Project: 2665 (Run 3, Clone 269, Gen 63)
Grendel
Hardware configuration: Q6600, Q9560 + GTX 660, i7-3770K + GTX 760
Post by Grendel »
EUE
[07:10:26] - Preparing to get new work unit...
[07:10:26] + Attempting to get work packet
[07:10:26] - Will indicate memory of 1536 MB
[07:10:26] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 15, Stepping: 11
[07:10:26] - Connecting to assignment server
[07:10:26] Connecting to http://assign.stanford.edu:8080/
[07:10:27] Posted data.
[07:10:27] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[07:10:27] + News From Folding@Home: Welcome to Folding@Home
[07:10:27] Loaded queue successfully.
[07:10:27] Connecting to http://171.64.65.64:8080/
[07:10:32] Posted data.
[07:10:32] Initial: 0000; - Receiving payload (expected size: 4743280)
[07:11:02] - Downloaded at ~154 kB/s
[07:11:02] - Averaged speed for that direction ~154 kB/s
[07:11:02] + Received work.
[07:11:02] Trying to send all finished work units
[07:11:02] + No unsent completed units remaining.
[07:11:02] + Closed connections
[07:11:02]
[07:11:02] + Processing work unit
[07:11:02] Work type a1 not eligible for variable processors
[07:11:02] Core required: FahCore_a1.exe
[07:11:02] Core found.
[07:11:02] Working on queue slot 04 [November 26 07:11:02 UTC]
[07:11:02] + Working ...
[07:11:02] - Calling 'mpiexec -np 4 -channel shm -env MPICH_USE_SMP_OPTIMIZATIONS 1 -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 04 -checkpoint 15 -verbose -lifeline 3788 -version 623'
[07:11:03]
[07:11:03] *------------------------------*
[07:11:03] Folding@Home Gromacs SMP Core
[07:11:03] Version 1.76 (February 23, 2008)
[07:11:03]
[07:11:03] Preparing to commence simulation
[07:11:03] - Ensuring status. Please wait.
[07:11:03] Created dyn
[07:11:03] - Files status OK
[07:11:08] - Expanded 4742768 -> 24426905 (decompressed 515.0 percent)
[07:11:08] - Starting from initial work packet
[07:11:08]
[07:11:08] Project: 2665 (Run 3, Clone 269, Gen 63)
[07:11:08]
[07:11:09] Assembly optimizations on if available.
[07:11:09] Entering M.D.
[07:11:34] al work packet
[07:11:34]
[07:11:34] Project: 2665 (Run 3, Clone 269, Gen 63)
[07:11:34]
[07:11:34] Entering M.D.
[07:11:44] Protein: HGG in water
[07:11:44] Writing local files
[07:11:44] Extra SSE boost OK.
[07:11:54]   (0 percent)
[07:26:55] Timered checkpoint triggered.
[07:27:05] Writing local files
[07:27:05] Completed 2500 out of 250000 steps  (1 percent)
[07:42:05] Timered checkpoint triggered.
[07:42:16] Writing local files
[07:42:16] Completed 5000 out of 250000 steps  (2 percent)
[..snip..]
[01:40:54] Completed 182500 out of 250000 steps  (73 percent)
[01:43:37] Gromacs cannot continue further.
[01:43:37] Going to send back what have done.
[01:43:37] logfile size: 145727
[01:43:37] - Writing 146263 bytes of core data to disk...
[01:43:37]   ... Done.
[01:43:37] No C.P. to delete.
[01:45:37]
[01:45:37] Folding@home Core Shutdown: EARLY_UNIT_END
[01:45:37]
[01:45:40] CoreStatus = 63 (99)
[01:45:40] + Error starting Folding@Home core.
[01:45:45]
[01:45:45] + Processing work unit
[01:45:45] Work type a1 not eligible for variable processors
[01:45:45] Core required: FahCore_a1.exe
[01:45:45] Core found.
[01:45:45] Working on queue slot 04 [November 27 01:45:45 UTC]
[01:45:45] + Working ...
[01:45:45] - Calling 'mpiexec -np 4 -channel shm -env MPICH_USE_SMP_OPTIMIZATIONS 1 -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 04 -checkpoint 15 -verbose -lifeline 3788 -version 623'
[01:45:46]
[01:45:46] *------------------------------*
[01:45:46] Folding@Home Gromacs SMP Core
[01:45:46] Version 1.76 (February 23, 2008)
[01:45:46]
[01:45:46] Preparing to commence simulation
[01:45:46] - Looking at optimizations...
[01:45:46] - Created dyn
[01:45:46] - Files status OK
[01:45:46]
[01:45:46] Folding@home Core Shutdown: MISSING_WORK_FILES
[01:45:46] Finalizing output
[01:47:50] CoreStatus = 1 (1)
[01:47:50] Sending work to server
[01:47:50] Project: 2665 (Run 3, Clone 269, Gen 63)
[01:47:50] + Attempting to send results [November 27 01:47:50 UTC]
[01:47:50] - Reading file work/wuresults_04.dat from core
[01:47:50]   (Read 146263 bytes from disk)
[01:47:50] Connecting to http://171.64.65.64:8080/
[01:47:52] Posted data.
[01:47:52] Initial: 0000; - Uploaded at ~47 kB/s
[01:47:53] - Averaged speed for that direction ~62 kB/s
[01:47:53] + Results successfully sent
[01:47:53] Thank you for your contribution to Folding@Home.
Re: Project: 2665 (Run 3, Clone 269, Gen 63)
Update your client to 6.23 : viewtopic.php?f=46&t=6642
There are 4 reports of EUE, but someone was able to complete it.
Grendel
Post by Grendel »
Grendel wrote:[07:11:02] - Calling 'mpiexec -np 4 -channel shm -env MPICH_USE_SMP_OPTIMIZATIONS 1 -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 04 -checkpoint 15 -verbose -lifeline 3788 -version 623'
I'll keep an eye on it.
Strange ... you shouldn't see this kind of issue with 6.23 client :?
