Project: 2665 (Run 2, Clone 726, Gen 68)
subego
Post by subego »
Hit me twice now. Figured this was the place to see what was up.
Should I switch off -forceasm and try again?
[23:46:24] Folding@Home Gromacs SMP Core
[23:46:24] Version 1.76 (February 23, 2008)
[23:46:24]
[23:46:24] Preparing to commence simulation
[23:46:24] - Ensuring status. Please wait.
[23:46:31] - Starting from initial work packet
[23:46:31]
[23:46:31] Project: 2665 (Run 2, Clone 726, Gen 68)
[23:46:31]
[23:46:32] Assembly optimizations on if available.
[23:46:32] Entering M.D.
[23:46:53]  on if available.
[23:46:53] Entering M.D.
[23:47:06] Protein: HGG with glycosylations
[23:47:06] Writing local files
[23:47:08] Extra SSE boost OK.
[23:47:18] al files
[23:47:18] Completed 0 out of 250000 steps  (0 percent)
[00:13:14] Writing local files
[00:13:15] Completed 2500 out of 250000 steps  (1 percent)
[00:38:25] Writing local files
[00:38:25] Completed 5000 out of 250000 steps  (2 percent)
[01:03:15] Writing local files
[18:40:12] Completed 112500 out of 250000 steps  (45 percent)
[19:03:55] Writing local files
[19:03:55] Completed 115000 out of 250000 steps  (46 percent)
[19:12:03] Gromacs cannot continue further.
[19:12:03] Going to send back what have done.
[19:12:03] logfile size: 80147
[19:12:03] - Writing 80683 bytes of core data to disk...
[19:12:03]   ... Done.
[19:12:03] - Failed to delete work/wudata_01.sas
[19:12:03] - Failed to delete work/wudata_01.goe
[19:12:03] Warning:  check for stray files
[19:12:03]
[19:12:03] Folding@home Core Shutdown: EARLY_UNIT_END
[19:12:03]
[19:12:07] CoreStatus = 63 (99)
[19:12:07] + Error starting Folding@Home core.
[19:12:12]
[19:12:12] + Processing work unit
[19:12:12] Work type a1 not eligible for variable processors
[19:12:12] Core required: FahCore_a1.exe
[19:12:12] Core found.
[19:12:12] Working on queue slot 01 [November 23 19:12:12 UTC]
[19:12:12] + Working ...
[19:12:16]
[19:12:16] *------------------------------*
[19:12:16] Folding@Home Gromacs SMP Core
[19:12:16] Version 1.76 (February 23, 2008)
[19:12:16]
[19:12:16] Preparing to commence simulation
[19:12:16] - Assembly optimizations manually forced on.
[19:12:16] - Not checking prior termination.
[19:12:16]
[19:12:16] Folding@home Core Shutdown: MISSING_WORK_FILES
[19:12:16] Finalizing output
[19:14:20] CoreStatus = 1 (1)
[19:14:20] Client-core communications error: ERROR 0x1
[19:14:20] This is a sign of more serious problems, shutting down.
Re: Project: 2665 (Run 2, Clone 726, Gen 68)
Update your client to 6.23, it handles EUE better : viewtopic.php?f=46&t=6642
Project: 2665 (Run 2, Clone 726, Gen 68) is a bad WU, nobody was able to complete it (3 similar reports are in the DB).
subego
Post by subego »
Awesome. Thank you. :)
