Project: 2620 (Run 64, Clone 11, Gen 36)
Escher
Post by Escher »
Imagine that ... another 2620 that fails ...
[20:23:12]
[20:23:12] *------------------------------*
[20:23:12] Folding@Home Gromacs Core
[20:23:12] Version 1.90 (March 8, 2006)
[20:23:12]
[20:23:12] Preparing to commence simulation
[20:23:12] - Looking at optimizations...
[20:23:12] - Created dyn
[20:23:12] - Files status OK
[20:23:13] - Expanded 3301509 -> 6015025 (decompressed 182.1 percent)
[20:23:13] - Starting from initial work packet
[20:23:13]
[20:23:13] Project: 2620 (Run 64, Clone 11, Gen 36)
[20:23:13]
[20:23:13] Assembly optimizations on if available.
[20:23:13] Entering M.D.
[20:23:19] Gromacs error.
[20:23:19]
[20:23:19] Folding@home Core Shutdown: UNKNOWN_ERROR
[20:23:22] CoreStatus = 79 (121)
[20:23:22] Client-core communications error: ERROR 0x79
[20:23:22] This is a sign of more serious problems, shutting down.
Re: Project: 2620 (Run 64, Clone 11, Gen 36)
Thanks for the report, I've marked it as a bad WU and it should be removed soon.
Hammerhead
Post by Hammerhead »
I just got one as well.
[23:43:33] Preparing to commence simulation
[23:43:33] - Looking at optimizations...
[23:43:33] - Created dyn
[23:43:33] - Files status OK
[23:43:35] - Expanded 418330 -> 10609001 (decompressed 2536.0 percent)
[23:43:35] - Starting from initial work packet
[23:43:35]
[23:43:35] Project: 2620 (Run 37, Clone 73, Gen 15)
[23:43:35]
[23:43:35] Assembly optimizations on if available.
[23:43:35] Entering M.D.
[23:43:43] Protein: p2620_p1475_tet1_03_1 t= 20000.00000
[23:43:43]
[23:43:43] Writing local files
[23:43:43] Gromacs error.
[23:43:43]
[23:43:43] Folding@home Core Shutdown: UNKNOWN_ERROR
[23:43:45] CoreStatus = 79 (121)
[23:43:45] Client-core communications error: ERROR 0x79
[23:43:45] This is a sign of more serious problems, shutting down.
Reported this one too :)
Escher
Post by Escher »
Has anyone returned anything from 2620? Seems like the whole line should be scrapped.
ferrisb
Post by ferrisb »
Project 2620 is junk. I have 17 console clients running on 9 machines and they are dropping like flies. In every instance the core shutdown was caused by 2620. I hope they get it fixed soon.
mastergage
Post by mastergage »
I am kinda new.....what do you do when you have this as I am one as well.....can you dump it and get a new WU or what is the best recommendation.....thanks!!!
This is a pretty rare situation so I don't want you drawing any general conclusions from the current situation.
Yes, you can delete the current WU, but it should only be done in really extenuating situations.
alexander94
Post by alexander94 »
hi im new how am i post to get points to get the crown hat
I've sent a mail to Peter to ask him to look at this issue again.
Hammerhead
Bruce,
Sorry but I don't think it's that rare. Recently I had 3 failed 2620 WUs in the past 2 days. Sometimes just deleting the WU works, other times I have to delete the work folder, queue.dat, and unitinfo.txt. These are on Windows XP running 6.23 console.
