Project: 5742 (Run 1, Clone 10, Gen 15)
osgorth
Post by osgorth »
Multiple instant failures of this one, bad WU?
[22:21:38] *------------------------------*
[22:21:38] Folding@Home GPU Core - Beta
[22:21:38] Version 1.18 (Mon Oct 13 11:11:30 PDT 2008)
[22:21:38]
[22:21:38] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[22:21:38] Build host: amoeba
[22:21:38] Board Type: AMD
[22:21:38] Core      :
[22:21:38] Preparing to commence simulation
[22:21:38] - Looking at optimizations...
[22:21:38] - Created dyn
[22:21:38] - Files status OK
[22:21:38] - Expanded 70238 -> 360060 (decompressed 512.6 percent)
[22:21:38] Called DecompressByteArray: compressed_data_size=70238 data_size=360060, decompressed_data_size=360060 diff=0
[22:21:38] - Digital signature verified
[22:21:38]
[22:21:38] Project: 5742 (Run 1, Clone 10, Gen 15)
[22:21:38]
[22:21:38] Assembly optimizations on if available.
[22:21:38] Entering M.D.
[22:21:44] Working on Protein
[22:21:44] Client config found, loading data.
[22:21:44] Starting GUI Server
[22:21:47] mdrun_gpu returned
[22:21:47] Nonzero force sum on GPU
[22:21:47]
[22:21:47] Folding@home Core Shutdown: UNSTABLE_MACHINE
[22:21:50] CoreStatus = 7A (122)
Re: Project: 5742 (Run 1, Clone 10, Gen 15)
Strange indeed :
Hi osgorth (team 37451),
Your WU (P5742 R1 C10 G15) was added to the stats database on 2008-11-21 19:48:23 for 384 points of credit.
osgorth
Post by osgorth »
Very strange.. I only found it once in my log file and that was what I pasted above. :/
I'll look through it again tonight when I get home!
osgorth
Post by osgorth »
You're correct here as well, it was later picked up and successfully folded!?
This is new behaviour - first time it crashes instantly, then a few hours later it picks up the same WU and folds it without a problem. Isn't that strange??
