Project: 4597 (Run 17, Clone 20, Gen 67)
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
EUE
[04:33:29] + Closed connections
[04:33:29]
[04:33:29] + Processing work unit
[04:33:29] Core required: FahCore_82.exe
[04:33:29] Core found.
[04:33:29] Working on Unit 05 [November 30 04:33:29]
[04:33:29] + Working ...
[04:33:29] - Calling 'FahCore_82.exe -dir work/ -suffix 05 -checkpoint 15 -verbose -lifeline 2764 -version 504'
[04:33:29]
[04:33:29] *------------------------------*
[04:33:29] Folding@Home PMD Core
[04:33:29] Version 1.03 (September 7, 2005)
[04:33:29]
[04:33:29] Preparing to commence simulation
[04:33:29] - Looking at optimizations...
[04:33:29] - Created dyn
[04:33:29] - Files status OK
[04:33:29] - Expanded 10939 -> 72408 (decompressed 661.9 percent)
[04:33:29]
[04:33:29] Project: 4597 (Run 17, Clone 20, Gen 67)
[04:33:29]
[04:33:29] Assembly optimizations on if available.
[04:33:29] Entering M.D.
[04:33:36] Going to send back what have done.
[04:33:36] logfile size: 5649
[04:33:36] - Writing 6169 bytes of core data to disk...
[04:33:36]   ... Done.
[04:33:36]
[04:33:36] Folding@home Core Shutdown: EARLY_UNIT_END
[04:33:39] CoreStatus = 72 (114)
[04:33:39] Sending work to server
[04:33:39] + Attempting to send results
[04:33:39] - Reading file work/wuresults_05.dat from core
[04:33:39]   (Read 6169 bytes from disk)
[04:33:39] Connecting to http://169.230.26.30:8080/
[04:33:40] Posted data.
[04:33:40] Initial: 0000; - Uploaded at ~7 kB/s
[04:33:40] - Averaged speed for that direction ~39 kB/s
[04:33:40] + Results successfully sent
[04:33:40] Thank you for your contribution to Folding@Home.
Re: Project: 4597 (Run 17, Clone 20, Gen 67)
There are 7 similar reports. I've marked this WU as bad, and it should be removed.
anko1
Post by anko1 »
As always, thanks for checking, toTOW.
