Project: 2485 (Run 102, Clone 31, Gen 0) EUE @ 45%
brityank
Post by brityank »
CP is Intel 6420 @ 2.13GHz 2GB RAM WinXP/SP2 - Core Temp 44ºC.
New WU active - Project: 2483 (Run 260, Clone 33, Gen 3)
[00:57:31] Working on Unit 01 [December 3 00:57:31]
[00:57:31] + Working ...
[00:57:31] - Calling 'FahCore_78.exe -dir work/ -suffix 01 -priority 96 -checkpoint 15 -verbose -lifeline 216 -version 504'
[00:57:31]
[00:57:31] *------------------------------*
[00:57:31] Folding@Home Gromacs Core
[00:57:31] Version 1.90 (March 8, 2006)
[00:57:31]
[00:57:31] Preparing to commence simulation
[00:57:31] - Looking at optimizations...
[00:57:31] - Created dyn
[00:57:31] - Files status OK
[00:57:34] - Expanded 2214694 -> 15104445 (decompressed 682.0 percent)
[00:57:34] - Starting from initial work packet
[00:57:34]
[00:57:34] Project: 2485 (Run 102, Clone 31, Gen 0)
[00:57:34]
[00:57:35] Assembly optimizations on if available.
[00:57:35] Entering M.D.
[00:57:42] Protein: system
[00:57:42]
[00:57:42] Writing local files
[00:57:45] Extra SSE boost OK.
[00:57:46] Writing local files
[00:57:46] Completed 0 out of 250000 steps  (0)
[01:13:34] Timered checkpoint triggered.
[01:28:35] Timered checkpoint triggered.
[01:32:04] Writing local files
[01:32:04] Completed 2500 out of 250000 steps  (1)
 - - - - - snip - - - - - -
[02:47:00] Completed 110000 out of 250000 steps  (44)
[03:03:01] Timered checkpoint triggered.
[03:18:01] Timered checkpoint triggered.
[03:22:04] Writing local files
[03:22:05] Completed 112500 out of 250000 steps  (45)
[03:25:17] Quit 101 - Fatal error:
[03:25:17] Step 112736, time 225.472 (ps)  LINCS WARNING
[03:25:17] relative constraint deviation after LINCS:
[03:25:17] max 0.723583 (between atoms 16869 and 16870) rms 0.008124
[03:25:17]
[03:25:17] Simulation instability has been encountered. The run has entered a
[03:25:17]   state from which no further progress can be made.
[03:25:17] This may be the correct result of the simulation, however if you
[03:25:17]   often see other project units terminating early like this
[03:25:17]   too, you may wish to check the stability of your computer (issues
[03:25:17]   such as high temperature, overclocking, etc.).
[03:25:17] Going to send back what have done.
[03:25:17] logfile size: 20951
[03:25:17] - Writing 21637 bytes of core data to disk...
[03:25:17]   ... Done.
[03:25:17]
[03:25:17] Folding@home Core Shutdown: EARLY_UNIT_END
[03:25:20] CoreStatus = 72 (114)
[03:25:20] Sending work to server
[03:25:20] + Attempting to send results
[03:25:20] - Reading file work/wuresults_01.dat from core
[03:25:20]   (Read 21637 bytes from disk)
[03:25:20] Connecting to http://171.65.103.162:8080/
[03:25:21] Posted data.
[03:25:21] Initial: 0000; - Uploaded at ~22 kB/s
[03:25:21] - Averaged speed for that direction ~39 kB/s
[03:25:21] + Results successfully sent
[03:25:21] Thank you for your contribution to Folding@Home.
[03:25:25] Trying to send all finished work units
[03:25:25] + No unsent completed units remaining.
[03:25:25] - Preparing to get new work unit...
[03:25:25] + Attempting to get work packet
[03:25:25] - Will indicate memory of 1024 MB
[03:25:25] - Connecting to assignment server
[03:25:25] Connecting to http://assign.stanford.edu:8080/
[03:25:26] Posted data.
[03:25:26] Initial: 41AB; - Successful: assigned to (171.65.103.162).
[03:25:26] + News From Folding@Home: Welcome to Folding@Home
[03:25:26] Loaded queue successfully.
[03:25:26] Connecting to http://171.65.103.162:8080/
[03:25:32] Posted data.
[03:25:32] Initial: 0000; - Receiving payload (expected size: 2984514)
[03:25:48] - Downloaded at ~182 kB/s
[03:25:48] - Averaged speed for that direction ~147 kB/s
[03:25:48] + Received work.
[03:25:48] Trying to send all finished work units
[03:25:48] + No unsent completed units remaining.
[03:25:48] + Closed connections
[03:25:53]
[03:25:53] + Processing work unit
[03:25:53] Core required: FahCore_78.exe
[03:25:53] Core found.
[03:25:53] Working on Unit 02 [December 4 03:25:53]
Submitted for reference and tracking.
... ... Free Republic Folders - A Tribute to Ronald Reagan ... ...
Re: Project: 2485 (Run 102, Clone 31, Gen 0) EUE @ 45%
There is another report for partial credit. No one was able to complete it yet.
brityank
Post by brityank »
Thanks for checking, toTOW. I looked through the listings but didn't see this one listed. I get an EUE about every four months or so, and usually find someone else has already listed the WU. Cheers! 8-)
ppetrone
Pande Group Member
Post by ppetrone »
Thanks for the report.
Keeping track of it.
Best,
Paula
sortofageek
Post by sortofageek »
Completed successfully on 2008-12-08 02:24:06 for 905 points of credit by another donor.
