Project: 2665 (Run 2, Clone 597, Gen 68)
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
Bad Core Files. The WU before and after this one completed successfully.
[22:10:54] + Closed connections
[22:10:54]
[22:10:54] + Processing work unit
[22:10:54] Work type a1 not eligible for variable processors
[22:10:54] Core required: FahCore_a1.exe
[22:10:54] Core found.
[22:10:54] Using generic mpiexec calls
[22:10:54] Working on queue slot 01 [November 23 22:10:54 UTC]
[22:10:54] + Working ...
[22:10:54] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 01 -checkpoint 15 -verbose -lifeline 5692 -version 623'
[22:10:57]
[22:10:57] *------------------------------*
[22:10:57] Folding@Home Gromacs SMP Core
[22:10:57] Version 1.74 (March 10, 2007)
[22:10:57]
[22:10:57] Preparing to commence simulation
[22:10:57] - Ensuring status. Please wait.
[22:11:03] - Starting from initial work packet
[22:11:03]
[22:11:03] Project: 2665 (Run 2, Clone 597, Gen 68)
[22:11:03]
[22:11:04] Assembly optimizations on if available.
[22:11:04] Entering M.D.
[22:11:25] al work packet
[22:11:25]
[22:11:25] Project: 2665 (Run 2, Clone 597, Gen 68)
[22:11:25]
[22:11:27] Entering M.D.
[22:11:29] ne 597, Gen 68)
[22:11:29]
[22:11:29] Entering M.D.
[22:11:37] Rejecting checkpoint
[22:11:38] NaN detected: x[28][1]=5.28945 v[28][1]=NaN
[22:11:38] ng output
[22:13:38] ome Core Shutdown: BAD_CORE_FILES
[22:13:38]
[22:13:38] Folding@home Core Shutdown: BAD_CORE_FILES
[22:13:39] CORE_FILES
[22:13:39] Finalizing output
[22:15:43] CoreStatus = 1 (1)
[22:15:43] Sending work to server
[22:15:43] Project: 2665 (Run 2, Clone 597, Gen 68)
[22:15:43] - Error: Could not get length of results file work/wuresults_01.dat
[22:15:43] - Error: Could not read unit 01 file. Removing from queue.
I got the same WU again, twice in a row, with the same results after successfully completing a different WU.
Re: Project: 2665 (Run 2, Clone 597, Gen 68)
Someone was able to submit partial results four times, but it's also an immediate failure :(
anko1
Post by anko1 »
Thanks for checking on all my WUs, toTOW.
