13:44:14] Writing local files
[13:45:37] Extra SSE boost OK.
[13:45:37] Writing local files
[13:45:37] Completed 0 out of 1500 steps (0%)
[13:46:05] Writing local files
[13:46:05] Completed 500 out of 1500 steps (33%)
[13:46:33] Writing local files
[13:46:33] Completed 1000 out of 1500 steps (67%)
[13:47:01] Writing local files
[13:47:01] Completed 1500 out of 1500 steps (100%)
[13:47:01] Writing final coordinates.
[13:47:01] Past main M.D. loop
[13:48:01]
[13:48:01] Finished Work Unit:
[13:48:01] - Reading up to 550656 from "work/wudata_01.arc": Read 550656
[13:48:01] - Reading up to 0 from "work/wudata_01.xtc": Read 0
[13:48:01] goefile size: 0
[13:48:01] Leaving Run
[13:48:03] - Writing 573212 bytes of core data to disk...
[13:48:03] Done: 572700 -> 518815 (compressed to 90.5 percent)
[13:48:03] ... Done.
[13:48:03] - Shutting down core
[13:48:03]
[13:48:03] Folding@home Core Shutdown: FINISHED_UNIT
[13:48:06] CoreStatus = 64 (100)
[13:48:06] Unit 1 finished with 99 percent of time to deadline remaining.
[13:48:06] Updated performance fraction: 0.996678
[13:48:06] Sending work to server
[13:48:06] Project: 3798 (Run 53, Clone 2, Gen 50)
[13:48:06] + Attempting to send results [December 5 13:48:06 UTC]
[13:48:06] - Reading file work/wuresults_01.dat from core
[13:48:06] (Read 519327 bytes from disk)
[13:48:06] Connecting to http://171.64.122.139:8080/
[13:48:24] Posted data.
[13:48:24] Initial: 0000; - Uploaded at ~28 kB/s
[13:48:24] - Averaged speed for that direction ~42 kB/s
[13:48:24] + Results successfully sent
[13:48:24] Thank you for your contribution to Folding@Home.
[13:48:24] + Number of Units Completed: 241
... to 06/12/08
[13:25:49] - Preparing to get new work unit...
[13:25:49] + Attempting to get work packet
[13:25:49] - Will indicate memory of 2037 MB
[13:25:49] - Connecting to assignment server
[13:25:49] Connecting to http://assign.stanford.edu:8080/
[13:25:50] Posted data.
[13:25:50] Initial: 40AB; - Successful: assigned to (171.64.122.139).
[13:25:50] + News From Folding@Home: Welcome to Folding@Home
[13:25:50] Loaded queue successfully.
[13:25:50] Connecting to http://171.64.122.139:8080/
[13:25:52] Posted data.
[13:25:52] Initial: 0000; - Receiving payload (expected size: 238223)
[13:25:58] - Downloaded at ~38 kB/s
[13:25:58] - Averaged speed for that direction ~65 kB/s
[13:25:58] + Received work.
[13:25:58] Trying to send all finished work units
[13:25:58] + No unsent completed units remaining.
[13:25:58] + Closed connections
[13:25:58]
[13:25:58] + Processing work unit
[13:25:58] Core required: FahCore_78.exe
[13:25:58] Core found.
[13:25:58] Working on queue slot 00 [December 6 13:25:58 UTC]
[13:25:58] + Working ...
[13:25:58] - Calling '.\FahCore_78.exe -dir work/ -suffix 00 -checkpoint 30 -service -forceasm -verbose -lifeline 5864 -version 620'
[13:25:58]
[13:25:58] *------------------------------*
[13:25:58] Folding@Home Gromacs Core
[13:25:58] Version 1.90 (March 8, 2006)
[13:25:58]
[13:25:58] Preparing to commence simulation
[13:25:58] - Assembly optimizations manually forced on.
[13:25:58] - Not checking prior termination.
[13:25:58] - Expanded 237711 -> 1167708 (decompressed 491.2 percent)
[13:25:58] - Starting from initial work packet
[13:25:58]
[13:25:58] Project: 3798 (Run 18, Clone 1, Gen 50)
[13:25:58]
[13:25:58] Assembly optimizations on if available.
[13:25:58] Entering M.D.
[13:26:05] Protein: p3798
[13:26:05]
[13:26:05] Writing local files
[13:27:28] Extra SSE boost OK.
[13:27:28] Writing local files
[13:27:28] Completed 0 out of 1500 steps (0%)
[13:27:55] Writing local files
[13:27:55] Completed 500 out of 1500 steps (33%)
[13:28:23] Writing local files
[13:28:23] Completed 1000 out of 1500 steps (67%)
[13:28:50] Writing local files
[13:28:50] Completed 1500 out of 1500 steps (100%)
[13:28:50] Writing final coordinates.
[13:28:50] Past main M.D. loop
[13:29:50]
[13:29:50] Finished Work Unit:
[13:29:50] - Reading up to 550656 from "work/wudata_00.arc": Read 550656
[13:29:50] - Reading up to 0 from "work/wudata_00.xtc": Read 0
[13:29:50] goefile size: 0
[13:29:50] Leaving Run
[13:29:53] - Writing 573212 bytes of core data to disk...
[13:29:54] Done: 572700 -> 518235 (compressed to 90.4 percent)
[13:29:54] ... Done.
[13:29:54] - Shutting down core
[13:29:54]
[13:29:54] Folding@home Core Shutdown: FINISHED_UNIT
[13:29:56] CoreStatus = 64 (100)
[13:29:56] Unit 0 finished with 100 percent of time to deadline remaining.
[13:29:56] Updated performance fraction: 0.998621
[13:29:56] Sending work to server
[13:29:56] Project: 3798 (Run 18, Clone 1, Gen 50)
[13:29:56] + Attempting to send results [December 6 13:29:56 UTC]
[13:29:56] - Reading file work/wuresults_00.dat from core
[13:29:56] (Read 518747 bytes from disk)
[13:29:56] Connecting to http://171.64.122.139:8080/
[13:30:06] Posted data.
[13:30:06] Initial: 0000; - Uploaded at ~50 kB/s
[13:30:06] - Averaged speed for that direction ~65 kB/s
[13:30:06] + Results successfully sent
[13:30:06] Thank you for your contribution to Folding@Home.
[13:30:06] + Number of Units Completed: 437
[13:30:10] Trying to send all finished work units
[13:30:10] + No unsent completed units remaining.
[13:30:10] - Preparing to get new work unit...
[13:30:10] + Attempting to get work packet
[13:30:10] - Will indicate memory of 2037 MB
[13:30:10] - Connecting to assignment server
[13:30:10] Connecting to http://assign.stanford.edu:8080/
[13:30:11] Posted data.
[13:30:11] Initial: 40AB; - Successful: assigned to (171.64.122.139).
[13:30:11] + News From Folding@Home: Welcome to Folding@Home
[13:30:11] Loaded queue successfully.
[13:30:11] Connecting to http://171.64.122.139:8080/
[13:30:13] Posted data.
[13:30:13] Initial: 0000; - Receiving payload (expected size: 238407)
[13:30:17] - Downloaded at ~58 kB/s
[13:30:17] - Averaged speed for that direction ~63 kB/s
[13:30:17] + Received work.
[13:30:17] Trying to send all finished work units
[13:30:17] + No unsent completed units remaining.
[13:30:17] + Closed connections
[13:30:17]
[13:30:17] + Processing work unit
[13:30:17] Core required: FahCore_78.exe
[13:30:17] Core found.
[13:30:17] Working on queue slot 01 [December 6 13:30:17 UTC]
[13:30:17] + Working ...
[13:30:17] - Calling '.\FahCore_78.exe -dir work/ -suffix 01 -checkpoint 30 -service -forceasm -verbose -lifeline 5864 -version 620'
[13:30:17]
[13:30:17] *------------------------------*
[13:30:17] Folding@Home Gromacs Core
[13:30:17] Version 1.90 (March 8, 2006)
[13:30:17]
[13:30:17] Preparing to commence simulation
[13:30:17] - Assembly optimizations manually forced on.
[13:30:17] - Not checking prior termination.
[13:30:17] - Expanded 237895 -> 1167708 (decompressed 490.8 percent)
[13:30:17] - Starting from initial work packet
[13:30:17]
[13:30:17] Project: 3798 (Run 61, Clone 0, Gen 50)
[13:30:17]
[13:30:17] Assembly optimizations on if available.
[13:30:17] Entering M.D.
[13:30:24] Protein: p3798
[13:30:24]
[13:30:24] Writing local files
[13:31:46] Extra SSE boost OK.
[13:31:46] Writing local files
[13:31:46] Completed 0 out of 1500 steps (0%)
[13:32:14] Writing local files
[13:32:14] Completed 500 out of 1500 steps (33%)
[13:32:42] Writing local files
[13:32:42] Completed 1000 out of 1500 steps (67%)
[13:33:09] Writing local files
[13:33:09] Completed 1500 out of 1500 steps (100%)
[13:33:09] Writing final coordinates.
[13:33:09] Past main M.D. loop
WangFeiHong
there are 3 projects 3798 in ur logfile but not any project 0 (goryan)
GoryanskyAleksey
Right... Project 0 was in Fahmon... Sorry
WangFeiHong
Re: Project: 3798 (Run 58, Clone 4, Gen 50)
http://fah-web.stanford.edu/cgi-bin/fahproject?p=3798
Project 3798
This project is just to test some new FAH code.
Project 3798
GoryanskyAleksey
sortofageek
These are short, 5-point WUs. The purpose is to test server code to make sure it works under certain conditions. Once the code is proven satisfactory, the testing will end. So, you are helping Pande Group make the server(s) run better. Thank you.
Hi GoryanskyAleksey (team 47191),
Your WU (P3798 R53 C2 G50) was added to the stats database on 2008-12-05 06:24:27 for 5 points of credit.
Your WU (P3798 R18 C1 G50) was added to the stats database on 2008-12-06 06:22:39 for 5 points of credit.
Your WU (P3798 R61 C0 G50) was added to the stats database on 2008-12-06 06:22:39 for 5 points of credit.
VijayPande
- Pande Group Member
Sortofageek is exactly right. We are intentionally pounding the new server code hard to put it through its paces. So far, it's handling very well, behaving much better than the old one (5x faster, uses fewer resources, handles much higher netloads much better).
Prof. Vijay Pande, PhD
Chair, Biophysics
Stanford University
Chair, Biophysics
Stanford University
uncle fuzzy
1 1/2 minutes to complete. I was doing these every other WU on one client for the last few days. Kinda freaked me when I first saw them.
[13:10:55] Project: 3798 (Run 67, Clone 0, Gen 50)
[13:10:55]
[13:10:55] Assembly optimizations on if available.
[13:10:55] Entering M.D.
[13:11:01] Protein: p3798
[13:11:01]
[13:11:01] Writing local files
[13:12:25] Extra SSE boost OK.
[13:12:25] Writing local files
[13:12:25] Completed 0 out of 1500 steps (0%)
[13:12:55] Writing local files
[13:12:55] Completed 500 out of 1500 steps (33%)
[13:13:25] Writing local files
[13:13:25] Completed 1000 out of 1500 steps (67%)
[13:13:56] Writing local files
[13:13:56] Completed 1500 out of 1500 steps (100%)
[13:13:56] Writing final coordinates.
[13:13:56] Past main M.D. loop
[13:14:56]
[13:14:56] Finished Work Unit:
[13:14:56] - Reading up to 550656 from "work/wudata_03.arc": Read 550656
[13:14:56] - Reading up to 0 from "work/wudata_03.xtc": Read 0
[13:14:56] goefile size: 0
[13:14:56] Leaving Run
[13:15:00] - Writing 573212 bytes of core data to disk...
[13:15:00] Done: 572700 -> 517607 (compressed to 90.3 percent)
[13:15:00] ... Done.
[13:15:00] - Shutting down core
[13:15:00]
[13:15:00] Folding@home Core Shutdown: FINISHED_UNIT
[13:15:03] CoreStatus = 64 (100)
[13:15:03] Unit 3 finished with 100 percent of time to deadline remaining.
[13:15:03] Updated performance fraction: 0.796082
[13:15:03] Sending work to server
[13:15:03] Project: 3798 (Run 67, Clone 0, Gen 50)
[13:15:03] + Attempting to send results [December 4 13:15:03 UTC]
[13:15:21] Project: 3798 (Run 75, Clone 0, Gen 22)
[13:15:21]
[13:15:21] Assembly optimizations on if available.
[13:15:21] Entering M.D.
[13:15:27] Protein: p3798
[13:15:27]
[13:15:27] Writing local files
[13:16:51] Extra SSE boost OK.
[13:16:51] Writing local files
[13:16:51] Completed 0 out of 1500 steps (0%)
[13:17:21] Writing local files
[13:17:21] Completed 500 out of 1500 steps (33%)
[13:17:51] Writing local files
[13:17:51] Completed 1000 out of 1500 steps (67%)
[13:18:20] Writing local files
[13:18:20] Completed 1500 out of 1500 steps (100%)
[13:18:20] Writing final coordinates.
[13:18:20] Past main M.D. loop
[13:19:20]
[13:19:20] Finished Work Unit:
[13:19:20] - Reading up to 550656 from "work/wudata_04.arc": Read 550656
[13:19:20] - Reading up to 0 from "work/wudata_04.xtc": Read 0
[13:19:20] goefile size: 0
[13:19:20] Leaving Run
[13:19:21] - Writing 573212 bytes of core data to disk...
[13:19:21] Done: 572700 -> 518121 (compressed to 90.4 percent)
[13:19:21] ... Done.
[13:19:21] - Shutting down core
[13:19:21]
[13:19:21] Folding@home Core Shutdown: FINISHED_UNIT
[13:19:25] CoreStatus = 64 (100)
[13:19:25] Unit 4 finished with 100 percent of time to deadline remaining.
[13:19:25] Updated performance fraction: 0.836583
[13:19:25] Sending work to server
[13:19:25] Project: 3798 (Run 75, Clone 0, Gen 22)
[13:19:25] + Attempting to send results [December 4 13:19:25 UTC]
[23:02:40] Project: 3798 (Run 66, Clone 0, Gen 50)
[23:02:40]
[23:02:40] Assembly optimizations on if available.
[23:02:40] Entering M.D.
[23:02:46] Protein: p3798
[23:02:46]
[23:02:46] Writing local files
[23:04:09] Extra SSE boost OK.
[23:04:09] Writing local files
[23:04:09] Completed 0 out of 1500 steps (0%)
[23:04:39] Writing local files
[23:04:39] Completed 500 out of 1500 steps (33%)
[23:05:08] Writing local files
[23:05:08] Completed 1000 out of 1500 steps (67%)
[23:05:38] Writing local files
[23:05:38] Completed 1500 out of 1500 steps (100%)
[23:05:38] Writing final coordinates.
[23:05:38] Past main M.D. loop
[23:06:38]
[23:06:38] Finished Work Unit:
[23:06:38] - Reading up to 550656 from "work/wudata_07.arc": Read 550656
[23:06:38] - Reading up to 0 from "work/wudata_07.xtc": Read 0
[23:06:38] goefile size: 0
[23:06:38] Leaving Run
[23:06:40] - Writing 573212 bytes of core data to disk...
[23:06:40] Done: 572700 -> 518551 (compressed to 90.5 percent)
[23:06:40] ... Done.
[23:06:40] - Shutting down core
[23:06:40]
[23:06:40] Folding@home Core Shutdown: FINISHED_UNIT
[23:06:44] CoreStatus = 64 (100)
[23:06:44] Unit 7 finished with 100 percent of time to deadline remaining.
[23:06:44] Updated performance fraction: 0.893140
[23:06:44] Sending work to server
[23:06:44] Project: 3798 (Run 66, Clone 0, Gen 50)
[23:06:44] + Attempting to send results [December 4 23:06:44 UTC]
[23:07:12] Project: 3798 (Run 24, Clone 3, Gen 50)
[23:07:12]
[23:07:12] Assembly optimizations on if available.
[23:07:12] Entering M.D.
[23:07:18] Protein: p3798
[23:07:18]
[23:07:18] Writing local files
[23:08:41] Extra SSE boost OK.
[23:08:41] Writing local files
[23:08:41] Completed 0 out of 1500 steps (0%)
[23:09:11] Writing local files
[23:09:11] Completed 500 out of 1500 steps (33%)
[23:09:41] Writing local files
[23:09:41] Completed 1000 out of 1500 steps (67%)
[23:10:10] Writing local files
[23:10:10] Completed 1500 out of 1500 steps (100%)
[23:10:10] Writing final coordinates.
[23:10:11] Past main M.D. loop
[23:11:11]
[23:11:11] Finished Work Unit:
[23:11:11] - Reading up to 550656 from "work/wudata_08.arc": Read 550656
[23:11:11] - Reading up to 0 from "work/wudata_08.xtc": Read 0
[23:11:11] goefile size: 0
[23:11:11] Leaving Run
[23:11:12] - Writing 573212 bytes of core data to disk...
[23:11:12] Done: 572700 -> 518973 (compressed to 90.6 percent)
[23:11:13] ... Done.
[23:11:13] - Shutting down core
[23:11:13]
[23:11:13] Folding@home Core Shutdown: FINISHED_UNIT
[23:11:16] CoreStatus = 64 (100)
[23:11:16] Unit 8 finished with 100 percent of time to deadline remaining.
[23:11:16] Updated performance fraction: 0.914230
[23:11:16] Sending work to server
[23:11:16] Project: 3798 (Run 24, Clone 3, Gen 50)
[23:11:16] + Attempting to send results [December 4 23:11:16 UTC]
[23:11:48] Project: 3798 (Run 14, Clone 3, Gen 50)
[23:11:48]
[23:11:48] Assembly optimizations on if available.
[23:11:48] Entering M.D.
[23:11:54] Protein: p3798
[23:11:54]
[23:11:54] Writing local files
[23:13:16] Extra SSE boost OK.
[23:13:17] Writing local files
[23:13:17] Completed 0 out of 1500 steps (0%)
[23:13:46] Writing local files
[23:13:46] Completed 500 out of 1500 steps (33%)
[23:14:16] Writing local files
[23:14:16] Completed 1000 out of 1500 steps (67%)
[23:14:46] Writing local files
[23:14:46] Completed 1500 out of 1500 steps (100%)
[23:14:46] Writing final coordinates.
[23:14:46] Past main M.D. loop
[23:15:46]
[23:15:46] Finished Work Unit:
[23:15:46] - Reading up to 550656 from "work/wudata_09.arc": Read 550656
[23:15:46] - Reading up to 0 from "work/wudata_09.xtc": Read 0
[23:15:46] goefile size: 0
[23:15:46] Leaving Run
[23:15:48] - Writing 573212 bytes of core data to disk...
[23:15:48] Done: 572700 -> 518742 (compressed to 90.5 percent)
[23:15:48] ... Done.
[23:15:48] - Shutting down core
[23:15:48]
[23:15:48] Folding@home Core Shutdown: FINISHED_UNIT
[23:15:52] CoreStatus = 64 (100)
[23:15:52] Unit 9 finished with 100 percent of time to deadline remaining.
[23:15:52] Updated performance fraction: 0.931101
[23:15:52] Sending work to server
[23:15:52] Project: 3798 (Run 14, Clone 3, Gen 50)
[23:15:52] + Attempting to send results [December 4 23:15:52 UTC]
[17:56:12] Project: 3798 (Run 44, Clone 0, Gen 50)
[17:56:12]
[17:56:12] Assembly optimizations on if available.
[17:56:12] Entering M.D.
[17:56:18] Protein: p3798
[17:56:18]
[17:56:18] Writing local files
[17:57:41] Extra SSE boost OK.
[17:57:41] Writing local files
[17:57:41] Completed 0 out of 1500 steps (0%)
[17:58:11] Writing local files
[17:58:11] Completed 500 out of 1500 steps (33%)
[17:58:41] Writing local files
[17:58:41] Completed 1000 out of 1500 steps (67%)
[17:59:11] Writing local files
[17:59:11] Completed 1500 out of 1500 steps (100%)
[17:59:11] Writing final coordinates.
[17:59:11] Past main M.D. loop
[18:00:11]
[18:00:11] Finished Work Unit:
[18:00:11] - Reading up to 550656 from "work/wudata_01.arc": Read 550656
[18:00:11] - Reading up to 0 from "work/wudata_01.xtc": Read 0
[18:00:11] goefile size: 0
[18:00:11] Leaving Run
[18:00:12] - Writing 573212 bytes of core data to disk...
[18:00:13] Done: 572700 -> 518710 (compressed to 90.5 percent)
[18:00:13] ... Done.
[18:00:13] - Shutting down core
[18:00:13]
[18:00:13] Folding@home Core Shutdown: FINISHED_UNIT
[18:00:16] CoreStatus = 64 (100)
[18:00:16] Unit 1 finished with 100 percent of time to deadline remaining.
[18:00:16] Updated performance fraction: 0.949937
[18:00:16] Sending work to server
[18:00:16] Project: 3798 (Run 44, Clone 0, Gen 50)
[18:00:16] + Attempting to send results [December 6 18:00:16 UTC]
[18:01:34] Project: 3798 (Run 83, Clone 4, Gen 50)
[18:01:34]
[18:01:34] Assembly optimizations on if available.
[18:01:34] Entering M.D.
[18:01:40] Protein: p3798
[18:01:40]
[18:01:40] Writing local files
[18:03:03] Extra SSE boost OK.
[18:03:03] Writing local files
[18:03:03] Completed 0 out of 1500 steps (0%)
[18:03:33] Writing local files
[18:03:33] Completed 500 out of 1500 steps (33%)
[18:04:03] Writing local files
[18:04:03] Completed 1000 out of 1500 steps (67%)
[18:04:32] Writing local files
[18:04:32] Completed 1500 out of 1500 steps (100%)
[18:04:32] Writing final coordinates.
[18:04:33] Past main M.D. loop
[18:05:33]
[18:05:33] Finished Work Unit:
[18:05:33] - Reading up to 550656 from "work/wudata_02.arc": Read 550656
[18:05:33] - Reading up to 0 from "work/wudata_02.xtc": Read 0
[18:05:33] goefile size: 0
[18:05:33] Leaving Run
[18:05:34] - Writing 573212 bytes of core data to disk...
[18:05:34] Done: 572700 -> 518715 (compressed to 90.5 percent)
[18:05:34] ... Done.
[18:05:34] - Shutting down core
[18:05:34]
[18:05:34] Folding@home Core Shutdown: FINISHED_UNIT
[18:05:38] CoreStatus = 64 (100)
[18:05:38] Unit 2 finished with 100 percent of time to deadline remaining.
[18:05:38] Updated performance fraction: 0.959666
[18:05:38] Sending work to server
[18:05:38] Project: 3798 (Run 83, Clone 4, Gen 50)
[18:05:38] + Attempting to send results [December 6 18:05:38 UTC]
[21:12:57] Project: 3798 (Run 48, Clone 0, Gen 22)
[21:12:57]
[21:12:57] Assembly optimizations on if available.
[21:12:57] Entering M.D.
[21:13:03] Protein: p3798
[21:13:03]
[21:13:03] Writing local files
[21:14:26] Extra SSE boost OK.
[21:14:26] Writing local files
[21:14:26] Completed 0 out of 1500 steps (0%)
[21:14:56] Writing local files
[21:14:56] Completed 500 out of 1500 steps (33%)
[21:15:25] Writing local files
[21:15:26] Completed 1000 out of 1500 steps (67%)
[21:15:55] Writing local files
[21:15:55] Completed 1500 out of 1500 steps (100%)
[21:15:55] Writing final coordinates.
[21:15:55] Past main M.D. loop
[21:16:55]
[21:16:55] Finished Work Unit:
[21:16:55] - Reading up to 550656 from "work/wudata_05.arc": Read 550656
[21:16:55] - Reading up to 0 from "work/wudata_05.xtc": Read 0
[21:16:55] goefile size: 0
[21:16:55] Leaving Run
[21:16:58] - Writing 573212 bytes of core data to disk...
[21:16:58] Done: 572700 -> 518362 (compressed to 90.5 percent)
[21:16:58] ... Done.
[21:16:58] - Shutting down core
[21:16:58]
[21:16:58] Folding@home Core Shutdown: FINISHED_UNIT
[21:17:01] CoreStatus = 64 (100)
[21:17:01] Unit 5 finished with 100 percent of time to deadline remaining.
[21:17:01] Updated performance fraction: 0.972287
[21:17:01] Sending work to server
[21:17:01] Project: 3798 (Run 48, Clone 0, Gen 22)
[21:17:01] + Attempting to send results [December 6 21:17:01 UTC]
[21:17:38] Project: 3798 (Run 48, Clone 0, Gen 23)
[21:17:38]
[21:17:38] Assembly optimizations on if available.
[21:17:38] Entering M.D.
[21:17:44] Protein: p3798
[21:17:44]
[21:17:44] Writing local files
[21:19:06] Extra SSE boost OK.
[21:19:06] Writing local files
[21:19:06] Completed 0 out of 1500 steps (0%)
[21:19:36] Writing local files
[21:19:36] Completed 500 out of 1500 steps (33%)
[21:20:06] Writing local files
[21:20:06] Completed 1000 out of 1500 steps (67%)
[21:20:36] Writing local files
[21:20:36] Completed 1500 out of 1500 steps (100%)
[21:20:36] Writing final coordinates.
[21:20:36] Past main M.D. loop
[21:21:36]
[21:21:36] Finished Work Unit:
[21:21:36] - Reading up to 550656 from "work/wudata_06.arc": Read 550656
[21:21:36] - Reading up to 0 from "work/wudata_06.xtc": Read 0
[21:21:36] goefile size: 0
[21:21:36] Leaving Run
[21:21:38] - Writing 573212 bytes of core data to disk...
[21:21:38] Done: 572700 -> 518728 (compressed to 90.5 percent)
[21:21:38] ... Done.
[21:21:38] - Shutting down core
[21:21:38]
[21:21:38] Folding@home Core Shutdown: FINISHED_UNIT
[21:21:41] CoreStatus = 64 (100)
[21:21:41] Unit 6 finished with 100 percent of time to deadline remaining.
[21:21:41] Updated performance fraction: 0.977548
[21:21:41] Sending work to server
[21:21:41] Project: 3798 (Run 48, Clone 0, Gen 23)
[21:21:41] + Attempting to send results [December 6 21:21:41 UTC]
[21:22:14] Project: 3798 (Run 48, Clone 0, Gen 25)
[21:22:14]
[21:22:14] Assembly optimizations on if available.
[21:22:14] Entering M.D.
[21:22:20] Protein: p3798
[21:22:20]
[21:22:20] Writing local files
[21:23:43] Extra SSE boost OK.
[21:23:43] Writing local files
[21:23:43] Completed 0 out of 1500 steps (0%)
[21:24:12] Writing local files
[21:24:12] Completed 500 out of 1500 steps (33%)
[21:24:42] Writing local files
[21:24:42] Completed 1000 out of 1500 steps (67%)
[21:25:12] Writing local files
[21:25:12] Completed 1500 out of 1500 steps (100%)
[21:25:12] Writing final coordinates.
[21:25:12] Past main M.D. loop
[21:26:12]
[21:26:12] Finished Work Unit:
[21:26:12] - Reading up to 550656 from "work/wudata_07.arc": Read 550656
[21:26:12] - Reading up to 0 from "work/wudata_07.xtc": Read 0
[21:26:12] goefile size: 0
[21:26:12] Leaving Run
[21:26:14] - Writing 573212 bytes of core data to disk...
[21:26:14] Done: 572700 -> 518873 (compressed to 90.6 percent)
[21:26:14] ... Done.
[21:26:14] - Shutting down core
[21:26:14]
[21:26:14] Folding@home Core Shutdown: FINISHED_UNIT
[21:26:17] CoreStatus = 64 (100)
[21:26:17] Unit 7 finished with 100 percent of time to deadline remaining.
[21:26:17] Updated performance fraction: 0.981756
[21:26:17] Sending work to server
[21:26:17] Project: 3798 (Run 48, Clone 0, Gen 25)
[21:26:17] + Attempting to send results [December 6 21:26:17 UTC]Proud to crash my machines as a Beta Tester!
sortofageek
I didn't think anything could freak the uncle fuzzy.
