Workunit size, upload and download size
chungenhung
How can I tell how big a work unit is???
I need to know the download size and upload size. Only on GPU work units. My CPU is running for BOINC.
Thanks
Thanks
anandhanju
Re: Workunit size, upload and download size
When a WU is downloaded and decompressed, look at the value at the left. It indicates the downloaded size.
After results have been compressed, look for the value n in the message "Read n bytes from disk". It indicates the upload size.[02:15:38] Folding@Home Gromacs Core
[02:15:38] Version 1.90 (March 8, 2006)
[02:15:38]
[02:15:38] Preparing to commence simulation
[02:15:38] - Assembly optimizations manually forced on.
[02:15:38] - Not checking prior termination.
[02:15:38] - Expanded 237859 -> 1167708 (decompressed 490.9 percent)
[02:15:38] - Starting from initial work packet
All sizes are in bytes. You may have to switch on -verbosity 9 to see these messages, I'm not certain.[02:20:26] + Attempting to send results [November 25 02:20:26 UTC]
[02:20:26] - Reading file work/wuresults_02.dat from core
[02:20:26] (Read 520425 bytes from disk)
It depends. Some work units are quite small, like the CPU client, while others can be larger, as with the SMP client, from a few K to 10s of MB.
You can set a preference for larger or smaller work units in the client setup for the CPU client, but if you run the SMP client, you will always get larger work units. You don't have a choice with SMP WUs.
And just like you can't pick which work units to fold, you can't really choose a size either. You get what the project sends you.
Why do you need to know the size, maybe we can find a different solution...
chungenhung
Well, I never said I want to pick work units.7im wrote: And just like you can't pick which work units to fold, you can't really choose a size either. You get what the project sends you.
I need to know the size because my ISP is #$%^&* saying I am using too much bandwidth.
I don't think that is possible with normal internet surfing and F@H.
v00d00
- 16GB DDR3,
- Zotac GTX 1050Ti @ Stock.
- Gigabyte GTX 970 @ Stock
Debian 9.
Avg A2 workunit is either 26mb or 48mb, but there are some 96mb uploaders coming through, and the trend if you look at whats coming through now, is it will likely go up exponentially.
Some numbers ripped from my machines running SMP or normal cpu client, with the -adv flag.
A2:
P2668: Download 4830414 bytes, Upload 49152308 bytes
P2669: Download 4829642 bytes, Upload 26037350 bytes
P2672: Download 4841671 bytes, Upload 26058736 bytes
P2675: Download 4842022 bytes, Upload 26069481 bytes
A1:
P2665: Download 4660863 bytes, Upload 21932466 bytes
P5101: Download 739597 bytes, Upload 2859679 bytes
Normal Client with BigWU on:
P2445: Download 5106834 bytes, Upload 40557899 bytes
P2493: Download 2225146 bytes, Upload 2716880 bytes
A2:
A1:
You might consider finding an ISP that doesn't limit (or charge) network traffic
... none of them (56k, cable or ADSL ones) do this kind of shit in France ... except those that promise "unlimited" 3G+ surf (by unlimited, they mean that there is a limit of 500MB per month,and they can lower the transfer rate if you use too much traffic).
v00d00
- 16GB DDR3,
Debian 9.
I worked out what each SMP machine has used per month, based on 2 clients per machine. It comes to around 4GB. The CPU machines amount to around 1GB. Add on normal usage, an you could easily go over 10GB bandwidth per month.
What size package do you have?
If you are running linux machines, look into vnstat for bandwidth monitoring. It should give you an idea of what you are using per hour/day/week/month and uses /proc to gather data, so no need for extra kernel modules.
On windows, look at the firewall on each machine, it should tell you how much data you've moved. Then do some Math to get a rough idea.
chungenhung
Where is the bandwidth data regarding Windows firewall? I can't find it.v00d00 wrote:I worked out what each SMP machine has used per month, based on 2 clients per machine. It comes to around 4GB. The CPU machines amount to around 1GB. Add on normal usage, an you could easily go over 10GB bandwidth per month.
I don't have a fixed size package, its just that they told me I am using a lot of bandwidth and should cut it down a bit.
I'm using NetMeter to monitor my Windows network interfaces : it gives instantaneous rate and record the amount of transferred data.
chungenhung
Thanks a bunch. This is what I am looking for. You rock!toTOW wrote:I'm using NetMeter to monitor my Windows network interfaces : it gives instantaneous rate and record the amount of transferred data.
