Project: 2620 (Run 2, Clone 11, Gen 32)
Escher
Post by Escher »
I keep having a problem with this WU, seems this project has a lot of problems in general. I keep clearing out files in hopes to get a different WU, but continue to get the same one.
[13:59:19]
[13:59:19] *------------------------------*
[13:59:19] Folding@Home Gromacs Core
[13:59:19] Version 1.90 (March 8, 2006)
[13:59:19]
[13:59:19] Preparing to commence simulation
[13:59:19] - Looking at optimizations...
[13:59:19] - Created dyn
[13:59:19] - Files status OK
[13:59:20] - Expanded 413277 -> 10322281 (decompressed 2497.6 percent)
[13:59:20] - Starting from initial work packet
[13:59:20]
[13:59:20] Project: 2620 (Run 2, Clone 11, Gen 32)
[13:59:20]
[13:59:20] Assembly optimizations on if available.
[13:59:20] Entering M.D.
[13:59:27] Protein: p2620_p1475_tet1_03_1 t= 20000.00000
[13:59:27]
[13:59:27] Writing local files
[13:59:27] Gromacs error.
[13:59:27]
[13:59:27] Folding@home Core Shutdown: UNKNOWN_ERROR
Flathead74
Re: Project: 2620 (Run 2, Clone 11, Gen 32)
Post by Flathead74 »
Hang in there, Escher, normally after deleting bad WU files, on the fourth time you will receive a different WU.
ymmv
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
Which client are you using?
Escher
Post by Escher »
I'm using the latest systray client
I guess Peter will have to remove this one manually :?
anko1
Post by anko1 »
I asked b/c I was too lazy to look up and see what type of WU it was. They've done a nice job of handling this type of problem in the beta SMP release. Hopefully this will carry over when it comes out of beta since the object is to have just one client.
Escher
Post by Escher »
I really wish they'd hurry up and have an SMP systray client with a simple install package. Heck, make it support CPU and GPU too! Is this really too much to ask? If a user can set up 4 clients and a CPU client (like I have), surely they can figure out how to properly thread their app to do the same thing. It's not rocket science, but perhaps they need a good developer on staff to help.
