Project: 5742 (Run 4, Clone 35, Gen 0)
osgorth
Post by osgorth »
[17:49:11] Folding@Home GPU Core - Beta
[17:49:11] Version 1.18 (Mon Oct 13 11:11:30 PDT 2008)
[17:49:11]
[17:49:11] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[17:49:11] Build host: amoeba
[17:49:11] Board Type: AMD
[17:49:11] Core      :
[17:49:11] Preparing to commence simulation
[17:49:11] - Looking at optimizations...
[17:49:11] - Created dyn
[17:49:11] - Files status OK
[17:49:11] - Expanded 66068 -> 360060 (decompressed 544.9 percent)
[17:49:11] Called DecompressByteArray: compressed_data_size=66068 data_size=360060, decompressed_data_size=360060 diff=0
[17:49:12] - Digital signature verified
[17:49:12]
[17:49:12] Project: 5742 (Run 4, Clone 35, Gen 0)
[17:49:12]
[17:49:12] Assembly optimizations on if available.
[17:49:12] Entering M.D.
[17:49:19] Working on Protein
[17:49:19] Client config found, loading data.
[17:49:19] Starting GUI Server
[17:49:20] mdrun_gpu returned
[17:49:20] Self-test failure
[17:49:20]
[17:49:20] Folding@home Core Shutdown: UNSTABLE_MACHINE
[17:49:24] CoreStatus = 7A (122)
Re: Project: 5742 (Run 4, Clone 35, Gen 0)
This one is completed without issue too ... strange again :
Hi osgorth (team 37451),
Your WU (P5742 R4 C35 G0) was added to the stats database on 2008-11-23 14:51:58 for 384 points of credit.
osgorth
Post by osgorth »
Will double-check this in my logs too..
osgorth
Post by osgorth »
You're correct, it was later picked up and successfully folded!?
This is new behaviour - first time it crashes instantly, then a few hours later it picks up the same WU and folds it without a problem. Isn't that strange??
