Project: 4744 (Run 3, Clone 923, Gen 11)
bollix47
Post by bollix47 »
[20:39:40] + Attempting to get work packet
[20:39:40] - Will indicate memory of 3060 MB
[20:39:40] - Connecting to assignment server
[20:39:40] Connecting to http://assign-GPU.stanford.edu:8080/
[20:39:41] Posted data.
[20:39:41] Initial: 40AB; - Successful: assigned to (171.64.65.103).
[20:39:41] + News From Folding@Home: GPU folding beta
[20:39:41] Loaded queue successfully.
[20:39:41] Connecting to http://171.64.65.103:8080/
[20:39:41] Initial: 0000; - Receiving payload (expected size: 88825)
[20:39:42] - Downloaded at ~86 kB/s
[20:39:42] - Averaged speed for that direction ~86 kB/s
[20:39:42] + Received work.
[20:39:42] Trying to send all finished work units
[20:39:42] + No unsent completed units remaining.
[20:39:42] + Closed connections
[20:39:42]
[20:39:42] + Processing work unit
[20:39:42] Core required: FahCore_11.exe
[20:39:42] Core found.
[20:39:42] Working on queue slot 08 [November 29 20:39:42 UTC]
[20:39:42] + Working ...
[20:39:42] - Calling '.\FahCore_11.exe -dir work/ -suffix 08 -priority 96 -nocpulock -checkpoint 15 -verbose -lifeline 1764 -version 620'
[20:39:42]
[20:39:42] *------------------------------*
[20:39:42] Folding@Home GPU Core - Beta
[20:39:42] Version 1.18 (Mon Oct 13 11:11:30 PDT 2008)
[20:39:42]
[20:39:42] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[20:39:42] Build host: amoeba
[20:39:42] Board Type: AMD
[20:39:42] Core      :
[20:39:42] Preparing to commence simulation
[20:39:42] - Looking at optimizations...
[20:39:42] - Created dyn
[20:39:42] - Files status OK
[20:39:42] - Expanded 88313 -> 447304 (decompressed 506.4 percent)
[20:39:42] Called DecompressByteArray: compressed_data_size=88313 data_size=447304, decompressed_data_size=447304 diff=0
[20:39:42] - Digital signature verified
[20:39:42]
[20:39:42] Project: 4744 (Run 3, Clone 923, Gen 11)
[20:39:42]
[20:39:42] Assembly optimizations on if available.
[20:39:42] Entering M.D.
[20:39:48] Working on p4744_lam5w_300K
[20:39:48] Client config found, loading data.
[20:39:48] Starting GUI Server
[20:39:51] mdrun_gpu returned
[20:39:51] NANs detected on GPU
[20:39:51]
[20:39:51] Folding@home Core Shutdown: UNSTABLE_MACHINE
[20:39:54] CoreStatus = 7A (122)
[20:39:54] Sending work to server
[20:39:54] Project: 4744 (Run 3, Clone 923, Gen 11)
[20:39:54] - Read packet limit of 540015616... Set to 524286976.
[20:39:54] - Error: Could not get length of results file work/wuresults_08.dat
[20:39:54] - Error: Could not read unit 08 file. Removing from queue.
[20:39:54] Trying to send all finished work units
[20:39:54] + No unsent completed units remaining.
[20:39:54] - Preparing to get new work unit...
[20:39:54] + Attempting to get work packet
[20:39:54] - Will indicate memory of 3060 MB
[20:39:54] - Connecting to assignment server
[20:39:54] Connecting to http://assign-GPU.stanford.edu:8080/
[20:39:54] Posted data.
[20:39:54] Initial: 40AB; - Successful: assigned to (171.64.65.103).
[20:39:54] + News From Folding@Home: GPU folding beta
[20:39:54] Loaded queue successfully.
[20:39:54] Connecting to http://171.64.65.103:8080/
[20:39:55] Posted data.
[20:39:55] Initial: 0000; - Receiving payload (expected size: 88825)
[20:39:55] Conversation time very short, giving reduced weight in bandwidth avg
[20:39:55] - Downloaded at ~173 kB/s
[20:39:55] - Averaged speed for that direction ~95 kB/s
[20:39:55] + Received work.
[20:39:55] Trying to send all finished work units
[20:39:55] + No unsent completed units remaining.
[20:39:55] + Closed connections
[20:40:00]
[20:40:00] + Processing work unit
[20:40:00] Core required: FahCore_11.exe
[20:40:00] Core found.
[20:40:00] Working on queue slot 09 [November 29 20:40:00 UTC]
[20:40:00] + Working ...
[20:40:00] - Calling '.\FahCore_11.exe -dir work/ -suffix 09 -priority 96 -nocpulock -checkpoint 15 -verbose -lifeline 1764 -version 620'
[20:40:00]
[20:40:00] *------------------------------*
[20:40:00] Folding@Home GPU Core - Beta
[20:40:00] Version 1.18 (Mon Oct 13 11:11:30 PDT 2008)
[20:40:00]
[20:40:00] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[20:40:00] Build host: amoeba
[20:40:00] Board Type: AMD
[20:40:00] Core      :
[20:40:00] Preparing to commence simulation
[20:40:00] - Looking at optimizations...
[20:40:00] - Created dyn
[20:40:00] - Files status OK
[20:40:00] - Expanded 88313 -> 447304 (decompressed 506.4 percent)
[20:40:00] Called DecompressByteArray: compressed_data_size=88313 data_size=447304, decompressed_data_size=447304 diff=0
[20:40:00] - Digital signature verified
[20:40:00]
[20:40:00] Project: 4744 (Run 3, Clone 923, Gen 11)
[20:40:00]
[20:40:00] Assembly optimizations on if available.
[20:40:00] Entering M.D.
[20:40:06] Working on p4744_lam5w_300K
[20:40:07] Client config found, loading data.
[20:40:07] Starting GUI Server
[20:40:10] mdrun_gpu returned
[20:40:10] NANs detected on GPU
[20:40:10]
[20:40:10] Folding@home Core Shutdown: UNSTABLE_MACHINE
[20:40:13] CoreStatus = 7A (122)
[20:40:13] Sending work to server
[20:40:13] Project: 4744 (Run 3, Clone 923, Gen 11)
[20:40:13] - Read packet limit of 540015616... Set to 524286976.
[20:40:13] - Error: Could not get length of results file work/wuresults_09.dat
[20:40:13] - Error: Could not read unit 09 file. Removing from queue.
[20:40:13] Trying to send all finished work units
[20:40:13] + No unsent completed units remaining.
[20:40:13] - Preparing to get new work unit...
[20:40:13] + Attempting to get work packet
[20:40:13] - Will indicate memory of 3060 MB
[20:40:13] - Connecting to assignment server
[20:40:13] Connecting to http://assign-GPU.stanford.edu:8080/
[20:40:13] Posted data.
[20:40:13] Initial: 40AB; - Successful: assigned to (171.64.65.103).
[20:40:13] + News From Folding@Home: GPU folding beta
[20:40:13] Loaded queue successfully.
[20:40:13] Connecting to http://171.64.65.103:8080/
[20:40:13] Initial: 0000; - Receiving payload (expected size: 88825)
[20:40:14] - Downloaded at ~86 kB/s
[20:40:14] - Averaged speed for that direction ~93 kB/s
[20:40:14] + Received work.
[20:40:14] Trying to send all finished work units
[20:40:14] + No unsent completed units remaining.
[20:40:14] + Closed connections
[20:40:19]
[20:40:19] + Processing work unit
[20:40:19] Core required: FahCore_11.exe
[20:40:19] Core found.
[20:40:19] Working on queue slot 00 [November 29 20:40:19 UTC]
[20:40:19] + Working ...
[20:40:19] - Calling '.\FahCore_11.exe -dir work/ -suffix 00 -priority 96 -nocpulock -checkpoint 15 -verbose -lifeline 1764 -version 620'
[20:40:19]
[20:40:19] *------------------------------*
[20:40:19] Folding@Home GPU Core - Beta
[20:40:19] Version 1.18 (Mon Oct 13 11:11:30 PDT 2008)
[20:40:19]
[20:40:19] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[20:40:19] Build host: amoeba
[20:40:19] Board Type: AMD
[20:40:19] Core      :
[20:40:19] Preparing to commence simulation
[20:40:19] - Looking at optimizations...
[20:40:19] - Created dyn
[20:40:19] - Files status OK
[20:40:19] - Expanded 88313 -> 447304 (decompressed 506.4 percent)
[20:40:19] Called DecompressByteArray: compressed_data_size=88313 data_size=447304, decompressed_data_size=447304 diff=0
[20:40:19] - Digital signature verified
[20:40:19]
[20:40:19] Project: 4744 (Run 3, Clone 923, Gen 11)
[20:40:19]
[20:40:19] Assembly optimizations on if available.
[20:40:19] Entering M.D.
[20:40:25] Working on p4744_lam5w_300K
[20:40:26] Client config found, loading data.
[20:40:26] Starting GUI Server
[20:40:29] mdrun_gpu returned
[20:40:29] NANs detected on GPU
[20:40:29]
[20:40:29] Folding@home Core Shutdown: UNSTABLE_MACHINE
[20:40:32] CoreStatus = 7A (122)
[20:40:32] Sending work to server
[20:40:32] Project: 4744 (Run 3, Clone 923, Gen 11)
[20:40:32] - Read packet limit of 540015616... Set to 524286976.
[20:40:32] - Error: Could not get length of results file work/wuresults_00.dat
[20:40:32] - Error: Could not read unit 00 file. Removing from queue.
[20:40:32] Trying to send all finished work units
[20:40:32] + No unsent completed units remaining.
[20:40:32] - Preparing to get new work unit...
[20:40:32] + Attempting to get work packet
[20:40:32] - Will indicate memory of 3060 MB
[20:40:32] - Connecting to assignment server
[20:40:32] Connecting to http://assign-GPU.stanford.edu:8080/
[20:40:32] Posted data.
[20:40:32] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[20:40:32] + News From Folding@Home: GPU folding beta
[20:40:32] Loaded queue successfully.
[20:40:32] Connecting to http://171.64.65.102:8080/
[20:40:32] Initial: 0000; - Receiving payload (expected size: 68947)
[20:40:33] - Downloaded at ~67 kB/s
[20:40:33] - Averaged speed for that direction ~88 kB/s
[20:40:33] + Received work.
[20:40:33] Trying to send all finished work units
[20:40:33] + No unsent completed units remaining.
[20:40:33] + Closed connections
[20:40:38]
[20:40:38] + Processing work unit
[20:40:38] Core required: FahCore_11.exe
[20:40:38] Core found.
[20:40:38] Working on queue slot 01 [November 29 20:40:38 UTC]
[20:40:38] + Working ...
[20:40:38] - Calling '.\FahCore_11.exe -dir work/ -suffix 01 -priority 96 -nocpulock -checkpoint 15 -verbose -lifeline 1764 -version 620'
[20:40:38]
[20:40:38] *------------------------------*
[20:40:38] Folding@Home GPU Core - Beta
[20:40:38] Version 1.18 (Mon Oct 13 11:11:30 PDT 2008)
[20:40:38]
[20:40:38] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[20:40:38] Build host: amoeba
[20:40:38] Board Type: AMD
[20:40:38] Core      :
[20:40:38] Preparing to commence simulation
[20:40:38] - Looking at optimizations...
[20:40:38] - Created dyn
[20:40:38] - Files status OK
[20:40:38] - Expanded 68435 -> 357580 (decompressed 522.5 percent)
[20:40:38] Called DecompressByteArray: compressed_data_size=68435 data_size=357580, decompressed_data_size=357580 diff=0
[20:40:38] - Digital signature verified
[20:40:38]
[20:40:38] Project: 5746 (Run 4, Clone 8, Gen 28)
[20:40:38]
[20:40:38] Assembly optimizations on if available.
[20:40:38] Entering M.D.
[20:40:44] Working on Protein
[20:40:45] Client config found, loading data.
[20:40:45] Starting GUI Server
[20:42:45] Completed 1%
[20:44:42] Completed 2%
[20:46:40] Completed 3%
Re: Project: 4744 (Run 3, Clone 923, Gen 11)
There's no data for this WU in the DB yet ...
