Separate user stats for CPU's
If there would be separate statistics for CPU PPD, people would buy more CPU's where as now GPU has increasing popularity because PPD system favors it. People buy dual cores because PPD doesn't justify quad cores when there's 3-4 GPU's.
Re: Separate user stats for CPU's
Are you looking for something like that : http://fahinfo.org/
I assume the user based statistics come out after I register? Then it's fine, though I'd rather not register into yet another service.
Thanks.
Thanks.
Service? What service? Fahinfo.org is a web site, and it is great! So is gpu.fahinfo.org.
Click on "WU Search", enter a project number, hit Submit button and select the detail level you want (All CPU, AMD only or Intel only).folding4u wrote:I assume the user based statistics come out after I register? Then it's fine, though I'd rather not register into yet another service.
Thanks.
You can also get global stats with "Average Scores" and "Score lists".
I have to ask because I have done no CPU folding myself.
Doesn't fahinfo import their stats from FAH directly? Or does it require a fahmon data file? If so, does that mean that old stats can't be imported somehow?
codysluder
The official FAH project does not have any reports with information about specific hardware. Fahinfo is based strictly on user-reported data. It's a lot easier to search than something like this: viewtopic.php?f=52&t=3193folding4u wrote:I have to ask because I have done no CPU folding myself.
Sure. Appreciate the confirmation.
