Project: 5757 (Run 1, Clone 117, Gen 0)
Alphax
Hardware configuration: Vista Home Premium 32-bit
Intel Core2 Duo T7700@2.4GHz, 3GB DDR2
NVIDIA GeForce 8600M GT, 256MB DDR2, PCI-E x16, 178.24 drivers
Post by Alphax »
Not good...
[07:41:09] Completed 1%
[07:47:32] Completed 2%
[07:53:54] Completed 3%
[08:00:13] Completed 4%
[08:06:35] Completed 5%
[08:08:15] Run: exception thrown during GuardedRun
[08:08:15] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[08:08:15] Going to send back what have done -- stepsTotalG=10000000
[08:08:15] Work fraction=0.0526 steps=10000000.
[08:08:19] logfile size=11256 infoLength=11256 edr=0 trr=23
[08:08:19] - Writing 11792 bytes of core data to disk...
[08:08:19] Done: 11280 -> 4069 (compressed to 36.0 percent)
[08:08:19]   ... Done.
[08:08:19]
[08:08:19] Folding@home Core Shutdown: EARLY_UNIT_END
[08:08:21] CoreStatus = 72 (114)
[08:08:21] Sending work to server
[08:08:21] Project: 5757 (Run 1, Clone 117, Gen 0)
Edit: the 5506 I received immediately afterwards was reporting low PPD (<800 vs. my normal 1000) - did the EUE leave the GPU in some sort of corrupted state?
Edit 2: It crashed, so quite possibly :(
(Hardware info in profile)
Re: Project: 5757 (Run 1, Clone 117, Gen 0)
There is only one record for this WU, and it's your EUE.
We'll have to wait a bit until someone else tries to run it.
Cajun_Don
Post by Cajun_Don »
I'm receiving a lot of 5757 right now (20 or more), with different R/C/G and they are all EUEing . Some before 1% complete with others after 10% - 20%. None of them have completed to 100%.
My Graphics Card is stable for other projects.
Have a great day.
What is your core version ? Try to remove overclocking if you have one.
Alphax
Post by Alphax »
toTOW wrote:What is your core version ? Try to remove overclocking if you have one.
Mine? 1.19, stock clocks (it's hard enough keeping a mobile GPU at sane temps without OC'ing).
I've checked this WU again, and someone else was able to complete it.
