Project: 5745 (Run 2, Clone 28, Gen 1), Core: 11
antisocd
Hardware configuration: Intel E6750@2.66 Sapphire ATI3850
Post by antisocd »
Hi There!
Need a bit of help. I am new and face the problem that the project in the subject has been started on the GPU version twice. Is this normal or am i doing something wrong? :oops: I guess that does not count twice in the stats, does it? I have both the GPU and the CPU version working on my PC at the same time, but it is the GPU that has done the project 5745 (same run and everyting :D) twice.
Thanks for any advice
Re: Project: 5745 (Run 2, Clone 28, Gen 1), Core: 11
I suggest your read this Wiki entry to understand what Project, Run, Clone and Gen are : http://fahwiki.net/index.php/Runs%2C_Clones_and_Gens
antisocd
Post by antisocd »
Checked it, Thanks. :D
