Project: 4609 (Run 1, Clone 1, Gen 62)
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
Catching up on old logs - EUE.
[08:13:22] + Closed connections
[08:13:22]
[08:13:22] + Processing work unit
[08:13:22] Core required: FahCore_82.exe
[08:13:22] Core found.
[08:13:22] Working on Unit 03 [November 24 08:13:22]
[08:13:22] + Working ...
[08:13:22] - Calling 'FahCore_82.exe -dir work/ -suffix 03 -checkpoint 15 -forceasm -verbose -lifeline 2504 -version 503'
[08:13:22]
[08:13:22] *------------------------------*
[08:13:22] Folding@Home PMD Core
[08:13:22] Version 1.03 (September 7, 2005)
[08:13:22]
[08:13:22] Preparing to commence simulation
[08:13:22] - Assembly optimizations manually forced on.
[08:13:22] - Not checking prior termination.
[08:13:22] - Expanded 11935 -> 75389 (decompressed 631.6 percent)
[08:13:22]
[08:13:22] Project: 4609 (Run 1, Clone 1, Gen 62)
[08:13:22]
[08:13:22] Assembly optimizations on if available.
[08:13:22] Entering M.D.
[08:13:24] + New frame time estimate; Working...
[08:13:29] + New frame time estimate; Working...
[08:13:29] Going to send back what have done.
[08:13:29] logfile size: 5649
[08:13:29] - Writing 6169 bytes of core data to disk...
[08:13:29]   ... Done.
[08:13:29]
[08:13:29] Folding@home Core Shutdown: EARLY_UNIT_END
[08:13:32] CoreStatus = 72 (114)
[08:13:32] Sending work to server
[08:13:32] + Attempting to send results
[08:13:32] - Reading file work/wuresults_03.dat from core
[08:13:32]   (Read 6169 bytes from disk)
[08:13:32] Connecting to http://169.230.26.30:8080/
[08:13:33] Posted data.
[08:13:33] Initial: 0000; - Uploaded at ~7 kB/s
[08:13:33] - Averaged speed for that direction ~40 kB/s
[08:13:33] + Results successfully sent
[08:13:33] Thank you for your contribution to Folding@Home.
Re: Project: 4609 (Run 1, Clone 1, Gen 62)
8 reports for 0 points : that's a bad WU :(
