Project: 4743 (Run 0, Clone 999, Gen 10)
osgorth
Post by osgorth »
Another instant failure, this is also from my 4870x2 card:
[06:56:52] Folding@Home GPU Core - Beta
[06:56:52] Version 1.18 (Mon Oct 13 11:11:30 PDT 2008)
[06:56:52]
[06:56:52] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[06:56:52] Build host: amoeba
[06:56:52] Board Type: AMD
[06:56:52] Core      :
[06:56:52] Preparing to commence simulation
[06:56:52] - Looking at optimizations...
[06:56:52] - Created dyn
[06:56:52] - Files status OK
[06:56:52] - Expanded 88361 -> 447304 (decompressed 506.2 percent)
[06:56:52] Called DecompressByteArray: compressed_data_size=88361 data_size=447304, decompressed_data_size=447304 diff=0
[06:56:52] - Digital signature verified
[06:56:52]
[06:56:52] Project: 4743 (Run 0, Clone 999, Gen 10)
[06:56:52]
[06:56:52] Assembly optimizations on if available.
[06:56:52] Entering M.D.
[06:56:58] Working on p4743_lam5w_300K
[06:56:58] Client config found, loading data.
[06:56:58] Starting GUI Server
[06:57:01] mdrun_gpu returned
[06:57:01] Nonzero force sum on GPU
[06:57:01]
[06:57:01] Folding@home Core Shutdown: UNSTABLE_MACHINE
[06:57:04] CoreStatus = 7A (122)
Re: Project: 4743 (Run 0, Clone 999, Gen 10)
There is only one other report for this WU, and it's an instant failure.
X_ArchAngel
Post by X_ArchAngel »
Just started getting this WU today - 4743 (5, 962, 43) - and it instantly EUE's on every attempt.
There are only records of two uploads for this WU -- one for 0 points and one for 548. Since it was completed, it should no longer be downloadable.
I see FahCore Version 1.18 but you didn't say which version of the client you are running.
