[01:23:45] - Starting from initial work packet
[01:23:45]
[01:23:45] Project: 3798 (Run 56, Clone 2, Gen 4)
[01:23:45]
[01:23:45] Assembly optimizations on if available.
[01:23:45] Entering M.D.
[01:23:50] + New frame time estimate; Working...
[01:23:51] Protein: p3798
[01:23:51]
[01:23:51] Writing local files
[01:23:55] + New frame time estimate; Working...
[01:25:06] Extra SSE boost OK.
[01:25:06] Writing local files
[01:25:06] Completed 0 out of 1500 steps (0)
[01:25:53] Writing local files
[01:25:53] Completed 500 out of 1500 steps (33)
[01:26:41] Writing local files
[01:26:41] Completed 1000 out of 1500 steps (67)
[01:26:45] + Writing 'sec_per_frame = 2390.000000' to config
[01:26:45] + Working ...+ New frame time estimate; Working...
[01:26:55] + New frame time estimate; Working...
[01:27:00] + New frame time estimate; Working...
[01:27:05] + New frame time estimate; Working...
[01:27:10] + New frame time estimate; Working...
[01:27:15] + New frame time estimate; Working...
[01:27:20] + New frame time estimate; Working...
[01:27:25] + New frame time estimate; Working...
[01:27:28] Writing local files
[01:27:28] Completed 1500 out of 1500 steps (100)
[01:27:28] Writing final coordinates.
[01:27:28] Past main M.D. loop
[01:27:30] + New frame time estimate; Working...
[01:27:35] + New frame time estimate; Working...
[01:27:40] + New frame time estimate; Working...
[01:27:45] + New frame time estimate; Working...
[01:27:50] + New frame time estimate; Working...
[01:27:55] + New frame time estimate; Working...
[01:28:00] + New frame time estimate; Working...
[01:28:05] + New frame time estimate; Working...
[01:28:10] + New frame time estimate; Working...
[01:28:15] + New frame time estimate; Working...
[01:28:20] + New frame time estimate; Working...
[01:28:25] + New frame time estimate; Working...
[01:28:28]
[01:28:28] Finished Work Unit:
[01:28:28] - Reading up to 550656 from "work/wudata_09.arc": Read 550656
[01:28:28] - Reading up to 0 from "work/wudata_09.xtc": Read 0
[01:28:28] goefile size: 0
[01:28:28] Leaving Run
[01:28:30] + New frame time estimate; Working...
[01:28:30] - Writing 573212 bytes of core data to disk...
[01:28:30] Done: 572700 -> 519292 (compressed to 90.6 percent)
[01:28:30] ... Done.
[01:28:30] - Shutting down core
[01:28:30]
[01:28:30] Folding@home Core Shutdown: FINISHED_UNIT
[01:28:33] CoreStatus = 64 (100)
[01:28:33] Unit 9 finished with 100 percent of time to deadline remaining.
[01:28:33] Updated performance fraction: 0.994601
[01:28:33] Sending work to server
[01:28:33] + Attempting to send results
[01:28:33] - Reading file work/wuresults_09.dat from core
[01:28:33] (Read 519804 bytes from disk)
[01:28:33] Connecting to http://171.64.122.139:8080/
[01:30:28] Posted data.
[01:30:28] Initial: 0000; - Uploaded at ~4 kB/s
[01:30:28] - Averaged speed for that direction ~23 kB/s
[01:30:28] + Results successfully sent
[01:30:28] Thank you for your contribution to Folding@Home.
[01:30:28] + Number of Units Completed: 391
[01:30:32] Trying to send all finished work units
[01:30:32] + No unsent completed units remaining.
[01:30:32] - Preparing to get new work unit...
[01:30:32] + Attempting to get work packet
[01:30:32] - Will indicate memory of 2046 MB.
[01:30:32] - Connecting to assignment server
[01:30:32] Connecting to http://assign.stanford.edu:8080/
[01:30:32] Posted data.
[01:30:32] Initial: 40AB; - Successful: assigned to (171.64.122.139).
[01:30:32] + News From Folding@Home: Welcome to Folding@Home
[01:30:32] Loaded queue successfully.
[01:30:32] Connecting to http://171.64.122.139:8080/
[01:30:36] Posted data.
[01:30:36] Initial: 0000; - Receiving payload (expected size: 238411)
[01:33:01] - Downloaded at ~1 kB/s
[01:33:01] - Averaged speed for that direction ~47 kB/s
[01:33:01] + Received work.
[01:33:01] Trying to send all finished work units
[01:33:01] + No unsent completed units remaining.
[01:33:01] + Closed connections
[01:33:01]
[01:33:01] + Processing work unit
[01:33:01] Core required: FahCore_78.exe
[01:33:01] Core found.
[01:33:01] Working on Unit 00 [December 2 01:33:01]
[01:33:01] + Working ...
[01:33:01] - Calling 'FahCore_78.exe -dir work/ -suffix 00 -checkpoint 15 -verbose -lifeline 3908 -version 503'
[01:33:01]
[01:33:01] *------------------------------*
[01:33:01] Folding@Home Gromacs Core
[01:33:01] Version 1.90 (March 8, 2006)
[01:33:01]
[01:33:01] Preparing to commence simulation
[01:33:01] - Looking at optimizations...
[01:33:01] - Created dyn
[01:33:01] - Files status OK
[01:33:01] - Expanded 237899 -> 1167708 (decompressed 490.8 percent)
[01:33:01] - Starting from initial work packet
[01:33:01]
[01:33:01] Project: 3798 (Run 56, Clone 2, Gen 5)
[01:33:01]
[01:33:01] Assembly optimizations on if available.
[01:33:01] Entering M.D.
[01:33:03] + New frame time estimate; Working...
[01:33:07] Protein: p3798
[01:33:07]
[01:33:07] Writing local files
[01:33:08] + New frame time estimate; Working...
[01:34:22] Extra SSE boost OK.
[01:34:22] Writing local files
[01:34:22] Completed 0 out of 1500 steps (0)
[01:35:09] Writing local files
[01:35:09] Completed 500 out of 1500 steps (33)
[01:35:57] Writing local files
[01:35:57] Completed 1000 out of 1500 steps (67)
[01:35:58] + Writing 'sec_per_frame = 553.000000' to config
[01:35:58] + Working ...+ New frame time estimate; Working...
[01:36:08] + New frame time estimate; Working...
[01:36:13] + New frame time estimate; Working...
[01:36:18] + New frame time estimate; Working...
[01:36:23] + New frame time estimate; Working...
[01:36:28] + New frame time estimate; Working...
[01:36:33] + New frame time estimate; Working...
[01:36:38] + New frame time estimate; Working...
[01:36:43] + New frame time estimate; Working...
[01:36:44] Writing local files
[01:36:44] Completed 1500 out of 1500 steps (100)
[01:36:44] Writing final coordinates.
[01:36:44] Past main M.D. loop
[01:36:48] + New frame time estimate; Working...
[01:36:53] + New frame time estimate; Working...
[01:36:58] + New frame time estimate; Working...
[01:37:03] + New frame time estimate; Working...
[01:37:08] + New frame time estimate; Working...
[01:37:13] + New frame time estimate; Working...
[01:37:18] + New frame time estimate; Working...
[01:37:23] + New frame time estimate; Working...
[01:37:28] + New frame time estimate; Working...
[01:37:33] + New frame time estimate; Working...
[01:37:38] + New frame time estimate; Working...
[01:37:43] + New frame time estimate; Working...
[01:37:44]
[01:37:44] Finished Work Unit:
[01:37:44] - Reading up to 550656 from "work/wudata_00.arc": Read 550656
[01:37:44] - Reading up to 0 from "work/wudata_00.xtc": Read 0
[01:37:44] goefile size: 0
[01:37:44] Leaving Run
[01:37:46] - Writing 573212 bytes of core data to disk...
[01:37:47] Done: 572700 -> 519270 (compressed to 90.6 percent)
[01:37:47] ... Done.
[01:37:47] - Shutting down core
[01:37:47]
[01:37:47] Folding@home Core Shutdown: FINISHED_UNIT
