Project: 2445 (Run 38, Clone 27, Gen 0)
ei57
Post by ei57 »
Running a Folding@Home Client Version 5.04beta on an E8400@3.5GHz with 404 completed WU's in recorded history. This is maybe the second to give an EUE. Temps are not an issue, CPU cores around 50C and the computer never hangs. There is however an exception to the latter, it always hangs when running Gigabyte's OC SW.
[01:17:20] Folding@Home Gromacs Core
[01:17:20] Version 1.90 (March 8, 2006)
[01:17:20]
[01:17:20] Preparing to commence simulation
[01:17:20] - Looking at optimizations...
[01:17:20] - Created dyn
[01:17:20] - Files status OK
[01:17:26] - Expanded 5107253 -> 28568413 (decompressed 559.3 percent)
[01:17:26] - Starting from initial work packet
[01:17:26]
[01:17:26] Project: 2445 (Run 38, Clone 27, Gen 0)
[01:17:26]
[01:17:27] Assembly optimizations on if available.
[01:17:27] Entering M.D.
[01:17:34] Protein: Protein
[01:17:34]
[01:17:34] Writing local files
[01:17:40] Extra SSE boost OK.
[01:17:41] Writing local files
[01:17:41] Completed 0 out of 250000 steps  (0)
[01:37:43] Quit 101 - Fatal error:
[01:37:43] Step 1501, time 3.002 (ps)  LINCS WARNING
[01:37:43] relative constraint deviation after LINCS:
[01:37:43] max 0.000040 (between atoms 29683 and 29684) rms 0.000003
[01:37:43]
[01:37:43] Simulation instability has been encountered. The run has entered a
[01:37:43]   state from which no further progress can be made.
[01:37:43] This may be the correct result of the simulation, however if you
[01:37:43]   often see other project units terminating early like this
[01:37:43]   too, you may wish to check the stability of your computer (issues
[01:37:43]   such as high temperature, overclocking, etc.).
[01:37:43] Going to send back what have done.
[01:37:43] logfile size: 9542
[01:37:43] - Writing 10224 bytes of core data to disk...
[01:37:43]   ... Done.
[01:37:43]
[01:37:43] Folding@home Core Shutdown: EARLY_UNIT_END
[01:37:46] CoreStatus = 72 (114)
[01:37:46] Sending work to server
[01:37:46] + Attempting to send results
[01:37:47] + Results successfully sent
[01:37:47] Thank you for your contribution to Folding@Home.
[01:37:51] + Attempting to send results
[01:39:55] + Results successfully sent
[01:39:55] Thank you for your contribution to Folding@Home.
[01:39:55] + Number of Units Completed: 404
The client completed a 2493 a couple of days ago and comparing the logs, this one was close to 1% done before EUEing.
Re: Project: 2445 (Run 38, Clone 27, Gen 0)
There are 7 reports for partial credit for this WU ... I think this one one won't go to 100% :(
soa_rru
Post by soa_rru »
toTOW wrote:There are 7 reports for partial credit for this WU ... I think this one one won't go to 100% :(
Been looking around for any info on the 2445 and this thread seems to be the only one anywhere :lol: ive been nibbling away at a 2445 R12 C3 G0 for the past 7days now and its sitting @ 78% so hopefully fingers crossed i should be able to finish it 8-)
Is the fact that no one has finished one yet the reason why FahMon still cant tell me the preferred deadline / PPD etc?
anandhanju
Post by anandhanju »
soa_rru wrote:Is the fact that no one has finished one yet the reason why FahMon still cant tell me the preferred deadline / PPD etc?
No. This project doesn't appear in the psummary page that FAHMon uses.
Here are the project details:
Project:            2445
Preferred deadline: 42.00
Final deadline:     93.00
Project description
Well, I was about to mark this WU as a bad one, but finally someone completed it : Your WU (P2445 R38 C27 G0) was added to the stats database on 2008-11-27 22:21:17 for 2435 points of credit. (I removed the username and teamnumber informations)
