Project: 2674 (Run 2, Clone 86, Gen 68)
biodoc
Post by biodoc »
The step times of project 2674 (1920 points) are similar to to project 2673 (3840 points).
2674 (1920 points):
Min. Time / Frame : 4mn 56s - 2802.16 ppd
Avg. Time / Frame : 4mn 56s - 2802.16 ppd
Cur. Time / Frame : 5mn 14s - 2641.53 ppd
R3F. Time / Frame : 5mn 17s - 2616.53 ppd
Eff. Time / Frame : 2mn 30s - 5529.60 ppd
2673 on same machine (3840 points) :
Cur. Time / Frame : 5mn 12s - 2658.46 ppd
Thanks in advance!
Re: Project: 2674 (Run 2, Clone 86, Gen 68)
How is it possible to get the same PPD in both cases :?:
biodoc
Post by biodoc »
That's my question!
Perhaps there's a mistake on points assignment?
Or is it some issue on my end?
Are your sure that your psummary is up-to-date (I assume it's under fahmon) ?
biodoc
Post by biodoc »
Yes, this is fahmon and I did run an "project update".
Computer: Q6600@3.24GHz running ubuntu linux 8.04
1xSMP= 5400 ppd
I'm also running 1xGPU under wine (8800GT) on the same computer.
Oddly enough, another 2674 WU just loaded and now the ppd is back up to 5400 ppd. (Project: 2674 (Run 3, Clone 145, Gen 55))
Must have been an issue with fahmon , I guess. :?: 'cause the step times are the same.
Bottom line ignore OP! :shock:
