Project 3798
anko1
(3.2GHz) HT;Windows XP
Project 3798
Post by anko1 »
When I first saw this in my log, I thought I had an error for sure. Then when I saw the finished unit, I thought this had to be the world's smallest WU. When I looked it up, I saw that they are testing code. :-)
[08:21:24] + Closed connections
[08:21:24]
[08:21:24] + Processing work unit
[08:21:24] Core required: FahCore_78.exe
[08:21:24] Core found.
[08:21:24] Working on Unit 06 [November 25 08:21:24]
[08:21:24] + Working ...
[08:21:24] - Calling 'FahCore_78.exe -dir work/ -suffix 06 -checkpoint 15 -verbose -lifeline 880 -version 504'
[08:21:24]
[08:21:24] *------------------------------*
[08:21:24] Folding@Home Gromacs Core
[08:21:24] Version 1.90 (March 8, 2006)
[08:21:24]
[08:21:24] Preparing to commence simulation
[08:21:24] - Looking at optimizations...
[08:21:24] - Created dyn
[08:21:24] - Files status OK
[08:21:25] - Expanded 237785 -> 1167708 (decompressed 491.0 percent)
[08:21:25] - Starting from initial work packet
[08:21:25]
[08:21:25] Project: 3798 (Run 30, Clone 4, Gen 1)
[08:21:25]
[08:21:25] Assembly optimizations on if available.
[08:21:25] Entering M.D.
[08:21:31] Protein: p3798
[08:21:31]
[08:21:31] Writing local files
[08:23:16] Extra SSE boost OK.
[08:23:16] Writing local files
[08:23:16] Completed 0 out of 1500 steps  (0)
[08:24:02] Writing local files
[08:24:03] Completed 500 out of 1500 steps  (33)
[08:24:51] Writing local files
[08:24:51] Completed 1000 out of 1500 steps  (67)
[08:25:40] Writing local files
[08:25:40] Completed 1500 out of 1500 steps  (100)
[08:25:40] Writing final coordinates.
[08:25:40] Past main M.D. loop
[08:26:40]
[08:26:40] Finished Work Unit:
[08:26:40] - Reading up to 550656 from "work/wudata_06.arc": Read 550656
[08:26:40] - Reading up to 0 from "work/wudata_06.xtc": Read 0
[08:26:40] goefile size: 0
[08:26:40] Leaving Run
[08:26:41] - Writing 573212 bytes of core data to disk...
[08:26:41] Done: 572700 -> 519640 (compressed to 90.7 percent)
[08:26:41]   ... Done.
[08:26:41] - Shutting down core
[08:26:41]
[08:26:41] Folding@home Core Shutdown: FINISHED_UNIT
Re: Project 3798
Wow it's been completed 3 times :shock:
anko1
Re: Project 3798
Post by anko1 »
That's interesting. I've had three separate WUs so far:
Project: 3798 (Run 6, Clone 0, Gen 28)
Project: 3798 (Run 11, Clone 0, Gen 1)
Btw, are they giving points for this? It didn't say in the project description.
Re: Project 3798
No record under your name for Project: 3798 (Run 6, Clone 0, Gen 28), but two people completed it successfully.
Hi anko1 (team 47815),
Your WU (P3798 R30 C4 G1) was added to the stats database on 2008-11-25 02:21:08 for 5 points of credit.
There also two other full credits for this one.
Project: 3798 (Run 11, Clone 0, Gen 1) : two people got full credit for it (but not you).
Yes they're worth 5 points ... and I don't think you should get them ...
anko1
Re: Project 3798
Post by anko1 »
"Yes they're worth 5 points ... and I don't think you should get them ..." At a point per minute I don't mind. :-D Thanks for checking.
Edit: thanks anandhanju for explaining toTOW's comment. Edit to reflect that.
Snyde
Re: Project 3798
Post by Snyde »
Having an issue uploading this one as well. From the time of download to the first upload attempt, about 17 minutes. Took about 6 minuted from writing local files to past main MD loop, completed with 100% time remaining.
Project: 3798 (Run 30, Clone 0, Gen 6)
16:34:05] + Attempting to send results
[16:34:05] - Reading file work/wuresults_09.dat from core
[16:34:05]   (Read 520061 bytes from disk)
[16:34:05] Connecting to http://171.64.122.139:8080/
[16:35:44] Writing local files
[16:35:44] Completed 325000 out of 2500000 steps  (13)
[16:41:01] - Couldn't send HTTP request to server
[16:41:01] + Could not connect to Work Server (results)
[16:41:01]     (171.64.122.139:8080)
[16:41:01] - Error: Could not transmit unit 09 (completed November 25) to work server.
[16:41:01] - 11 failed uploads of this unit.
[16:41:01] + Attempting to send results
[16:41:01] - Reading file work/wuresults_09.dat from core
[16:41:01]   (Read 520061 bytes from disk)
[16:41:01] Connecting to http://171.64.122.135:8080/
[16:41:05] Posted data.
[16:41:05] Initial: 0000; - Uploaded at ~127 kB/s
[16:41:05] - Averaged speed for that direction ~131 kB/s
[16:41:05] - Server does not have record of this unit. Will try again later.
[16:41:05]   Could not transmit unit 09 to Collection server; keeping in queue.
[16:41:05] + Sent 0 of 1 completed units to the server
Don't care about the points, just wondering how much longer this will try to upload. What is the expiry date and when will it auto delete? Or should I not sweat this?
Regards-
jb
jb
anandhanju
Re: Project 3798
Post by anandhanju »
I think the unit has an expiry period of 2 days, and as toTOW said, they shouldn't have been assigned outside of testing.
I had trouble uploading them as well, but they just went through about half an hour ago. Try stopping the client and restarting it or use the -send all switch.
Snyde
Re: Project 3798
Post by Snyde »
anandhanju wrote:I think the unit has an expiry period of 2 days, and as toTOW said, they shouldn't have been assigned outside of testing.
Will give it a go, thanks-
jb
Snyde
Re: Project 3798
Post by Snyde »
No go. Will it auto delete after expiration?
Regards-
jb
anko1
Re: Project 3798
Post by anko1 »
If it gets close to the deadline, I'd delete the unit. If autosend tries to send a past due unit, it kills the unit that's being worked on. At least that's been my experience.
http://foldingforum.org/viewtopic.php?f ... =15#p66245
GrGramps
Re: Project 3798
Post by GrGramps »
Looks like project 3798 is back again. Downloaded 48 min ago; preferred deadline 34 min ago. I suppose I'm too slow?
John Naylor
Hardware configuration: Q9450 OC @ 3.2GHz (Win7 Home Premium) - SMP2
i5-3750k @ 3.8GHz (Win7 Pro) - SMP2
Re: Project 3798
Post by John Naylor »
lol... it reports that deadline but folds on straight through it... I dunno why.
Folding whatever I'm sent since March 2006 :) Beta testing since October 2006. www.FAH-Addict.net Administrator since August 2009.
susato
Re: Project 3798
Post by susato »
I'll report it but since it's the weekend, please have extra patience. And it may be doing precisely what it's supposed to do.
IMHO this project is server test code again. Did you see there's no atom count for it in its psummary listing? The 0.01 day preferred deadline would make sure that it gets issued again every few minutes, slowly building up in number and in its ability to load up the server, while the 2 day final deadline gives everyone who gets it a chance to earn points on it.
Rather ingenious if you ask me!
Grandpa_01
Re: Project 3798
Post by Grandpa_01 »
I think they were trying to load the servers today I started getting the about 3 AM this morning and kept getting them until about 1 hr ago 7 PM. I had around 30 of them today, made for allot of points and probably did a pretty good job of loading up the servers. The longest I had to wait for another WU was 7 attempts most connected and downloaded on the first attempt.
2 - I7 980X 4.4Ghz 2-GTX680
1 - 2700k 4.4Ghz GTX680
Total = 464 cores folding
jcoffland
Re: Project 3798
Post by jcoffland »
susato wrote:IMHO this project is server test code again. Did you see there's no atom count for it in its psummary listing? The 0.01 day preferred deadline would make sure that it gets issued again every few minutes, slowly building up in number and in its ability to load up the server, while the 2 day final deadline gives everyone who gets it a chance to earn points on it.
That's correct. I am going to stop new assignments of project 3798 for now though to avoid wasting CPU cycles.
Cauldron Development LLC
http://cauldrondevelopment.com/
