Project: 2665 (Run 2, Clone 563, Gen 69)
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
EUE, but not by much. Probably a network connection, though maybe not, since it actually quit b/f 100%. I set up the loopback adaptor (thanks, Xilion - this is the first EUE I've had since then).
[05:20:59] + Closed connections
[05:20:59]
[05:20:59] + Processing work unit
[05:20:59] Work type a1 not eligible for variable processors
[05:20:59] Core required: FahCore_a1.exe
[05:20:59] Core found.
[05:20:59] Using generic mpiexec calls
[05:20:59] Working on queue slot 09 [November 21 05:20:59 UTC]
[05:20:59] + Working ...
[05:20:59] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 09 -checkpoint 15 -verbose -lifeline 5692 -version 623'
[05:21:01]
[05:21:01] *------------------------------*
[05:21:01] Folding@Home Gromacs SMP Core
[05:21:01] Version 1.74 (March 10, 2007)
[05:21:01]
[05:21:01] Preparing to commence simulation
[05:21:01] - Looking at optimizations...
[05:21:01] - Created dyn
[05:21:01] - Files status OK
[05:21:06] - Expanded 4812680 -> 24810145 (decompressed 515.5 percent)
[05:21:07] - Starting from initial work packet
[05:21:07]
[05:21:07] Project: 2665 (Run 2, Clone 563, Gen 69)
[05:21:07]
[05:21:07] Assembly optimizations on if available.
[05:21:07] Entering M.D.
[05:21:28]  percent)
[05:21:28] - Starting from initial work packet
[05:21:28]
[05:21:28] Project: 2665 (Run 2, Clone 563, Gen 69)
[05:21:28]
[05:21:32] Entering M.D.
[05:21:39] Rejecting checkpoint
[05:21:41] Protein: HGG with glycosylations
[05:21:41] Writing local files
[05:21:50] Extra SSE boost OK.
[05:21:50] Writing local files
[05:21:50] Completed 0 out of 250000 steps  (0 percent)
[05:36:51] Timered checkpoint triggered.
[05:40:11] Writing local files
[05:40:11] Completed 2500 out of 250000 steps  (1 percent)
         {snip}
[11:01:40] Timered checkpoint triggered.
[11:05:21] Writing local files
[11:05:21] Completed 240000 out of 250000 steps  (96 percent)
[11:07:10] Gromacs cannot continue further.
[11:07:10] Going to send back what have done.
[11:07:10] logfile size: 188395
[11:07:10] - Writing 188931 bytes of core data to disk...
[11:07:10]   ... Done.
[11:07:13] - Failed to delete work/wudata_09.arc
[11:07:13] Warning:  check for stray files
[11:09:13]
[11:09:13] Folding@home Core Shutdown: EARLY_UNIT_END
[11:09:13]
[11:09:18] CoreStatus = 7B (123)
[11:09:18] Sending work to server
[11:09:18] Project: 2665 (Run 2, Clone 563, Gen 69)
[11:09:18] + Attempting to send results [November 22 11:09:18 UTC]
[11:09:18] - Reading file work/wuresults_09.dat from core
[11:09:18]   (Read 188931 bytes from disk)
[11:09:18] Connecting to http://171.64.65.64:8080/
[11:09:25] Posted data.
[11:09:25] Initial: 0000; - Uploaded at ~26 kB/s
[11:09:25] - Averaged speed for that direction ~46 kB/s
[11:09:25] + Results successfully sent
[11:09:25] Thank you for your contribution to Folding@Home.
Re: Project: 2665 (Run 2, Clone 563, Gen 69)
There are 3 reports for partial credit ... nobody was able to finish it yet.
