Project: 2665 (Run 0, Clone 850, Gen 60)
osgorth
Post by osgorth »
Found another EUE.. Probably because I said it was a long time since I saw one, and now two in the same day! Typical.. ;)
This is on a new machine so I'd appreciate if someone could check if it's been reported by someone else?
[19:21:07] *------------------------------*
[19:21:07] Folding@Home Gromacs SMP Core
[19:21:07] Version 1.74 (March 10, 2007)
[19:21:07]
[19:21:07] Preparing to commence simulation
[19:21:07] - Ensuring status. Please wait.
[19:21:24] - Assembly optimizations manually forced on.
[19:21:24] - Not checking prior termination.
[19:21:44] - Expanded 4744424 -> 24426905 (decompressed 514.8 percent)
[19:21:44] - Starting from initial work packet
[19:21:44]
[19:21:44] Project: 2665 (Run 0, Clone 850, Gen 60)
[19:21:44]
[19:21:45] Assembly optimizations on if available.
[19:21:45] Entering M.D.
[19:21:51] Rejecting checkpoint
[19:21:53] Protein: HGG in water
[19:21:53] Writing local files
[19:22:00] Extra SSE boost OK.
[19:22:01] Writing local files
[19:22:01] Completed 0 out of 250000 steps  (0 percent)
[05:26:34] Completed 62500 out of 250000 steps  (25 percent)
[05:48:49] Warning:  long 1-4 interactions
[05:48:50] Gromacs cannot continue further.
[05:48:50] Going to send back what have done.
[05:48:50] logfile size: 0
[05:48:50] Warning: Core could not open logfile.
[05:48:50] - Writing 536 bytes of core data to disk...
[05:48:50]   ... Done.
[05:48:50] - Failed to delete work/wudata_05.sas
[05:48:50] - Failed to delete work/wudata_05.goe
[05:48:50] Warning:  check for stray files
[05:50:50]
[05:50:50] Folding@home Core Shutdown: EARLY_UNIT_END
[05:50:50]
[05:50:54] CoreStatus = 7B (123)
[05:50:54] Client-core communications error: ERROR 0x7b
[05:50:54] This is a sign of more serious problems, shutting down.
Re: Project: 2665 (Run 0, Clone 850, Gen 60)
There are 4 other reports for partial credit, but finally someone was able to complete it :)
osgorth
Post by osgorth »
Ok, merci! I'll keep a close look on that machine the coming week, then.
