Project: 4625 (Run 3, Clone 6, Gen 44)
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
EUE
[18:15:54] + Closed connections
[18:15:54]
[18:15:54] + Processing work unit
[18:15:54] Core required: FahCore_82.exe
[18:15:54] Core found.
[18:15:54] Working on Unit 09 [November 30 18:15:54]
[18:15:54] + Working ...
[18:15:54] - Calling 'FahCore_82.exe -dir work/ -suffix 09 -checkpoint 15 -forceasm -verbose -lifeline 2504 -version 503'
[18:15:54]
[18:15:54] *------------------------------*
[18:15:54] Folding@Home PMD Core
[18:15:54] Version 1.03 (September 7, 2005)
[18:15:54]
[18:15:54] Preparing to commence simulation
[18:15:54] - Assembly optimizations manually forced on.
[18:15:54] - Not checking prior termination.
[18:15:54] - Expanded 12952 -> 82265 (decompressed 635.1 percent)
[18:15:54]
[18:15:54] Project: 4625 (Run 3, Clone 6, Gen 44)
[18:15:54]
[18:15:54] Assembly optimizations on if available.
[18:15:54] Entering M.D.
[18:15:56] + New frame time estimate; Working...
[18:16:01] Going to send back what have done.
[18:16:01] logfile size: 5649
[18:16:01] - Writing 6169 bytes of core data to disk...
[18:16:01]   ... Done.
[18:16:01]
[18:16:01] Folding@home Core Shutdown: EARLY_UNIT_END
[18:16:01] + New frame time estimate; Working...
[18:16:04] CoreStatus = 72 (114)
[18:16:04] Sending work to server
[18:16:04] + Attempting to send results
[18:16:04] - Reading file work/wuresults_09.dat from core
[18:16:04]   (Read 6169 bytes from disk)
[18:16:04] Connecting to http://169.230.26.30:8080/
[18:16:05] Posted data.
[18:16:05] Initial: 0000; - Uploaded at ~7 kB/s
[18:16:05] - Averaged speed for that direction ~37 kB/s
[18:16:05] + Results successfully sent
[18:16:05] Thank you for your contribution to Folding@Home.
Re: Project: 4625 (Run 3, Clone 6, Gen 44)
There are 5 similar reports : this has been marked as bad.
anko1
Post by anko1 »
Thanks, toTOW.
anandhanju
Post by anandhanju »
Offtopic (sorry anko1):
toTOW, is this a new feature that Mods have nowadays? The ability to mark WUs bad?
Is there any automatic notification or flag that the Mods/ PG see when a WU EUEs multiple times? Or do you mark them based upon reports like these? I asking this because many GPU WU EUEs may not be reported.
Yes that's new.
The moderators are still those who decide if a WU is bad or not judging by the reports posted on the forum, and the data returned by the tool (which been available to us for a long time now).
After a WU is marked as bad, the deletion process should be automatic (I don't know if it's enabled yet ... the feature is brand new).
anandhanju
Great! Thanks for the info.
We certainly will not be marking a WU as bad unless there are a number of similar reports. It's still VERY difficult to tell if it's the WU or the machine.
I'm getting use to some kind of repeated issues (ERROR 0x79, instant EUE on Amber projects, multiple EUE on GPU projects, ...) but I often don't know what to do, and I let the time decide (to see if the same issue happens again, or if someone from PG knows what happened).
anko1
Post by anko1 »
Yes, it must be difficult in some cases. Iirc, on one of my reports, there were 5 EUE, but one person was able to complete it.
PS- anandhanju - I was wondering the same thing. :-)
