Folding-Stats-Plus is a plugin for wordpress that displays your stats in the sidebar of your blog using a widget.
The latest stable version is always available from http://wordpress.org/extend/plugins/folding-stats-plus/.
You can see screenshots here: http://wordpress.org/extend/plugins/fol ... reenshots/
There are a few style options in the admin screen and some cache options.
The plugin caches the data in the wordpress database. If the stats server is down when the plugin goes to update it will try again an hour later.
Newest versions are always posted on my blog.
WordPress Plugin for F@H
My Blog will always have the latest version of Folding-Stats-Plus the F@H plugin for wordpress.
Re: WordPress Plugin for F@H
After nearly a year and a lot of updates to the plugin I decided it was time to totally rewrite the code.
It is now optimized for the latest version of wordpress.
The dev version is here: http://downloads.wordpress.org/plugin/f ... s-plus.zip
The final version will be ready soon. You can see the dev version working here: http://www.pross.org.uk
Great work!
MSI Eclipse i7@3.45GHz
2x GTX260@702/1053/1512 Win 7+VMware+linuxfah VM+bigadv
