Some weeks ago I got this odd message. Now I get it again (please, see 12:41:23):
[12:18:10] Completed 247500 out of 250000 steps (99%)
[12:39:52] Writing local files
[12:39:53] Completed 250000 out of 250000 steps (100%)
[12:39:53] Writing final coordinates.
[12:39:55] Past main M.D. loop
[12:40:55]
[12:40:55] Finished Work Unit:
[12:40:55] - Reading up to 3049368 from "work/wudata_06.arc": Read 3049368
[12:40:55] - Reading up to 4221816 from "work/wudata_06.xtc": Read 4221816
[12:40:55] goefile size: 0
[12:40:55] logfile size: 73591
[12:40:55] Leaving Run
[12:40:58] - Writing 7385955 bytes of core data to disk...
[12:41:02] Done: 7385443 -> 6796036 (compressed to 92.0 percent)
[12:41:02] ... Done.
[12:41:02] - Shutting down core
[12:41:02]
[12:41:02] Folding@home Core Shutdown: FINISHED_UNIT
[12:41:05] CoreStatus = 64 (100)
[12:41:05] Sending work to server
[12:41:05] Project: 2611 (Run 0, Clone 308, Gen 107)
[12:41:05] - Read packet limit of 540015616... Set to 524286976.
[12:41:05] + Attempting to send results [November 22 12:41:05 UTC]
[12:41:05] - Couldn't send HTTP request to server
[12:41:05] (Got status 503)
[12:41:05] + Could not connect to Work Server (results)
[12:41:05] (171.64.65.65:8080)
[12:41:05] + Retrying using alternative port
[12:41:05] (171.64.65.65:80)
[12:41:05] - Error: Could not transmit unit 06 (completed November 22) to work server.
[12:41:05] Keeping unit 06 in queue.
[12:41:06] - Couldn't send HTTP request to server
[12:41:06] (Got status 503)
[12:41:06] + Could not connect to Work Server (results)
[12:41:06] (171.64.65.65:8080)
[12:41:06] + Retrying using alternative port
[12:41:06] (171.64.65.65:80)
[12:41:06] - Error: Could not transmit unit 06 (completed November 22) to work server.
[12:41:06] - Read packet limit of 540015616... Set to 524286976.
[12:41:06] + Attempting to send results [November 22 12:41:06 UTC]
[12:41:07] - Couldn't send HTTP request to server
[12:41:07] (Got status 503)
[12:41:07] + Could not connect to Work Server (results)
[12:41:07] (171.67.108.25:8080)
[12:41:07] + Retrying using alternative port
[12:41:07] (171.67.108.25:80)
[12:41:07] Could not transmit unit 06 to Collection server; keeping in queue.
[12:41:07] - Preparing to get new work unit...
[12:41:07] + Attempting to get work packet
[12:41:07] - Connecting to assignment server
[12:41:08] - Successful: assigned to (171.64.122.72).
[12:41:08] + News From Folding@Home: Welcome to Folding@Home
[12:41:08] Loaded queue successfully.
[12:41:09] - Couldn't send HTTP request to server
[12:41:09] (Got status 503)
[12:41:09] + Could not connect to Work Server
[12:41:09] - Attempt #1 to get work failed, and no other work to do.
Waiting before retry.
[12:41:25] + Attempting to get work packet
[12:41:25] - Connecting to assignment server
[12:41:26] - Successful: assigned to (171.64.122.72).
[12:41:26] + News From Folding@Home: Welcome to Folding@Home
[12:41:26] Loaded queue successfully.
[12:41:26] - Couldn't send HTTP request to server
[12:41:26] (Got status 503)
[12:41:26] + Could not connect to Work Server
[12:41:26] - Attempt #2 to get work failed, and no other work to do.
[12:41:39] + Attempting to get work packet
[12:41:39] - Connecting to assignment server
[12:41:39] - Successful: assigned to (171.64.122.72).
[12:41:39] + News From Folding@Home: Welcome to Folding@Home
[12:41:40] Loaded queue successfully.
[12:41:40] - Couldn't send HTTP request to server
[12:41:40] (Got status 503)
[12:41:40] + Could not connect to Work Server
[12:41:40] - Attempt #3 to get work failed, and no other work to do.
[12:42:11] + Attempting to get work packet
[12:42:11] - Connecting to assignment server
[12:42:12] - Successful: assigned to (171.64.122.72).
[12:42:12] + News From Folding@Home: Welcome to Folding@Home
[12:42:12] Loaded queue successfully.
[12:42:15] Project: 2611 (Run 0, Clone 308, Gen 107)
[12:42:15] - Read packet limit of 540015616... Set to 524286976.
[12:42:15] + Attempting to send results [November 22 12:42:15 UTC]
[12:42:15] - Couldn't send HTTP request to server
[12:42:15] (Got status 503)
[12:42:15] + Could not connect to Work Server (results)
[12:42:15] (171.64.65.65:8080)
[12:42:15] + Retrying using alternative port
[12:42:15] (171.64.65.65:80)
[12:42:15] - Error: Could not transmit unit 06 (completed November 22) to work server.
[12:43:21] - Server does not have record of this unit. Will try again later.
[12:43:21] Could not transmit unit 06 to Collection server; keeping in queue.
[12:43:21] + Closed connections
[12:43:21]
[12:43:21] + Processing work unit
[12:43:21] Core required: FahCore_81.exe
[12:43:21] Core found.
[12:43:21] Working on queue slot 07 [November 22 12:43:21 UTC]
[12:43:21] + Working ...
[12:43:21]
[12:43:21] *------------------------------*
[12:43:21] Folding@Home Gromacs Simulated Tempering Core
[12:43:21] Version 1.10 (Oct 4, 2007)
[12:43:21]
[12:43:21] Preparing to commence simulation
[12:43:21] - Looking at optimizations...
[12:43:21] - Created dyn
[12:43:21] - Files status OK
[12:43:21] - Expanded 239860 -> 1167683 (decompressed 486.8 percent)
[12:43:21] - Starting from initial work packet
[12:43:21]
[12:43:21] Project: 4418 (Run 18, Clone 5, Gen 155)
[12:43:21]
[12:43:21] Assembly optimizations on if available.
[12:43:21] Entering M.D.
[12:43:27] Protein: p4418_Seq_50_nat_AMBER_Native
[12:43:27]
[12:43:27] Writing local files
[12:45:13] Extra SSE boost OK.
[12:45:13] Writing local files
[12:45:13] Completed 0 out of 150000 steps (0%)
[12:46:34] Writing local files
Perhaps this golden hand can try to do the trick for me again?
Thank you in advance,
Oriolus
