running the GPU2 client:
[03:43:52] + Attempting to get work packet
[03:43:52] - Will indicate memory of 2048 MB
[03:43:52] - Connecting to assignment server
[03:43:52] Connecting to http://assign-GPU.stanford.edu:8080/
[03:43:52] Posted data.
[03:43:52] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[03:43:52] + Couldn't get work instructions.
[03:43:52] - Attempt #12 to get work failed, and no other work to do.
Waiting before retry.
Been about 2:15 now.
server gives back an OK when http'ing directly to it.
Last WU was Project: 4743 (Run 1, Clone 924, Gen 22)
appears it's tried to connect to a couple other servers:
Connecting to http://171.64.65.103:80/
[01:29:08] - Couldn't send HTTP request to server
Could not connect to Work Server (results)
[01:29:09] (171.67.108.25:8080)
Re: No appropriate work server was available;
Same thing here, both my ATI clients are trying to get work.
[12:50:40] - Preparing to get new work unit...
[12:50:40] + Attempting to get work packet
[12:50:40] - Will indicate memory of 8190 MB
[12:50:40] - Connecting to assignment server
[12:50:40] Connecting to http://assign-GPU.stanford.edu:8080/
[12:50:41] Posted data.
[12:50:41] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[12:50:41] + Couldn't get work instructions.
[12:50:41] - Attempt #1 to get work failed, and no other work to do.
[12:50:46] + Attempting to get work packet
[12:50:46] - Will indicate memory of 8190 MB
[12:50:46] - Connecting to assignment server
[12:50:46] Connecting to http://assign-GPU.stanford.edu:8080/
[12:50:47] Posted data.
[12:50:47] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[12:50:47] + Couldn't get work instructions.
[12:50:47] - Attempt #2 to get work failed, and no other work to do.
[12:51:00] + Attempting to get work packet
[12:51:00] - Will indicate memory of 8190 MB
[12:51:00] - Connecting to assignment server
[12:51:00] Connecting to http://assign-GPU.stanford.edu:8080/
[12:51:00] Posted data.
[12:51:01] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[12:51:01] + Couldn't get work instructions.
[12:51:01] - Attempt #3 to get work failed, and no other work to do.
[12:51:33] + Attempting to get work packet
[12:51:33] - Will indicate memory of 8190 MB
[12:51:33] - Connecting to assignment server
[12:51:33] Connecting to http://assign-GPU.stanford.edu:8080/
[12:51:34] Posted data.
[12:51:34] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[12:51:34] + Couldn't get work instructions.
[12:51:34] - Attempt #4 to get work failed, and no other work to do.
[12:52:26] + Attempting to get work packet
[12:52:26] - Will indicate memory of 8190 MB
[12:52:26] - Connecting to assignment server
[12:52:26] Connecting to http://assign-GPU.stanford.edu:8080/
[12:52:26] Posted data.
[12:52:26] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[12:52:26] + Couldn't get work instructions.
[12:52:26] - Attempt #5 to get work failed, and no other work to do.
[12:53:47] + Attempting to get work packet
[12:53:47] - Will indicate memory of 8190 MB
[12:53:47] - Connecting to assignment server
[12:53:47] Connecting to http://assign-GPU.stanford.edu:8080/
[12:53:47] Posted data.
[12:53:47] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[12:53:47] + Couldn't get work instructions.
[12:53:47] - Attempt #6 to get work failed, and no other work to do.
[12:56:30] + Attempting to get work packet
[12:56:30] - Will indicate memory of 8190 MB
[12:56:30] - Connecting to assignment server
[12:56:30] Connecting to http://assign-GPU.stanford.edu:8080/
[12:56:30] Posted data.
[12:56:30] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[12:56:30] + Couldn't get work instructions.
[12:56:30] - Attempt #7 to get work failed, and no other work to do.
[13:01:58] + Attempting to get work packet
[13:01:58] - Will indicate memory of 8190 MB
[13:01:58] - Connecting to assignment server
[13:01:58] Connecting to http://assign-GPU.stanford.edu:8080/
[13:01:59] Posted data.
[13:01:59] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[13:01:59] + Couldn't get work instructions.
[13:01:59] - Attempt #8 to get work failed, and no other work to do.
Machine #2:
Machine 3:
I too am running into the same problem with my ATI GPU's.
